Old 07-29-2008, 08:53 PM   #1
2008 22' International CCD
vacaville , California
Can I tow my airstream with my H2
I have a 2003 H2, and was wondering how I go about towing my 2008 Airstream trailer with it. I have the air leveling system in my H2 and load leveling hitch for my airstream. But I need to know what hit receiver works best and any other experiences that you all have had with towing with the H2.
vacaville1 is offline   Reply With Quote
Old 07-29-2008, 08:59 PM   #2
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
With the 6700 pound towing limit of your Hummer and a base weight of 7100 lbs of your Classic, I don't think you have enough towing capacity. Which came first, the trailer or the H2
altamont is offline   Reply With Quote
Old 07-29-2008, 09:56 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
First off, welcome to the Forums. We're glad to have you with us.
A late model 30' Airstream ready to travel will probably go at least 8000#. That puts your tow load well past the H-2's capacity.
Brian
SuEllyn & Brian McCabe
Old 08-03-2008, 02:11 PM   #4
Astroboy's Avatar
2007 28' International CCD
West Hollywood , California
Hello,
I just bought a 2008 Hummer H2 last week to tow my 2007 28' CCD fully loaded. So, I am going through similar process as you do.
- I'm having airbag helper springs installed in the rear. I prefer the reliability of coil springs. Whenever I hitch up my trailer, I will just need to pump up the rear suspension with my bicycle pump.
- I'm also swapping out its Class III (5000) hitch, which was originally equipped with Class IV (10000).
I was advised that the weakest link is the class III hitch that was originally equipped from the factory. My hitch is only rated to tow 5000 pounds & 1000 pounds tongue weight (according to the sticker on the hitch), although H2's chassis is rated & known to tow much more. A shop showed me an actual broken hitch that was bent & ripped from overloading, then they quoted me $500 to swap out the hitch (parts & labor).
The new 2008 Hummer H2 has a new engine (Vortec 6.8L, 398 hp) & new 6-speed transmission, is rated to tow 8200 pounds.
I don't think there's any difference between the chassis & the brakes of 2008 and of 2003 H2. The frame is GM's 800-series chassis which was shared among Tahoe, Yukon, & Escalade.
Compared to Expedition or Tahoe, H2 can be shorter in overall length, but longer in wheelbase by about 6 inches, wider in track by 2 inches, this I believe is a good + for towing. However, H2 has higher center of gravity and the suspension is lifted and maybe softer. The tires are bigger & heavier, thus reducing the effective gear ratio of 3.73.
I think you can make your H2 good tow vehicle if you play your cards right. Do you have a Hensley?
Astroboy is offline   Reply With Quote
Old 08-03-2008, 03:16 PM   #5
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Really? Let's see, the tow rating of Vacaville1's 2003 humster is 6700 lbs. and the weight of the 30' Classic is 8700# (that's what mine says). That's a 2000# difference in the negative. And that's without people, gear and fluids.
Don't know what kind of "cards" your playing, but that's a loosing game no matter what kind of hitch you have!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 08-03-2008, 05:29 PM   #6
RBolton's Avatar
Belington , West Virginia
Before you all start throwing rocks - how did vacaville1 go from towing a 22 footer to towing a 30 footer?
RBolton is offline   Reply With Quote
Old 08-03-2008, 07:11 PM   #7
1971 25' Caravanner
scappoose , Oregon
The numbers for HP and torque, in the '08 H2, are what was considered to be "big block" figures, only a few years ago. That said, many of the most experienced "towers", consider not to tow more than 75-80% of the vehicles rating.
rangebowdrie is offline   Reply With Quote
Old 08-03-2008, 11:20 PM   #8
I have the smaller 22 ft unit. I mistakenly put in the 30 ft model. I figured it out already and it tows just fine. Thanks for all the responses
Looking for Airstream tow truck. Barry2952 Tow Vehicles 167 03-18-2012 06:06 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Airstream Tow Vehicle?? Ultradog Tow Vehicles 4 05-29-2006 03:18 PM
About to tow my first Airstream - Which WD set up? H TWO Hitches, Couplers & Balls 7 04-08-2006 12:36 PM
'78 Safari towed weight cdholt 1974 - 1979 Safari 3 08-25-2003 02:43 PM
