Old 06-06-2012, 05:51 PM   #1
Courtland , Ontario
Can I tow any airstream with a ford edge?
Hi
We are very interested in purchasing our first trailer. Through our research on trailers we have falllen in love with the Airstream trailers. We are now ready to buy but have hit a snag because our vehicle, a 2007 Ford Edge can only tow 3700 lbs. Is there any Airstream trailers I can tow with this vehicle? Or is there anything I can do to my vehicle to be able to tow a larger Airstream, preferably a 25' to 30' trailer?
Thanks.
Kris
Kapitor is offline   Reply With Quote
Old 06-06-2012, 06:05 PM   #2
Naper's Avatar
Loretto , Ontario
Can you tow a 25' Airstream with a Ford Edge, yes you can. Should you tow a 25' Airstream with a Ford Edge, no you shouldn't
Naper is offline   Reply With Quote
Old 06-06-2012, 06:07 PM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
You are very limited Kris on the newer AS. I ended up buying a certified preowned F150 with tow package because of this very reason. The lowest GVWR is the 16' sport with 3500 pounds or the listed 17' sport (never saw this one but they list it) at also 3500 pounds. The only other option is to look at vintage. They are cool but you have to be handy in most cases unless you buy already revamped. The concern with even the two newer units is that you are maxed out at GVWR with little to no give. Just be aware that you have to look at the GVWR weight on the trailer and the towing weight. The tongue weight on the 16' will take 446 pounds of your payload while the 17' takes 300 pounds from what can be hauled in the Edge. The maximum payload for the 2007 SE Edge is 1011 lbs. and the SEL is 1023 lbs. Also, according to Ford, even with the special equipped package, the max tongue weight is 350 lbs. which leaves only the 17' sport as a choice for you. You have about 700 pounds left for people and stuff - really close to limits.
Old 06-06-2012, 06:22 PM   #4
Naper's Avatar
Loretto , Ontario
F150 ( or any 1/5 ton pickup ) and a 25' Airstream is the perfect match.
Old 06-06-2012, 07:13 PM   #5
Chaps's Avatar
2011 19' Flying Cloud
2012 25' Flying Cloud
Lemoore , California
The 17 sport would look awesome behind your edge. If you have never spent time in an RV may I kindly suggest spending the night in a 17 before you make the purchase. :-) We started with a new 19' because of tow vehicle restraints and within 8 months bought a new truck and a new 25.' Yes the depreciation pinch hurt the old wallet but you know what they say, happy wife, happy life... Enjoy your search, some where out there is the perfect Air Stream for you and your family! Blessings, Chaps
Chaps is offline   Reply With Quote
Old 06-06-2012, 07:16 PM   #6
2004 16' International CCD
Orem , Utah
I do not see how Edge could do it
I am sure it could but would wear down edge. Now could it tow newer bambi 16 humm maybe with proper setup. 19 trailer is pretty darn cool I would not mind one those. But I really do like my 16. Now ford escape no way never
starcraft is offline   Reply With Quote
Old 06-06-2012, 07:28 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Kris,
I wouldn't tow an Airstream with a Ford on the Edge.
But go to CanAm in London, Ont. They can set up a Cub Cadet.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 06-06-2012, 08:21 PM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you bought an older AS you could tow it as they weigh less. But then you have to remodel and work on it and sink tons of $$$$ into it. It's a love hate relationship.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-06-2012, 08:31 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Buy the trailer you want, then get a tow vehicle to match it. You'll probably have the trailer through several tow vehicles, so match them up right to begin with.
Stephanie
Old 06-06-2012, 09:03 PM   #10
Wayward's Avatar
Cary , North Carolina
I agree with Bob. Call CanAm and see what they have for ideas. You might be surprised. There does not seen to be any reason an Edge could not be properly setup to haul 20 or so feet of Airstream.
http://img.photobucket.com/albums/v2...00%20width=250
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 06-06-2012, 09:10 PM   #11
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Originally Posted by Wayward View Post
I agree with Bob. Call CanAm and see what they have for ideas. You might be surpised. There does not seen to be any reason an Edge could not be properly setup to haul 20 or so feet of Airstream.
It would be quite a feat to go from 3,700lbs rated on the Edge to <> 7,300GVW on a 25 footer... I think you're looking to kill an Edge with that kind of weight unless it was for short, easy trips...
Friday is offline   Reply With Quote
Old 06-06-2012, 09:19 PM   #12
Wayward's Avatar
Well a 25 might be on the heavy side but a 22 FB Sport has an UBW of 3600 pounds. Even without CanAm's magic, that could be set up safely with an Edge.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 06-06-2012, 09:55 PM   #13
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
Towing a 25 footer with an Edge might be pushing it, but certainly give Andy Thomson at Can-Am RV here in London a call Can-Am RV Centre | New and Used Travel Trailers, Motorhomes and Fifth Wheels | Towing & Hitch Specialists | Top Airstream Dealer.
FWIW here's what they did for me and my Traverse recently, which has a similar power train as your Edge (unless you have the Ecoboost! )...
http://www.airforums.com/forums/f238...rse-91344.html
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
