Old 02-08-2013, 06:52 PM   #1
Newbury Park , California
Can an Audi Q7 tow a 23D?
Do you think an audi Q7 with a towing capacity of 6500 lbs can safely tow a late model 23D?
bunnyfamily is offline   Reply With Quote
Old 02-08-2013, 06:59 PM   #2
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
I would not do it. Gross weight on a 23D is 6000 lbs. Not much margin there
Old 02-08-2013, 07:06 PM   #3
Thx. I am so stuck on the towing capacity vs everyday gas mileage issue. Perhaps need to buy a third vehicle, like a truck.
Old 02-08-2013, 07:38 PM   #4
1972 Travelux Princess 25
Cobourg , Ontario
It will work if it is set up right. Can Am RVs in London Ontario is the expert on this type of setup. They tow that size Airstream with a VW all the time. Go to their web site and look at some of their videos and articles.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-08-2013, 08:07 PM   #5
cameront120's Avatar
1972 25' Tradewind
Talk to Andrew at CanAm (he's a forum member), he'll be able to give you all the information you'll need about your vehicle.
North Vancouver, BC
Old 02-08-2013, 08:26 PM   #6
Road Ruler's Avatar
Images: 38
Andrew T at CanAm (forum member) is the man you should talk to.
Old 02-08-2013, 09:40 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I thought you bought a 2012 Tundra last week?
doug k
Old 02-08-2013, 10:10 PM   #8
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
I'm still waiting for Andy T to open this type of vehicle modification in the states or mentor someone so we don't have to travel so far.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 02-09-2013, 10:04 AM   #9
Cobourg , Ontario
I think I can give you the basic Can Am formula from reading this web site and the Can Am site
Lower profile tires for stability and lower gearing. If your car came with 70 series, get 60. If it came with 60 get 50.
A good transmission cooler
A strong hitch receiver. Either custom built or a stock one reinforced. Most of the stock ones have an I shape. CanAm's are more like an H or possibly Y depending on under car configuration. I bought a standard hitch for my Ford and had a welder turn it from an I to an H by adding a cross bar as far forward as possible, about a foot, then connecting it to the original hitch in the middle. When he finished the job he remarked "you could tow a transport with that".
Keep the ball as close to the back bumper as possible. If necessary cut the hitch short and drill a new pin hole.
Finally you have to use a good weight distributing hitch and set it up carefully to equalize the weight on the trailer and tow vehicle, and don't go too stiff on the spring bars. The trailer and tow vehicle should sit level and the hitch be at the correct height for the trailer, etc.
This can take some time and experimenting with different settings. But once you have done it, it is easy to hitch up the same way every time. In other words it only needs to be done once.
Old 02-09-2013, 10:37 AM   #10
doug k
Good memory, Doug. Well when my husband went back the next morning to finish the paperwork they did the whole "oops price is higher switcheroo" so he got mad and left. Made us rethink everything...Now we are considering a touareg to pull a 23d instead of the audi.
Old 02-09-2013, 10:54 AM   #11
dkottum's Avatar
Jeep Grand Cherokee has just introduced a diesel model that has potential to be an Airstream towing favorite.
2014 Jeep Grand Cherokee| Fuel Efficient Luxury SUV | Jeep
doug k
Tow vehicle sag danlehosky Tow Vehicles 7 12-04-2011 09:18 AM
Need a truck to tow a 2007 16' Bambi rportillo Tow Vehicles 15 10-24-2011 01:48 PM
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
1/2 Ton Tow Vehicles brianw Tow Vehicles 39 09-08-2011 06:44 PM
Does NADA have any bearing on reality? International 23D smeghead Trailer Values 20 04-13-2011 01:18 AM
