Closed Thread
Old 04-19-2011, 06:25 PM   #1
Evergreen , Colorado
Can a Ford Flex tow an Airstream
We have a 65 Overlander which we normally tow with our 01 Excursion. We are looking to downsize our TV and are looking at the Ford Flex. Anyone had any experience with one as a TV? Skip
Nigel is offline
Old 04-19-2011, 06:35 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
With a MAXIMUM of 4500#...I doubt it. There is also a exposed frontal area restriction. How much does a '65 Overlander weigh fully loaded? I cannot tell by reading Ford's brochure whether there are any other weight restrictions imposed. I know in the past you had to reduce allowable trailer weight to allow for additional occupants and loading on the tow vehicle. My rule of thumb is 75% of the tow capacity for total maximum trailer weight, if it gets close I haul out the calculator.
Aaron
WBCCI #XXXX AIR #2495
wahoonc is offline
Old 04-19-2011, 07:18 PM   #3
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Nigel
We have a lot of customers who tow with the Ford Flex and the Ford Edge which has the same drivetrain. The 3.5 Litre has a very wide powerband which combined with the 6 speed transmission allows it to perform much better than the specs would lead you to expect. Handling is considerably more stable than the Excursion. Your overlander is very easy to tow and it should not be any problem at all.
One down side is that the factory hitch is not strong enough but it is a fairly easy one to strengthen. Which equalizng hitch are you using?
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 04-19-2011, 07:42 PM   #4
r carl's Avatar
Lin , Ne
With 355 hp and 350 lb.-ft. of torque, a 6 speed, and a high tech suspension you have a good start with what you need.
r carl is offline
Old 04-19-2011, 08:08 PM   #5
Road Ruler's Avatar
Images: 38
For sure r Carl.
By comparision this 327, 64 Impala would have had less power, only a 3 speed tranny, weak brakes and a shorter wheelbase to mention just a few of it's weaker specs.
Name:	chev impala 1964 1.jpg
Road Ruler is offline
Old 04-19-2011, 08:16 PM   #6
BeBop's Avatar
2000 27' Safari
Berkeley , California
But it's a '64 Impala! If you had that car, in that condition, you could sell it and buy any TV vehicle you want!
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline
Old 04-20-2011, 02:47 AM   #7
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Those are the Echo Boost numbers the natuarlly asperated model is 262 HP 248 Torque. The Echo Boost tows amazing since it is not using a lot of its power to pull itself but it is also quite a lot more expensive than the naturally asperated model which has more than enough power.
Andrew T
Andrew Thomson
London, Ontario
Andrew T is offline
Old 04-20-2011, 07:40 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Interesting thread for another Excursion owner. I do like the big monsta and the V10 is terrific, but since downsizing from 1980 31' AS to a 1966 26', this option sounds tempting. Would like to hear from someone who actually tows their 4000 lbs with a Flex.
this from Ford-
frontal area limitations = 35 sq. ft. With Trailer Tow Package Class III
Max towing weight 4500 and tongue load 450
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
ALANSD is offline
Old 04-20-2011, 08:11 AM   #9
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
I have an Excursion too, but I just don't feel comfortable towing with full or close to- the vehicle's rated tow capacity. Now, if I was going to just stick around FL where it's close to sea level and relatively flat, it probably wouldn't bother me, but I like mountains. I am certainly overkill on my TV, I'm sure. But there were other reasons to buy this vehicle for my situation (6 pets + Hubby... & stuff). However---My ultimate goal/dream is to find a 1956-57 Chevy Nomad. I think that would make an interesting combination with my Overlander.
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline
Old 04-20-2011, 09:02 AM   #10
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Yes. Yes you can. I've towed with several modern-day tow vehicles. The Flex/Lincoln MKT has been my favorite. Very stable, very quick and effortless with the Ecoboost twin-turbo.
I admit, my Minuet is a small and light trailer. But your vintage Overlander adds even more stability than my trailer from having tandem axles. The Overlander is also narrower than modern trailers and is fairly light overall. With a well-dialed-in hitch and a reinforced receiver, I know I'd tow a vintage Overlander with a Flex with no worries about stability or braking. (A Flex has a lot shorter stopping distance than your Excursion and handles much better.)
The frontal area prescription suggests that the limiting factor in the tow rating is powertrain cooling. This is typically tested climbing a steep grade in the desert at highway speeds with the AC full blast. So, if you're in a similar situation, you might have to dial things back some. That said, I've cruised at highway moving-with-traffic speeds while towing in 90 deg heat with this set-up and had no issues at all.
Tom
mutcth is offline
Old 04-20-2011, 09:49 AM   #11
Ottawa , ON
OOooOOoooo... And it looks so! nice, too!! Thanks for that photo.
Aage is offline
Old 04-20-2011, 10:40 AM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Yes that is a cool set up. I will have to add the Flex to my list for sure...
AIR #005
retired!
ALANSD is offline
Old 04-20-2011, 10:48 AM   #13
Road Ruler's Avatar
Images: 38
Thumbs up Test Drive
Tom
Looks good Tom. That Flex set up you have there would be one I'd luv to test drive. As you said though a dual axle Airstream may make the ideal combination for the Flex..
Old 04-20-2011, 11:08 AM   #14
mutcth's Avatar
2007 23' Safari SE
The dual axle would just make a good thing better - I have no complaints with the single-axle's behavior. Although now that you mention it, the DW and I would like a 23' Serenity...
Tom
mutcth is offline
Closed Thread
Who rents trucks to tow my 1962 Airstream Globetrotter? M Cordell Tow Vehicles 5 04-04-2011 10:36 AM
Airstream B-190 Motorhome, 1993 Ford E-350 Platform eBay Watch Airstreams on eBay 0 03-17-2011 04:30 PM
2007 Airstream Bambi Special Edition with 4 point tow eBay Watch Airstreams on eBay 0 02-09-2011 05:30 PM
55 Airstream Flying Cloud. Tow w/a car. Arrive in Style eBay Watch Airstreams on eBay 0 02-03-2011 07:10 PM
1955 Airstream Flying Cloud. Tow w/car. Arrive in Style eBay Watch Airstreams on eBay 0 01-23-2011 10:00 AM
