Closed Thread
Old 04-25-2011, 12:36 PM   #29
1985 31' Excella
Fresno , Texas
Originally Posted by Road Ruler View Post
For sure r Carl.
By comparision this 327, 64 Impala would have had less power, only a 3 speed tranny, weak brakes and a shorter wheelbase to mention just a few of it's weaker specs.
That car came with 327 and 409 engines. Horsepower was 250,300,340 hp on the 327 engine and 400,425 hp. for the 409 cu in.
Bad thing is they would have to have the carburetor adjusted to altitude while on vacation.
Wes
Wsmith is offline
Old 04-25-2011, 12:42 PM   #30
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Originally Posted by JFScheck View Post
Surprised no one here talking about the new Explorer since they are discussing the "Flex" - Explorer is simular frame - but can tow more, nice "Turbo-Gas" engine offering....
Explorer is rated to tow 500 lbs more. It doesn't offer the Ecoboost twin-turbo V6; it will only offer a 2.0-liter four-cylinder turbo with front-wheel-drive only. That won't be rated to tow much...
Tom
mutcth is offline
Old 04-25-2011, 02:37 PM   #31
Road Ruler's Avatar
Images: 38
Originally Posted by Nigel View Post
Everyone,
Thanks for some great input. Sounds like keeping the Excursion as a TV makes the most sense. We get about 14 mpg towing. The Flex may get about the same however we already own our Ex and would not have to buy another TV for 25k+. Nigel
I think there could be a good arguement for either choice, newer Flex/older Excursion. The vehicles are just so different. It just depends on the many, many, personal factors.
Road Ruler is offline
Old 04-25-2011, 02:41 PM   #32
Road Ruler's Avatar
Images: 38
Wes
"She's real fine, my 409".
Back in the late 60's a 4 door, plain jane, 64 Biscane rumbled up our local main street on a Friday night. I will never forget the sound of the engine.
Old 04-26-2011, 05:34 AM   #33
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
The Explorer has more rear overhang than the Edge and a shorter wheelbase than the Flex. Though it has a higher towing recomendation it would be the least stable of the three.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 04-29-2011, 02:07 PM   #34
JFScheck's Avatar
Rockville , Maryland
Images: 33
Yep -just checked - no current plans for Ford Eco-Boost V6...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline
Old 06-22-2011, 11:48 AM   #35
CallDon's Avatar
1986 Argosy
Dallas , Tech-Sus
Originally Posted by mutcth View Post
Yes. Yes you can. I've towed with several modern-day tow vehicles. The Flex/Lincoln MKT has been my favorite. Very stable, very quick and effortless with the Ecoboost twin-turbo.
Tom
Tom, what kind of MPG do you get with this rig? And what is the weight of your trailer??
Don
Life is too short. Do it NOW!!!
The Don Pod
Airstream FM
Easy Listening For the Internet Generation
CallDon is offline
Old 06-22-2011, 02:15 PM   #36
mutcth's Avatar
2007 23' Safari SE
Don, I got between 12-14 mpg when towing. I couldn't keep my foot out of the boost. The trailer weighs around 3200 lbs loaded.
I do better with my 2010 Honda Odyssey - 14-15 mpg towing the Argosy.
Tom
mutcth is offline
Old 07-27-2011, 09:45 AM   #37
Dag68's Avatar
1965 22' Safari
Shelter Island , New York
Images: 20
I'm excited to find this thread! I'm just closed a deal on a 2011 Flex Limited with Ecoboost (and the tow package) that I pick up on Saturday. I'm glad to hear people have such positive experiences towing with the Flex.
I've had my '65 Safari for almost a year and now, finally, I'll have a tow vehicle. I may have to take her out for a local drive, just because I can. She hasn't moved since last fall when I used a U-haul to pick her up and she's been quietly sitting since, as I renovate.
It looks like Mutcth and SafariGeorge are the guys with Flex experience. What equipment do you each use? What brand/model of Hitch, Ball, Brake Controller and Sway Control? Do either of you have the backup camera? I hear it makes hitching up a piece of cake.
For the Brake Controller I was leaning toward a Tekonsha Prodigy P2 (Proportional), in part because it is compact, removable and an easy install if I order the Flex connection cable. Anyone have any thoughts on the Tekonsha brand?
thanks,
Dag
Come on a (1965) Safari with me!
Dag68 is offline
Old 07-27-2011, 12:16 PM   #38
mutcth's Avatar
2007 23' Safari SE
I remember that U-haul pick-up thread! Glad to see that the Safari might hit the road.
I use a Eaz-lift weight-distributing hitch with a Reese friction anti-sway. My Prodigy P2 plugs right in - I spliced its harness into a Ford pigtail but like you said, you can get dedicated for-use-in-Ford cables for the Prodigy. No complaints about any of it.
The Flex has a good backup camera with a nice big screen (the Limited I used had navigation) and a black line right on center - it's really good for lining up the ball.
Tom
mutcth is offline
Old 07-27-2011, 11:35 PM   #39
Dag68's Avatar
1965 22' Safari
Images: 20
Thanks, Tom
I looked up the Eaz-lift weight-distributing hitch and Reese friction anti-sway. Looks like quite a lot of hardware and very solid. Any chance you have a picture of that rig set up?
Dag
Dag68 is offline
Old 12-07-2012, 07:03 PM   #40
Dayton , Ohio
Hey there, I have a flex and will soon be an Airstream owner. I've been doing a ton of research on this issue. The good news, according to Ford, if you are within your weight limit and using the class III set up they recommend it's doable. The frontal area question really worried me since there are conflicting details on the net about how to calculate. So, I called Ford today, and after about three tranfers I got to the right person. I wanted to know what does Ford mean when they mention the 35sq ft limit for frontal area. They said it is the height of the object being towed that is greater than the tow vehicle. The model Airstream I plan to purchase is a 1960s 26ft overlander that specs at about 3200lbs. The width of the flex is the same as this older model, 88 inches. The flex is 68 inches tall and the overlander is 107 inches tall. The height difference is 39 inches. I used a sq footage calculator, and it comes out around 23 or 26sq ft. Can't remember the exact end number, but I did it over the phone with Ford, and it was well under the limit. I'm feeling pretty optimistic about my plan. Ford also noted that a trailer that's curved is even better! Good luck with your research.
Yostella1963 is offline
Old 12-07-2012, 07:58 PM   #41
Ottawa , ON
The EcoBoost V6 they put into the Flex is the same EcoBoost they put into the F150, isn't it?
Aage is offline
Old 12-07-2012, 08:14 PM   #42
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Not really. It has a limit of 4500lbs for towing and 450 or so lbs for tongue weight. The wind resistance rating is 35 sq feet.- think motorbike trailer or small utility trailer. Its purpose is a people hauler crossover - car framed vehicle. They are beautiful but not haulers of heavy things. The lightest Airstream (2013) is 640 lbs tongue weight and 3500 lbs. Although the towing capacity meets requirements, the tongue weight, even with the WD hitch, does not.
It is not just the engine but the drive train, frame, etc.
rodsterinfl is offline
Closed Thread
Who rents trucks to tow my 1962 Airstream Globetrotter? M Cordell Tow Vehicles 5 04-04-2011 10:36 AM
Airstream B-190 Motorhome, 1993 Ford E-350 Platform eBay Watch Airstreams on eBay 0 03-17-2011 04:30 PM
2007 Airstream Bambi Special Edition with 4 point tow eBay Watch Airstreams on eBay 0 02-09-2011 05:30 PM
55 Airstream Flying Cloud. Tow w/a car. Arrive in Style eBay Watch Airstreams on eBay 0 02-03-2011 07:10 PM
1955 Airstream Flying Cloud. Tow w/car. Arrive in Style eBay Watch Airstreams on eBay 0 01-23-2011 10:00 AM
