Old 03-18-2008, 11:25 AM   #1
LucyPepper's Avatar
1975 27' Overlander
Salt Lake City , Utah
Wink Can 98 Toyota Pull a 64 Tradewind?
Hi,
I am so excited to find this forum. My boyfriend and I just decided to seriously downsize our lives and buy an airstream to travel and live in this coming summer over to the west coast (Highway 101) Any good spots to park or boondock you would suggest?
We are newbies, and are still learning the ways. We are looking for an airstream now, but are concerned on what would be a good option for the 98' Toyota 4-Runner that we have to tow the beauty. We found a 1964 24ft. Tradewind, with a dry weight of 3500lbs. Will the truck be able to handle this size once all of our stuff is in there? The max towing weight for the vehicle says 5000 lbs. I believe in the manual.
Also, what are the most crucial aspects to look for when buying a vintage airstream?
Any wisdom or advice is much appreciated.
thanks!
LucyP
LucyPepper is offline   Reply With Quote
Old 03-18-2008, 11:36 AM   #2
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
Toyotas
We are a Toyota family, and I would NOT use a 4-runner to tow.. it has a very short wheelbase.
We have a 1998 Tacoma, a 1987 Van-Wagon, a 1992 Tercel and a 2002 Tundra.
Nothing has towing ability except the Tundra, which we LOVE.
I'm just a pink flamingo on the great lawn of life :-)
flamingo-kid1 is offline   Reply With Quote
Old 03-18-2008, 11:49 AM   #3
austin , Texas
Toyota Tacoma TV
Hello, Lucy Welcome to the forums! See my post Totota Tacoma TV. I asked a simular question, and you may find helpful, some of the responces I recieved! There are some very exp people, willing to share their wisdom. And I wish you luck in your search! Peace.... Red Rover^^^
Red Rover is offline   Reply With Quote
Old 03-18-2008, 11:54 AM   #4
Darol Ingalls's Avatar
Lucy, DON'T believe in the manual. Your 4-Runner may be able to pull 5000 lbs dead weight across the parking lot, but put a 24' Tradewind loaded with "living" load and you'll wish you hadn't especially considering where you want to travel. The Tundra V8s will do just fine. Longer wheelbase and adequate power. Or you might consider a good used full-size 1/2 ton pickup. In any case, be sure you use a good hitch system and sway control. Darol
Darol Ingalls is offline   Reply With Quote
Old 03-18-2008, 12:23 PM   #5
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Considering you have the truck, and have only found the trailer, maybe it's easier for you to look for a much smaller trailer, instead.
bredlo is offline   Reply With Quote
Old 03-18-2008, 12:27 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm kind of on the ropes with it too. If I had to vote on it, I'd have vote no and agree that you either get a better tow vehicle or go with a 19' or smaller.
Old 03-18-2008, 01:12 PM   #7
SteveH's Avatar
Common Sense , Texas
I agree with everyone else on the subject....the Tacoma may be able to move it, but it is my opinion you will not be happy with it, it won't be an enjoyable journey, and it may not even be safe above about 30 miles an hour. You need either a bigger truck, a smaller trailer, or both.
Old 03-18-2008, 01:30 PM   #8
Midamrail's Avatar
1975 Argosy 26
Villa Ridge , Missouri
We had a 1964 Tradewind with the single axle (double axles were an option that year and standard the next), and our 3/4-ton trucks barely knew it was back there except...it hopped a bit, even fully hitched with the weight distributing and sway bars. In some respects, it was a bit more squirrelly at times than our big 31' Sovereign, even with a brand-new axle and new tires and wheels. It was a breeze to pull with the long wheelbase trucks, but I would not have felt comfortable pulling it with a shorter-wheelbase SUV like the 4Runner. We definitely felt the "hopping" more with the straight-cab truck than we did with the extended cab or crew cab trucks, and the straight-cab still has a longer wheelbase than the 4Runner.
The PO pulled it with a Crown Victoria, but the lower center of gravity may have helped that set-up, and he traveled light - one person, very little packed in the trailer.
Both Alex, my Argosy, and I are kids from Versailles, Ohio!
Midamrail is offline   Reply With Quote
Old 03-18-2008, 01:48 PM   #9
1967 28' Ambassador
Rockford , Illinois
towing
Don't forget this part:
a truck with a tow package has a transmission cooler.
A truck withOUT that can burn up from simply wind resistance.
A (much) smaller trailer coudl probably be pulled with a 4-runner.
Old 03-18-2008, 02:12 PM   #10
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Lucy P!
Welcome to the Forums!
As several others have indicated, I would tend toward the "not a good match" in this situation. When loaded for a trip, the TradeWind would be in excess of 80% of your Toyota's rated tow capacity. If you don't wish to consider a different tow vehicle, Argosy did manufacture a line of coaches that may be more compatible -- they were the Minuets (1977-1979). The Minuets were designed to be light weight and only a bit more than 7' wide -- they make a better match for a narrower tow vehicle. The 6.0 Metre Minuet has a GVWR of 3,250 pounds (approximately 20') while the 6.7 Metre Minuet has a GVWR of 3,750 pounds (approximately 22') -- the largest Minuet, the 7.3 Metre has a GVWR of 3,850 pounds (approximately 24'). In 1980, Airstream manufactured a series of similar coaches under the Caravelle name -- they are a bit wider and heavier as well.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 03-23-2008, 04:30 PM   #11
LucyPepper's Avatar
1975 27' Overlander
We found a Diesel truck instead.
Hi Everyone!
Thanks SO much for your wisdom. We talked to some local new AS dealers here in town, and your knowledge was much more detailed and useful! Thanks! We ended up getting an 85 Ford F250 that is in immaculate condition for it's year. I feel like we should be good now to pull a 25-27ft. AS now. Thanks!!
LucyP
Old 03-23-2008, 04:35 PM   #12
1967 28' Ambassador
Rockford , Illinois
Originally Posted by LucyPepper
Hi Everyone!
LucyP
I want to see a picture of that!!!!!
Old 03-23-2008, 09:01 PM   #13
LucyPepper's Avatar
1975 27' Overlander
The 85 Truck to pull our first AS
Here is the 80's vintage beaut that we just bought.
Old 03-23-2008, 09:11 PM   #14
1967 28' Ambassador
Rockford , Illinois
boo hoo
I can't see the picture :-(
Toyota RAV 4-V6 pull 16-ft Bambi? Skye Nomad Tow Vehicles 11 12-31-2007 06:47 AM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 06:10 PM
pull your battery yet? john hd Batteries, Univolts, Converters & Inverters 0 12-02-2004 08:12 PM
Pull out bed jgump Cabinets, Counter Tops & Furnishings 0 10-28-2004 07:44 PM
New Pull Vehicle Steph Our Community 1 09-07-2003 07:53 PM
