Old 08-12-2010, 09:49 PM   #99
Richie O's Avatar
o , Maine
I am a 6B cummins fan. I own 3 of the 1st gen dodges ( 89 to 93 ). They are simple and run a long time. I also have a LLM Dmax that is a work truck. These trucks ( all 3 makes ) have so much power now the drivelines are at risk even with a stock tune. The cummins was a non electronic engine up to 1998.5 when they switched to the 24 valve. After that there were some injection pump issues with the VP44 style pump. Mostly due to lift pump issues. Some of the 24 valvers also had the " 53 " casting block that were noted to cracking under the exhaust manifold. In my eyes its hard to beat the old style simple trucks. Just like everything else they all had there weakness. As you guys can see I know some about trucks,,, but VERY little about these little round campers. Just joined to read up in hopes of maybe someday fixing one up.
Keeping eyes open for a project. ( like I need another hobby )
Richie O is offline   Reply With Quote
Old 08-12-2010, 10:16 PM   #100
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by xonvldz View Post
listen to powerstrokehelp.com
Thanks xonvldz.
For those of you who haven't already visited this site, there are some interesting videos at Powerstrokehelp.com. I haven't watched them all yet, but from the ones I have seen I'm getting a better understanding of how this engine works and it's strengths and weaknesses.
Another good resource is the coffee table books at FordDoctorsdts.com
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 08-13-2010, 02:55 PM   #101
Silverfoxrae's Avatar
1957 26' Overlander
Saint Augustine , Florida
Images: 45
Back again... I recently had a problem with the Excursion. First, I was told I needed to replace the turbo, which I did, but continued to have the same intermittent problems. I eventually had to change shops because the one shop wasn't interested in trying to figure things out, even though the water in fuel light kept coming on. Turns out that I had a very bad fuel contamination issue. I am lucky that I didn't blow my injectors. Now I am paranoid, and re-reading what I can and learning more about what to do- proactively. Hopefully I can stay ahead of the problems, and run well on my 2004 6.0 :-)
Rae
Metallicised.
AIR # 42703
TCT Member
TAC # FL~6
WBCCI # 1464
'57 Overlander thread:"the end of the rainbow is silver"
Silverfoxrae is offline   Reply With Quote
Old 10-24-2010, 08:45 PM   #102
1964 26' Overlander
Milton , ON
By-pass filters
Finally got the by-pass coolant and oil filters installed.
I welded a bracket and bolted it onto the alternator mount. The bracket shown in the photo is not the final version. It seemed a little too flexible, so I added another piece to stiffen it. This can be seen in the first picture.
It took a lot of experimenting to get both filters to fit and allow room to change the filters. Having the bracket angle back toward the driver's side made a big difference.
One of the challenges was figuring out if there was enough vertical space between the filter mount and the hood. The crushed pop can shows the clearance.
ID:	113949   Click image for larger version
ID:	113951   Click image for larger version
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 10-25-2010, 03:19 PM   #103
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Originally Posted by DavidsonOverlander View Post
Hi Marvin,
How did your upgrades go? Did you install all this yourself, or have someone else do it? Feel free to drop in anytime you're going through Milton. I'd like to see what you've done with your truck.
I can't afford everything you're doing right now, but I'm starting with the coolant filter and would like to do something about the EGR.
Grant
Hi Grant, Sorry I didn't see your post. All the work is done and cost around $5000.00 I had it done at a Ford dealer in New York that was recommended on the Bullet Proof site. They didn't take the cab off just the fenders and rad. support. It is a 30 hour job by the book. Everything is good now, I still have to get the 4 inch exhaust and cat done.
To the Dodge boys posting on here. That Cummins engine is a real good engine, it is just to bad they had to put it in a Dodge.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 10-25-2010, 03:25 PM   #104
1979 30' Argosy
Grant, I forgot, if you want to do anything with your EGR cooler replace it with a Bullet Proof one they won't plug and it is better than deleting them.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 10-25-2010, 03:32 PM   #105
Carson City , Nevada
I have owned two Ford diesel trucks - 1986 6.9L and my current 2001 7.3L PS. No problems at all.
I heard so many horror stories about the 6.0L trucks that I searched out a low mileage 7.3L. Nice truck that does 19 MPG driving and 12-13 towing my AS.
Mike S is offline   Reply With Quote
Old 10-25-2010, 03:46 PM   #106
1979 30' Argosy
I believe like Stingray said at the beginning of this thread that the 6.0 is a good engine. It is just that Ford has known all of its proublems and didn't do anything about it. International put the coolant filters on all of their trucks to filter the sand, a real simple and easy fix. I didn't know that you had to get an extended warranty before 60,000 miles. I bought it with 30,000 miles and checked on the warranty at about 65,000 and they wouldn't sell me one. When I started having these proublems I had about 400 miles over the warranty, I took all my receipts to the dealer here and told them that they knew they had a problem with this engine and they should do something. He called Ford and they said they would pay half the cost so I said ok can I use the parts I want to at my expense and they said no deal, all Ford parts or no deal. So I left and took care of it myself.
Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 10-25-2010, 04:29 PM   #107
r carl's Avatar
Lin , Ne
This is yet another recall ford got out of...
Old 10-25-2010, 05:41 PM   #108
1964 26' Overlander
Milton , ON
Marvin
Thanks. That will probably be my next purchase, but not likely until Spring. I was hesitant to delete it in case it made a difference on the Drive Clean test.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 10-26-2010, 06:44 PM   #109
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Thanks xonvldz.
Not a bad video. Makes me happy that I bought an 2007. I'm sitting on 110,000 miles in three years now, 80% of which is towing, and I have yet to take it in for any repairs.
Oddly enough, I was afraid to buy a 6.0 but a close friend that is general manager of the local Dodge dealer advised me to buy the 6.0 over one of his because of all the problems they were having getting the 6.7 Cummins to run right at that point in time. He is close friends with the other dealer managers for Ford and GM and they all share their horror stories.
Of course he reminds me now on a regular basis that they have finally ironed the bugs out...
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 11-17-2010, 05:55 AM   #110
2007 31' Classic
holland , Pennsylvania
now that my truck is over 80000 miles it seems to be getting broken in.just towed back from fort wilderness in orlando keeping the diesel wound up and trying to avoid bogging the motor.with some miles before i started for home i drove 1140 miles on 74 gallons of diesel.my truck is completely stock and all i am using is stanadyne performance formula on every tank.i think the success with these trucks is to keep up on the maintenance and run them as often as you can.these diesels love to work.
xonvldz is offline   Reply With Quote
Old 11-17-2010, 06:03 AM   #111
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Mike S
I have a 2000 F250 7.3. love it. but I am scared of the tranny. .....................Sal
noreen&sal is offline   Reply With Quote
Old 12-15-2010, 10:47 AM   #112
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Wow, great feedback from my original post; I'm glad I could help.
I spend a lot of time on the Diesel Stop website, getting great information from the guys there. One of the things I've learned is that, while the information from the powerstrokehelp.com guy may have been good at one time, parts of it are outdated, so I would be hesitant to follow all of his advice.
I did get some great info from a guy on Powerstroke.org, via the Diesel Stop. Here is what he wrote:
"Here is the deal with the 6.0: Any good tuner (person writing your tunes) is not going to give you a tune that is going to tear up your truck. There are trucks all over the place running 400-420 rwhp with 750-800 rwtq all day long without problems.
Yes, the 6.0 is known to blow head gaskets. This is how it happens: The Ford Gold coolant contains silicates. These silicates are not able to handle high EGT's generated by a good load or relatively high boost, when run through the EGR cooler. They break down into a gel-like sludge and fall out of suspension. This crud gets caught up in the tiny coolant passageways of the oil cooler. As the cooler clogs up, it restricts coolant flow to the EGR cooler; the EGR cooler doesn't have enough coolant to carry off the heat generated by high EGT's; the limited amount of coolant in the EGR cooler flash boils, causing high pressure in the cooling system, and the truck pukes coolant from the degas bottle due to the pressure…it has to go somewhere. The Power Stroke owner is not monitoring coolant temps and oil temps, so he/she doesn't know what’s going on, and he/she keeps driving it this way. The problem gets worse; the pressure causes the EGR cooler to rupture. Now the EGR cooler is leaking coolant into the intake manifold, which then runs into the cylinders. Again, the high combustion temps cause the coolant to vaporize, causing unacceptably high cylinder pressure; the TTY head bolts stretch due to the additional pressure and there go your head gaskets.
Ok now you know the problem. Here's the cure: Get a good engine monitoring solution like the Edge Insight, so that you can monitor your ECT and EOT. If those temps get more than 15* apart, at normal cruising when at normal operating temperature, your oil cooler is clogging up. Rebuild it now, to prevent all that down-stream damage from occurring. Flush that Ford Gold coolant crap out of your engine with a couple bottles of Fleetrite Restore. This is made specifically to clean out that silicate residue. Now refill it with a silicate free Cat EC-1 rated ELC coolant and add a coolant filter; Dieselsite sells a kit, which you can install yourself quite easily. This removes the silicates that clog the oil cooler from the equation. If you live in an area where you don't have smog inspections delete the EGR system. If you can't delete it replace the EGR cooler with the cooler manufactured by Bulletproof Diesel. This is vastly superior to the Ford OEM EGR cooler and it will not fail on you. If you find that you need to replace head gaskets replace the TTY head bolts with ARP studs and use black onyx (Victor Reinz) head gaskets. If you have to replace the EGR cooler always replace the oil cooler. That is the source of the problem.
Now that you have addressed the common problems that scare the hell out of people, get an SCT tuner (i like the X3) and install some custom tunes and drive the heck out of it. DO NOT baby it. The Power Stroke hates this and will rebel with turbo issues.
Turbo issues are also common repair points with the 6.0. People like to complain that it's because the VGT turbos are pieces of junk. This is not so. The VGT vanes in the turbo need to be exercised regularly. This means making them go through their full range of motion. So put your foot in it regularly and let it see some full boost runs. That will keep your VGT vanes from getting all sooted up and freezing up because of the soot. Again, that is what happens when you baby it. Put your foot in it and you will have fewer problems. If you keep your foot off of it and try to milk it for mileage like you would a gasser, you're going to have turbo issues. Don't let it sit either. That is also the kiss of death to the turbo. The unison ring rusts up and again you have turbo problems. So now that you know you need to give your turbo a regular work out to keep it happy, give it a proper cool down as well. Just whipping into your parking place and shutting it down will lead to coking the bearings and, again, you will have major turbo issues. Running good synthetic oil will help here immensely because it handles heat so much better and resists coking. But always let your turbo have time to cool down. This is one of the reasons you need a Pyrometer (EGT gauge), Let the EGT come down to 350* before shutting your truck off. This only takes a couple of minutes, especially if you take it easy on it for the last couple minutes of your trip. If this is too much hassle for you get a turbo timer that will automatically delay shutdown when you turn off the key to allow the turbo to cool down.
Injectors – Ford’s injection system (HEUI) fires the injectors with high-pressure oil, to the tune of 4,000psi, at Wide Open Throttle. Maintenance is critical here, so you cannot let your oil changes slide like you can on a gasser; it will kill your injectors. The injectors are also known to suffer from something that we call stiction. That is when the oil side spool valve of the injectors hangs up or sticks when cold until the truck warms up. I believe this is caused by varnish buildup that is common to dino oils, especially those containing paraffin. Using good synthetic oil will take care of that, because it actually cleans the engine as it lubricates. If you do find yourself with some injector stiction, add a couple of bottles of Rev-X to your oil; Innovative Diesel carries it. It has cleared up 99.9% of the trucks it has been used on. 2 bottles run around $70. A new injector is about $250-$290. Be anal about keeping your oil clean and fresh and changing your fuel filters regularly. The other thing that kills injectors is low fuel pressure. The fuel pressure needs to stay above 45psi at all times and is typically set around 52 psi from the factory. The factory fuel pressure regulator spring is weak and loses its tension over time and can't maintain adequate fuel pressure. There is an updated rebuild kit that uses a better, stronger spring. Installing this spring will bring your fuel pressure up to about 62 psi and solve that. Get a fuel pressure gauge; it's important.
That covers the frequent complaints with the 6.0, which are all well known at this point as are the solutions. Does it suck we have to fix Ford's blunders? Heck yes it does. But, again, we know how and once done you will have a very reliable robust truck that is well worth the effort. Address the issues as you can and enjoy your truck. It is a dynamite vehicle. I love mine."
The bottom line is don't believe everything you read or hear; do your research, come to your own conclusions and then pull the trigger on the repairs/modifications you want to make to your 6.0 to make it more reliable/safer.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Calling on all Argosy Minuet Owners COArgosy78 All Argosy Trailers 252 08-14-2017 08:20 PM
Calling all 1970 owners robandzoe 1970 -1973 Ambassador 3 03-20-2012 10:29 PM
Calling all FB Twin option owners... yakman General Interior Topics 4 09-03-2008 11:16 AM
!!Warning for Ford PSD owners!! Blu_Hwy_Lady Tow Vehicles 21 09-21-2006 10:41 AM
Calling all Duramax/Allison owners Silvertwinkie Tow Vehicles 31 10-04-2004 05:19 AM
