Old 02-09-2014, 01:54 PM   #43
Gainesville , Florida
I understand the powerestrokes had problems the the duromax and cummins did not. Now the new ford diesels are much dif. Jim
Old 02-09-2014, 02:12 PM   #44
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
In my experience the Fords and Dmax have head gasket and turbo issues, the Cummins issues seem to be more with lift pumps causing injector pump failures.
The Cummins failures are mostly preventable, the other brands not so much.
The Fords equipped with the last generation of International engines have a slew of electronic control issues and injector problems that even dealers can't seem to fix for more than a month at a time... Add to this injector failures...
I like Fords, but the simple truth is that Ford unloaded a bunch of crap at premium prices and they never did make it right.
Dmaxes are better, but not a lot.
Old 02-09-2014, 04:45 PM   #45
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Originally Posted by TinTin View Post
Your new TV should prove to be a good match for your AS. The current price differential for diesel should be erased by the better mileage you'll achieve!
Just want to say ...."Ditto"
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 02-09-2014, 07:01 PM   #46
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by r carl View Post
Can't argue that the Dodge Cummins powertrain isn't good, but the rest of the truck is a POS.
That's an interesting observation. I have owned my dodge since new in 2003. I have had nearly zero problems with it. (No work done except required maintenance).
Could you please expand on what bad experiences you have had?
Ken
Old 02-09-2014, 07:55 PM   #47
Grrrwolf's Avatar
1977 31' Sovereign
Overland Park , Kansas
I'm happy with the power and quality (nearly out of warranty) of my 2012 1500 Ram but I'm starting to think the 3.0L diesel is more of a unicorn than a Ram. Do these have to be special ordered? That I will never do. Out of hundreds of Rams in my area, none have the small diesel.
I won't be paying sticker for anything much less something I can't test drive. I'm just hoping to find one within the next few years once the novelty wears off.
Grrrwolf is offline   Reply With Quote
Old 02-09-2014, 08:39 PM   #48
Ag&Au's Avatar
Ken
Never mind, R Carl. I just noticed your signature line.
Ken
Old 02-09-2014, 10:56 PM   #49
mefly2's Avatar
2015 25' FB Eddie Bauer
We would not go back to our F150 Triton after the Ram diesel ...PERIOD.
Old 02-10-2014, 07:16 AM   #50
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Originally Posted by hickory View Post
I don't care what everyone else drives. I love my Cummins powered Dodge and it is hardly a POS. Just because you don't like a vehicle doesn't mean it is a POS.
Grow up.
Hickory
I'm confused: doesn't "POS" mean 'Perfectionist's Only Solution?'
SeeMore is offline   Reply With Quote
Old 02-10-2014, 08:09 AM   #51
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by dznf0g View Post
Skater, I think you're a bit low on the gas mileage. At least today's engines.....I get, pretty consistently 9 - 9.5mpg while towing and a loaded truck. AS=9000lbs and about 600lbs in the bed. This has been whether I was using a 5.3, a 6.0 or a 6.2 litre.
Okay, so it turns out I screwed some things up when I went from memory. For fuel costs alone, the gas engine is cheaper to operate when you're getting above 9 MPG, if the diesel gets 11 MPG - 35 cents/mile diesel and 34 cents per mile gasoline at 9.5 MPG.
The per-mile cost including the cost of the engine and more expensive maintenance is 41.92 cents/mile for the diesel and 34.84 cents per mile for the gas, assuming you tow 250,000 miles. So the gas is cheaper for the long term, too. Note the per-mile cost drops for the diesel as you drive more miles (because the engine is a fixed cost), but they don't equalize even at 1,000,000 miles. And I suspect anyone getting that many miles out of their truck is going to be thrilled, gas or diesel, so I didn't bother finding the actual break-even point.
These calculations are already out of date, of course - the fuel prices have changed since I first did it, if nothing else.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 02-10-2014, 08:17 AM   #52
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
The used vehicle market has been crazy for the last 2 years with top prices being paid by dealers at auto auctions around the country.This is due to the low volume of used vehicles being made available.Make sure to get prices on a new vehicle of choice as there may not be as big justifiable of difference in price between new and used.
Old 02-10-2014, 09:28 AM   #53
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Unless your driving 70 , 11 mpg is pretty low for a diesel. We averaged 11 with 28 ft toy hauler and easily 12.5 to 13 with 25 AS at 60-62..
Sent from my Nexus 7 using Airstream Forums mobile app
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 02-10-2014, 11:39 AM   #54
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We can argue the specific numbers all day, but it definitely seems like it's close enough to essentially be a wash, except for the cost of the engine. 11 is pretty normal for us; either we're doing 65-70 mph when traffic and weather permit, or we're stuck in a traffic jam, or we're climbing hills, and none of those are great for fuel mileage. Sure we could do better by going slower or choosing flatter routes, but it makes sense to compare numbers on what we're actually doing, not what we COULD be doing.
Old 02-10-2014, 11:54 AM   #55
jrudd1968's Avatar
2005 31' Classic
2005 31' Classic
Douglass , Texas
Images: 12
Towed with both: Dodge 1500 gasser & 25' Airstream Safari. It struggled in the Rocky Mountains of Colorado. Dodge 2500 Cummins & 31' Airstream Classic.
Went anywhere in the Colrado Rockies I wanted to and even picked up speed going up hill when I needed to pass a gasser! Great combination for traveling anywhere in US & Canada!
James Rudd
2001 25' Safari
2003 Dodge 2500
jrudd1968 is offline   Reply With Quote
Old 02-10-2014, 01:03 PM   #56
Rot-Roo Rastro!!
silversled's Avatar
2000 30' Limited
No matter the fuel: If the used truck comes with integrated brake controller built into the dash, be sure it can communicate with your Airstream brakes. Some Airstreams braking systems are digital and some analogue. There are aftermarket solutions but they defeat the purpose of an integrated tow package that came on the truck and can be an added expense.
Astro & the humans I train Barry&Andrea
2000 Airstream Limited 30' ~ Silversled
2005 Ford Powerstroke, 4X4, Crew Cab
AIR #12075
silversled is offline   Reply With Quote
