Old 08-14-2009, 06:37 PM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
'burb 'bucks' and slips under load
2005 Suburban 2500, 4x4, 8.1, LT, 60k miles... Around town, no problem... drives fine... About a month ago, started hearing a 'buzzing' from undercarriage. Sounded a lot like a loose heat shield on muffler, so I disregarded for the time...
Last week hitched up for an extended trip east... 20 minutes on secondary roads under 45mph was fine... but after getting on freeway, and cruising at 65mph (speed control), truck started to 'buck', then RPM's spun freely up to redline... I switched off cruise, and coasted for 4-5 seconds, then gassed it, but engine reved like it was in neutral... shifted into 'N', then back to 'D', tranny seemed to engage OK... 55mph to the next exit about 5 minutes up... drove home... again, no problems on secondary roads...
My mechanic looked at it... said it sounded like clutch plates were gone... swapped out remanufactured tranny. Brought home... hitched up... drove secondary roads- no problem... no rattle... get on highway- same thing... identical problem... buck... buck... reevvvvvvvv...
Mechanic is stupefied.
Is my trust in my mechanic misplaced?
Could there be a tranny 'computer' problem?
Anybody??
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 08-14-2009, 06:45 PM   #2
Liquid Cooled
RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
I'd guess - and it is a guess - transfer case. Are there any codes?
Reasoning is this:
If it was the harness, the system should be able to self diagnose that there was an intermittent connection to the PRNDL (or gear lever if you'd rather) and you'd get a code. Also, that shouldn't make any noise.
However, if the transfer case was acting up, the trans controller might go into a self-preservation mode and disengage. I'd think there'd still be a code, though, but maybe not.
RedSHED is offline   Reply With Quote
Old 08-14-2009, 06:47 PM   #3
Dearborn , Michigan
Images: 21
no codes.. no engine light
Old 08-14-2009, 06:59 PM   #4
Dearborn , Michigan
Images: 21
I got Bender troubleshooting... he he
j/k, I really appreciate the help
Old 08-14-2009, 07:03 PM   #5
Liquid Cooled
RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
I still wouldn't rule it out. The check engine light is only required for emissions purposes, and technically the trans doesn't affect combustion.
Thinking about it, I can imagine a scenario where there are no codes. I don't know how the transfer case is engaged or disengaged, but I'm guessing there's a wire harness that winds up down there. Possibilities would include a flaky connection, which could be diagnosed and resolved by disconnecting devices from the harness, looking for corrosion or deformation, and reconnecting. It's been 15 years since I've messed with modules on a GM product, and that was during development, so I can't offer too much help, I'm afraid.
Maybe call Click and Clack in the morning
[edit: Bender doesn't mind. He consults with the knights who until very recently said "ni."]
Old 08-14-2009, 07:17 PM   #6
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
I had a problem like that with my 99 1/2 ton 2 wd it turned out to be a crank position sensor no check engine light just alot of bucking and jumping around rpm gauge going crazy too...SAM
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 09-02-2009, 12:22 PM   #7
Dearborn , Michigan
Images: 21
update: transfer case actuator was 'binding'... it was not fully engaging the 2HI gearset, and it would bounce out and in. actuator won't throw any codes.
RedSHED- right on the money. next time I'm PM'ing u first...
Old 09-02-2009, 04:30 PM   #8
Liquid Cooled
RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Bender said something about his shiny metal...
Thanks or you're welcome. Glad you got it figured out.
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Extended Warranty on my new to me Burb? SaabLover Tow Vehicles 7 11-16-2007 06:30 PM
Burb Silverado to tow a 65 Overlander kdenault Tow Vehicles 4 07-06-2006 07:52 PM
The right match for a CCD 28 - 1/2 ton Burb nangoff Tow Vehicles 40 09-29-2004 12:29 AM
What to look for in '98, '99 Burb Sav'h Steve On The Road... 5 08-17-2003 09:49 AM
