Old 05-27-2014, 10:41 AM   #1
2003 28' Classic
Ladysmith , Wisconsin
Bull dogging ?
Name:	ImageUploadedByAirstream Forums1401208822.062297.jpg
F-150 2012 Eco boost. Think she needs further weight distribution adjustments. This is without the 150 lb honda generator in truck bed less 2 passengers and a unloaded trailer.
JacobMerridy is offline   Reply With Quote
Old 05-27-2014, 11:58 AM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Need to make a trip to a scale
Originally Posted by JacobMerridy View Post
Attachment 212973
Best to make a trip to a scale, record each axle (the four tires on the AS count as one axle).
Post here as to the front truck axle, rear truck axle, and the AS.
Repeat with truck alone, and then AS alone (hitch and combined axle weight.
Please post the info from your driver side pillar - max rear axle, max front axle, and max combined.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-28-2014, 12:05 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Your 'goal' is 'level tow' for truck and AS.
Here is how.. Initially, find a LEVEL spot. It is ok if it slopes a bit.. but needs to be straight level as possible. Measure the bow and stern beltline to the ground. Do same for truck at fixed points like the upper edge of the wheel well.
Now, hitch up and recheck the levels. Adjust your WD bars so that the truck squats identically at bow and stern. If AS is Bow Low, you need to raise the ball on the truck.. of course you will need to recheck the WD bars to make the truck 'squat' identically at it's bow and stern (top of wheel well openings).
The result should be level AS, or just a TAD bow high(up).. like 1/4" above 'level'. Truck 'squat' is equal front and rear.
If AS is bow 'low', you will have towing issues.. same if too high. This is where you get the trailer weighed and ensure you are within specs on the axle loads.. The rear axle should carry more weight than the front.
Rotate your tires regularly to spread out the wear..
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-01-2014, 06:45 AM   #4
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Add a set of Firestone air bags, you will like the results.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 07-04-2014, 10:23 AM   #5
Thanks Pappy for the tip. Looking into the Firestone Air Bags for my 2012 F-150
MikeMollet is offline   Reply With Quote
PIT BULL on YOUTUBE 345bill The Pet Forum 0 09-06-2011 01:26 PM
Pit Bull vs Homeowners Policy 345bill The Pet Forum 66 08-14-2010 10:08 AM
The Bull in the China Shop Heirstreamer Off Topic Forum 15 08-04-2008 10:08 AM
Red Bull Air Race airedale Off Topic Forum 5 04-19-2008 06:44 AM
Red Bull Airstream Moonshot Our Community 3 03-20-2005 08:11 AM
