Old 03-06-2012, 08:14 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Towing puts a lot of strain on a vehicle, more than racing. It'll find all the weak spots where components and/or systems are old & tired. A thirty-year old SUV is not, IMO, the way to go.
A turbodiesel SUV is the TV to which to compare all others when starting from scratch. The default comparison. While a half-ton truck appears to be from a conventional starting point, an Airstream has the advantage of it's design over the SWB's.
Choose the TT first. Check weights. Consult CAN AM. The "best" TV (best for you) will make things enormously different; better.
Old 03-06-2012, 09:24 AM   #16
50KIP's Avatar
2009 19' International
Woodinville , Washington
SUV as TV
For those who doubt the towing capabilities of shorter wheelbase vehicle should watch the Airstream produced video on You Tube titled Airstream Performance. BTW: The Porche Cayenne is the same body as the VW Touareg, but with 500 hp.
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 03-06-2012, 10:03 AM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Interesting and impressive test but I would like to see done with more common TV trailer combinations.
MICHAEL
Old 03-06-2012, 10:12 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
........ the original question was 84 Bronco, that said, lets all agree he's doing the rite thing by researching a compatible tow vehicle.
As a former user of a full size "short wheelbase" SUV.....never mind.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-06-2012, 10:17 AM   #19
Road Ruler's Avatar
Images: 38
That is a sweet set up. Would luv to have that whole pkg in our driveway.
Note that the big influences in this combo are the
short rear overhang on the TV,
the Hensley,
high end performance tires/suspension,
etc.
When there are so many positive things going on as in this Porsche/Airstream combo the wheelbase becomes much less of a factor.
Old 03-06-2012, 11:03 AM   #20
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Too late to get a consensus "on subject". Someone has already said "Oh, look at the kitty!" ( or if you're a dog fan "Squirrel!!!!").
Ken
Old 03-06-2012, 11:12 AM   #21
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I think the reason not to tow with the Bronco is the short wheelbase- a longer wheelbase is better for directional stability when towing. We tow with an '08 Tundra, the base extra cab with a V6, towing our 2850 dry weigh '64. The thing has been pretty bullet proof with the exception of tires, but the current set is holding up well. Two great things for towing: one, you can choose gears manually, so you can drive in 4th or 5th. The other thing is the tight turning circle, it turns on a dime. We've had Fords, which had numerous stupid problems. We also have a Ridgeline which would be my tow vehicle of choice, but it had higher mileage on it so I set up the Tundra. The Ridgeline is much, much more comfortable and handles a lot better, and does just fine fully loaded. It also has a ladder frame and the body is very stiff. We have 100k on our 2006 with no problems, one brake reline and that's it. The one issue for me is that you can't select 4th gear, and I don't know if the Grade Logic transmission would compensate for towing by keeping it in 4th automatically. It automatically downshifts and holds the gear when necessary.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-06-2012, 06:01 PM   #22
r carl's Avatar
Lin , Ne
The toyota powertrain warranty is only good for 60k,,, they must not believe in their trucks like GM.
Old 03-06-2012, 06:55 PM   #23
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
It's actually do-able, but...
We towed a 24' Trailer with an '85 Ford Bronco 351 with Tow package for more than 12,000 miles, including trip across US and back.. Plastic Roof lets inside get warm in Dakota's when air temps over 100 degrees, but short wheelbase was actually a rare benefit in manuevering and backing up into tight spaces..
I won't argue with folks who say an '84 ANYTHING is getting potentially tired and worn out, and prone to blow at usually troublesome times.. Weak links in full-size Bronco's are cooling and transmission...
That said, dealer who sold us Trailer literally declined to make sale unless we bought best anti-sway setup (short of Hensley..) we could.. Problem with Bronco's isn't just short WB, it is squirrelly (technical term) steering box using recirculating ball instead of rack and pinion. Consequence is that even when NOT towing, Bronco tended to wander and use ALL of the lane it was assigned.. Add in a heavy trailer, some crosswinds, and a double semi-trailer truck passing you, and you will be sawing at the wheel like a NASCAR driver after being bumped in a corner.. Solutions involve slowing down and watching mirrors to see trucks coming and anticipate bow wave and tail suck-in.. In Idaho, where triples are allowed on I-90, we just decided to stay behind a UPS Triple rather than risk a pass at 65...
If you're not going to do a lot of freeway driving fast, and need to conserve cash for a couple years, get a really good anti-sway setup and you could try it..
Final thought is that Dodge Durango is same vehicle as Jeep Grand Cherokee (but for body parts and interior trim) and it might be less expensive alternative.. Late model Chevy TahoeGMC Yukon or Ford Expedition would be improvements over Bronco, even though wheelbase only slightly longer, as they use rack and pinion steering and are more stable... In many places, Tahoe's and Expeditions are getting cheap as gas gets expensive..
ps And yes, we traded Bronco in after 4 years and bought a Suburban.. ess power, but more stable
Condoluminum
Condoluminum is offline   Reply With Quote
Old 03-06-2012, 07:04 PM   #24
2007 25' International CCD FB
Holladay , Utah
Originally Posted by zlee
Touareg TDI. That's my dream TV. Not sure it'd tow a 25' though.
It will, and then some. Ask your friends at Can-Am. But it costs more than the Jeep.
FlashSilver is offline   Reply With Quote
Old 03-06-2012, 07:41 PM   #25
pxlchk1's Avatar
1972 Argosy 20
Brookfield , Illinois
I emailed back and forth a couple of times with Andy and he seems to really know his stuff. Asking around, I've gotten a lot of recos for his work as well as people saying that he is very well-respected.
Sounds like he's the guy to listen to.
I have an '06 Subaru Tribeca and have gotten lots of very strong opinions from well-meaning people who are not towing experts. I plan on taking it to Andy even though it's a 7 hour drive from Chicago. I want the work done right.
Good luck!
-Alana
AirForms thread: Alana's '72 Argosy Project
Where I blog : Nest Vintage Modern
pxlchk1 is offline   Reply With Quote
Old 03-06-2012, 07:43 PM   #26
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I agree with Condoluminum; Working at Ford dealers for many years and I have driven lots of Broncos. They wander all over the road even without any worn out steering components. I would never recommend a Bronco for towing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-06-2012, 07:52 PM   #27
pxlchk1's Avatar
1972 Argosy 20
AND a Subaru Tribeca.
HOLLA!
Alana (Tows with a Tribeca.)
Old 03-06-2012, 08:01 PM   #28
Thumbs up
I wanna toe with a teeny-weeny too.
PFC
"Tahawus"
RLC
John Prine
Bronco is a no-go scubachris Tow Vehicles 44 03-11-2015 09:07 AM
My next project is a basket case... InsideOut Vintage Kin 142 10-19-2013 09:18 PM
What size truck or SUV is best? Marinablue Towing, Tow Vehicles & Hitches 265 04-20-2012 11:39 AM
winegard antenna there is alum bracket that cradles unit starcraft Electrical - Systems, Generators, Batteries & Solar 8 03-07-2012 11:51 AM
Here is an old motor home AIR-Quarius Vintage Kin 11 03-05-2012 06:05 PM
