06-19-2015, 09:48 PM
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Full-Time
, Full-Time
Brake Controller Not Working on RAM Pickup
I am having trouble with my factory Integrated Brake Controller on my 2015 RAM 1500. The truck is new, less than two months, and today was the first time using it with a trailer. I went to go pick up my 2016 25FC and after all the check outs etc. it was time to test out the new hitch and adjust the brake controller to the new AS (as a reference I am an experienced tower and have been pulling AS for 20 years).
We used the standard method of initial dial in of the brake controller: drive approx. 20mph, let off the gas, apply manual gain to lock up trailer tires, then back off gain, repeat till the skidding stops. The problem of not enough trailer brake is even with a gain setting maxed at 10, it barely slows the rig and I mean barely. The issue is bad enough it is not safe to tow. The AS brakes are ‘definitely engaging’ but about as much braking as if any other controller was operating and you had the gain set at 2.
To test and make sure it was not the new AS brakes, we hooked another new 25 AS to my RAM and the same issue existed with an identical AS. We took my AS and hooked it up to another pickup and we could easily lockup the trailer tires. So, we have proven, with out any doubt, it is my new truck integrated brake controller, not the AS.
Here is the RAM brake controller settings I used:
- with gain set at max 10 the issue persisted no matter if the trailer brake controller was set at ‘light electric’ or ‘heavy electric’. Light is for up to 8,000lbs, heavy for over 8,000lbs. There was very little discernable difference felt between the two settings, even at 10 gain.
- I am definitely on 'electric' and not on 'electric over hydraulic' on the settings.
Has anyone experienced or heard of this issue with the RAM integrated brake controller? This is my first RAM truck so am I missing something? Unfortunately, tomorrow is Saturday and no dealerships open. Bummer!!!
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
06-19-2015, 10:15 PM
2012 25' Flying Cloud
Battle Lake
On our 2012 Ram 1500 (factory controller) and 25' FC Airstream we use the "Heavy Electric" setting with gain at 2.5, works very well over thousands of miles. I check it at each hookup by letting the rig roll ahead at idle and can stop the rig squeezing the manual trigger on the controller at 2.5 gain without locking up the brakes.
Doug and Cheryl
06-19-2015, 10:30 PM
1997 21' Excella
Full-Time
, Full-Time
On my 2015 and Heavy Electric on setting 2.5 you couldn't even feel it. I can barley stop a 10mph roll with Heavy Electric, not pushing on the gas, in 20 feet. Something seriously wrong.
Greg
06-19-2015, 10:47 PM
Battle Lake
Could it be the brand new trailer brakes are not adjusted. Not sure about this, but do they self-adjust by backing up the trailer and braking a few times? Try it.
Doug and Cheryl
06-19-2015, 10:51 PM
1974 Argosy 20
Kooskia
, Idaho
His brakes locked up with another TV hooked to his trailer, so the trailer brakes do work OK.
06-19-2015, 11:08 PM
Vintage Kin
Fort Worth
The factory integrated brake controllers on all brands have their problems. I've not yet read of one that is as sophisticated as the TUSON DIRECLINK, and would do the work to install it.
And add their electronic trailer antisway unit at the same time.
Some OEMs claim to have something similar to this, so do your reading. I'd rather have the TUSON at present.
06-19-2015, 11:31 PM
Battle Lake
A career of working with electrical systems (aircraft) taught me to never rule out anything. Most electrical faults are at the connections, so good to take a look at the obvious connections. The bumper connector may be defective physically or a poor crimp on the wire lead on the back of it. If there is a wire leading to a ground connector, it may be loose or poor contact. Look things over. You could check resistance through the connector and to ground, and voltage if you have a meter.
Doug and Cheryl
06-20-2015, 12:06 AM
Vintage Kin
Fort Worth
Dr Obvious is absolutely right.
06-20-2015, 04:37 AM
2012 25' FB Flying Cloud
Celina
I had the same problem with our 2014 Ram and 2012 FC. I tried all of the settings and nothing worked, took both to the Ram dealer 3 miles from home. At the third stop sign the brakes started working and have worked ever since. Never figured out why they work now but like the " never look a gift horse...."
Good luck
Gary
06-20-2015, 05:43 AM
Mantua
Maybe it just takes awhile for all that newfangled electronic computer actuated do dad stuff a little time to get to know each other and cooperate! Computer has to reset? Hope you figure this out!
06-20-2015, 05:59 AM
1997 21' Excella
Full-Time
, Full-Time
Thanks for all the input from everyone. It is so frustrating when something sort of works, but really doesn't especially when it's on a brand new rig, head to toe, literally.
I understand electricity a lot when it comes in the form of an on-off switch. But I am getting better at it, I think I have mastered the dimmer switch for the AS overhead lights:-)
I have an electrician friend coming over today to do the stuff electrical people know how to do: wiggle pins, look for bad grounds, resistance , ohms. After that, hopefully, if nothing found the dealer will see me Monday. I am already a week behind heading out to MT, ID and WY. Need brakes for the region for sure.
Greg
06-20-2015, 06:04 AM
Mantua
Frustrating. My only suggestion would be to start from scratch using the owners manual and slowly and deliberately set the controller and anything else to do with towing up again. Might be something simple. I wonder if there isn't enough amps to power the brakes properly. A setting or adjustment somewhere? Good luck hope it works out well for you!
06-20-2015, 10:50 AM
2014 25' FB International
Scottsdale
Ram Dealer?
I've also got a new Ram and tow a 25Int'l. Got the gain set on 4.5 when all loaded up and it's perfect. Given your "history" I'd head back to the Ram dealer and lay the problem at their doorstep. It's Saturday...they might still be able to solve it. Good luck.
06-20-2015, 12:00 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
I sympathize with the OP!
My '09 25' Int. brakes do not work at all with my 2013 RAM 1500. I've tried everything I know to try, including having the RAM at the dealership for an entire day after which they could find nothing wrong, and now have the trailer at the local Camping World shop waiting for resolution. They plan on looking at the AS and my TV on June 30th. I am anxiously awaiting a resolution as I've been unable to use my new (to us) AS.
Frustrating!
06-20-2015, 12:33 PM
2015 30' Classic
2012 28' International
Greensboro
I have a '14 Ram 2500 4x4 w/ Cummins and tow a '15 Classic. No issues with my controller. Something is amiss in your truck. There is a thread on this from someone else who had a similar issue -- sorry I don't remember the resolution.
_________________
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
06-21-2015, 11:12 AM
2003 25' Safari
Riverside
Take your truck back to the dealer and have them trouble shoot you truck using star case s1508000014 It will guide them through what to check.
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
06-22-2015, 06:56 AM
1997 21' Excella
Full-Time
, Full-Time
Thanks for the good info. I have gone from calling dealer this weekend, and their estimate to checking it out in about a week (that prompted me to call the head sales guy cell phone Sat. night) and when checking in 7:30am Mon. at dealer all of a sudden they were waiting for me, with a loaner, and taking it straight to the bay to trouble shoot. You can see who has the weight at a dealership😀
I'll keep you posted, I certainly hope they find something obvious.
Greg
06-22-2015, 09:18 AM
1997 21' Excella
Full-Time
, Full-Time
Problem should be solved !!!! The dealer who rushed my RAM in and 3 hours after I dropped it off their diagnosis detected faulty brake controller. Great news! Bad news it would take 3 days to get a new replacement. Good news is they scavenged a controller off a new truck on the lot, wow. Then they hooked my truck up to their trailer and tested it out, super wow. It now works. So, in 3 hours the dealer has solved my problem. My hat is off for them.
And thanks to everyone on this thread helping me out.
Greg
06-22-2015, 10:12 AM
Vintage Kin
Fort Worth
Great!
06-22-2015, 03:58 PM
1997 21' Excella
Full-Time
, Full-Time
I should have not spoken so fast!!!
I don't know what super light and not loaded trailer they used to test the new controller but there is no change between the new one and old one on my AS. It's not going to stop. They have opened a priority ticket with RAM. I talked to the technician and he said they did get the same error on both controllers indicating there was a short but they discounted since it seemed to work with them on their utility trailer with the new controller.
I just had to bite my tung.
The Saga continues.
Greg
