Old 05-28-2015, 05:08 PM   #113
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by KJRitchie View Post
Your dog is spoilt....just like mine.
Hook up your AS and tow it to that scale. When is your first trip towing your AS?
Kelvin
Hi, I don' think any dog is spoiled more than Dusty, but that's just me. After my Daughter from Phoenix, Arizona visits Oregon in June, we should be able to hit the road in July. I have almost 5,000 miles on my truck now. My wife commented on how long it took to get the first 1,000 miles, seemed like forever. Now the miles are coming fast.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-30-2015, 12:07 AM   #114
Salem , Oregon
Images: 18
Hi, I now have tie downs that should work for securing my Yamaha 2400 generator. I bought two 1/2" "D" rings with one hole. [hard to find] The hole in the bracket was a 7/16" square hole. I bought a reduced shank 9/16" drill bit and drilled the holes out. This was done because I want to use my bed bolts instead of drilling new holes in my bed. Even though I drilled the bracket holes to 9/16" they still didn't fit over my bed bolts. There are two ridges for keeping the washer in place. Because of the thickness on the "D" ring brackets, a washer is not needed. I put the bed bolts in my little drill press and used a file to remove the ridges and the washer. I now have two "D" rings mounted to my bed with the factory bed bolts.
ID:	239539   Click image for larger version
ID:	239541   Click image for larger version
2005 Safari 25-B
Old 06-03-2015, 01:08 AM   #115
Salem , Oregon
Images: 18
Hi, today I mounted my generator in my truck's bed and fired it up. It was very quiet and smooth running, but at this time it didn't have a load on it. I will be able to put stuff next to it while traveling, but not while the generator is running, for cooling purposes. I have a locking tailgate, a locking bed cover, and a cable lock on the generator. Also when running, the bed cover will be rolled back a few feet.
2005 Safari 25-B
Old 06-22-2015, 07:08 PM   #116
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Robert. I was on another site reading about the Ford 3.5 Ecoboost and the question of needing Supreme fuel came up. Someone stated that it was in the owners manual that Supreme was needed when towing.
I haven't read it on any of the Airstream threads regarding the Ecoboost, so I thought I would ask.
Does your owners manual recommend Premium when towing?
George
gandttimes is offline   Reply With Quote
Old 06-23-2015, 01:20 AM   #117
Salem , Oregon
Images: 18
George
Hi, George; Here is a quote, but the key word is "Recommended".
"Premium fuel will provide improved performance and is recommended for severe duty usage such as trailer tow."
2005 Safari 25-B
Old 06-23-2015, 11:56 AM   #118
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
I guess that really means " you don't have to but the engine will perform as advertised if you do"
George
Old 06-23-2015, 07:07 PM   #119
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Looking good Mr. Bob. You are really outfitting that truck!
I may be joining you soon! The dealer is now starting a hunt for me, to find a new 3.5 eco/white/camel. It's that first then order one if unsuccessful.
I am sure you shared but do you have the 3.55 rear or the 3.31? I am thinking about going with the .31.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-23-2015, 10:28 PM   #120
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Whether searching or ordering check payload and then check payload again. That is the only shortcoming of the F150 Echo boost. They are capable of having all the payload that you need but one has to be certain that the one you pick has an adequate payload. I set 1500lbs + as the minimum.
TinCan
graysailor is offline   Reply With Quote
Old 06-24-2015, 01:07 AM   #121
Salem , Oregon
Images: 18
Hi, rodsterinfl; I asked for, and received, Electronic locking 3:73 gears.
2005 Safari 25-B
Old 06-24-2015, 01:09 AM   #122
Salem , Oregon
Images: 18
Hi, to me this was very important; My Lincoln had a payload of 1600 lbs and I wanted more than that. Mine would have been 1900 lbs, but I believe that I lost 155 lbs to the Off Road Package due to skid plates. Mine is 1745 lbs.
2005 Safari 25-B
Old 06-27-2015, 12:40 AM   #123
Salem , Oregon
Images: 18
First tow with my F-150?
Hi, today I hitched my trailer to my new 2014 F-150; Tomorrow will be my very first tow with this vehicle. Actually, I'm towing my trailer to the other side of town for four new trailer tires. I ordered and paid for these tires a couple weeks ago. A random trip maybe starting soon.
2005 Safari 25-B
Old 06-29-2015, 12:37 PM   #124
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
hmm, no discernable performance or mpg difference for us when towing with our 2011 F150 EB.
we ran the tank down to empty before first fill with premium, and burned two consecutive tankfuls of premium.
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is online now   Reply With Quote
Old 06-29-2015, 03:46 PM   #125
Salem , Oregon
Images: 18
ymmv.
Hi, good to know of your experience; I will also try it sometime. We are leaving soon and I'll keep 87 in it and see what it does. I towed my trailer about twenty miles and so far so good. The real test will be on our trip.
2005 Safari 25-B
Old 06-29-2015, 05:08 PM   #126
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Robert,
What can you teach me about using a generator to top of batteries while dry camping? I "assume" battery selector is in run mode, so do you run the generator for 30 mins and check the see level battery indicator shows progress.
I guess, please share your technique. Thanks
Jeffrey
DoublTrouble is offline   Reply With Quote
2014 Flying Cloud 'Bambi' first report idroba 2005 and newer - Bambi all models 8 07-16-2015 07:20 AM
Ford 2014 Ecoboost 150 with Max tow and HD payload Rollster On The Road... 27 01-20-2015 08:10 AM
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
Applause for Bob Boondocker Boondocking 6 04-10-2006 10:20 AM
Bob Hope... canny_banjo_man Off Topic Forum 10 07-30-2003 01:43 PM
