Old 01-16-2015, 10:03 PM   #57
Oakland , California
Originally Posted by zigzagguzzi View Post
Most if the time you can take your vin number either to the service or parts dept and they can run a build sheet. This will tell you what was on the vehicle when built. Works well when buying used also. Peace, jim
Or just get it online here:
http://www.inventory.ford.com/servic...icker.pdf?vin=
Type in the vin number at the end. For example:
http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=1FT7W2B67DEA7533
mikebee is offline   Reply With Quote
Old 01-16-2015, 11:00 PM   #58
2017 27' International
Fall City , Washington
I'll have to measure to be sure, but my bed is 8' in length, which may explain why the box that holds the rolled up cover could differ in dimension. I suspect my 4" guesstimate may be off a bit.
2014 28' Flying Cloud
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 01-21-2015, 09:54 PM   #59
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Retrax Pro.
Hi, a few friends came by this morning and we got the bed cover sitting on the bed. From there I got it in proper position and clamped in place. I later went out and installed the two drain tubes; It was 32 degrees out this morning and everything was icy. It was a bit warmer when I installed the drain tubes. The bed cover is a nice fit and works well. It also improved my gas mileage by 5 MPG. I was just testing to see if you were awake while reading this.
(1.) Not everything in this picture is white, without the frost on it. [house roof is black]
(2.) Mounted before the frost melted.
(3.) Name and number so I don't forget, or if someone else likes it they know who to call.
(4.) Finished mounting and fully retracted.
(5.) This shows one of the drain tubes; I chose to drill holes in the plastic plugs instead of the bed floor. Also note the room under the canister to the bed floor.
(6.) One of four mounting clamps.
(7.) Two empty containers an one ice chest for shopping. We always kept an ice chest in the Lincoln for cold items. [ice cream, Etc.]
(8.) Bed cover closed, tailgate open.
(9.) All closed and locked; Ready for the road.
ID:	230883   Click image for larger version
ID:	230885   Click image for larger version
ID:	230887   Click image for larger version
ID:	230889   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-21-2015, 11:12 PM   #60
2007 22' International CCD
Bob,
Looks a LOT like the one I have on my 2002 Tacoma P/U. My 2012 Taco TV has a solid tonneau on it.
Looks nice. I can just get spare propane tanks under the one one TV. Little Taco is not deep enough.
You will find that sheets of plywood or plasterboard fit under the box and sit on the tailgate edge--assuming the bed is wide enough. Just a strap to hold it in and you're good to haul stuff--which is what a P/U is all about IMHO
KE4GNK/AE
Old 01-22-2015, 04:17 AM   #61
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
A bed extender flipped inside will allow,you to get rid of that tie-down strap across those totes and cooler. There may also be cut-outs/indentations in the bed to place a 2x4 vertically side to side to keep things in place.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-22-2015, 09:18 PM   #62
Salem , Oregon
Images: 18
Originally Posted by rmkrum View Post
Bob,
Hi, I figured that my truck will hold more plywood or 2X4's than I will ever need to carry. And this is with the bed cover installed.
2005 Safari 25-B
Old 01-22-2015, 09:27 PM   #63
Salem , Oregon
Images: 18
Originally Posted by m.hony View Post
A bed extender flipped inside will allow,you to get rid of that tie-down strap across those totes and cooler. There may also be cut-outs/indentations in the bed to place a 2x4 horizontally side to side to keep things in place.
Hi, I noticed those places for the boards; right now, I have plenty of ratchet straps, no wood, and plan on mounting my generator back there. I will have see how everything is going to fit. I had a place for everything, except for my generator, in my Lincoln. I'm not sure that a bed extender will work with my generator, but I haven't ruled anything out yet. Today, on the other side of town, we bought a lot of cold items including ice cream. The ice chest worked great and was easier to get to than I thought it would be.
2005 Safari 25-B
Old 01-23-2015, 04:47 PM   #64
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Have you adjusted your Equalizer hitch yet Bob. You ready to roll yet?
subfan1 is offline   Reply With Quote
Old 01-23-2015, 05:03 PM   #65
dznf0g's Avatar
Oswego , Illinois
Originally Posted by mikebee View Post
That's a cool web feature, but it's a window sticker, not build sheet.
Here's an example of a GM build sheet, Ford is similar, I'm sure:
Vehicle Build
Model: 1LF26-2013 EQUINOX LS FWD Order Number: QMSWVW
Gross Vehicle Weight: 2,252 Build Date: 08/25/2012
Build Plant: 1
Option Codes
01A - SEAT TRIM JET BLACK 1AB - DR PANEL TRIM JET BLACK
1LS - 1LS PACKAGE 1SZ - OPTION PACKAGE DISCOUNT
4AA - INTERIOR TRIM JET BLACK AFH - JET BLACK
AL0 - AIRBAG SENSING SYSTEM, PASSENGER AR9 - SEAT, FRONT BUCKET
AT8 - RR CHILD SEAT RESTRAINT ATG - REMOTE KEYLESS ENTRY
AXP - MPV VIN IDENT POSITION AY0 - AIRBAGS, DRIVER & FRONT PASS. FRONT/SIDE IMPACT. AIRBAGS SIDE HEAD CURTAIN
B37 - FLOOR MATS FRONT & REAR C67 - AIR CONDITIONING
D22 - POWER MIRRORS, DUAL DCP - 6 MTHS ONSTAR DIRECTIONS & CONNECTIONS W/ AUTOMATIC CRASH RESPONSE AND TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
EBC - BASE CLOTH EF7 - COUNTRY UNITED STATES OF AMERICA (USA)
F82 - AXLE, 3.23 FINAL DRIVE RATIO FBZ - TRIM DOOR VINYL, DARWIN
FE1 - SUSPENSION SYSTEM FE9 - 50-STATE EMISSIONS
FHO - VEHICLE FUEL GASOLINE E10 GLJ - ASHEN GRAY METALLIC
GZL - 4,960 LBS GVWR I13 - ENGINEERING MODEL YEAR
JL9 - ANTI-LOCK BRAKE SYSTEM, 4 WHEEL DISC K09 - ALTERNATOR, 120 AMPS
K34 - CRUISE CONTROL LEA - ENGINE, 2.4L DOHC 4 CYL W/ VVT
MAH - MARKETING AREA US, PUERTO RICO /USVI MH7 - TRANSMISSION 6 SPD AUTO, HMD
MX0 - 6 SPD AUTOMATIC TRANSMISSION N37 - STEERING COLUMN, TILT AND TELESCOPIC
NK5 - STEERING WHEEL NT7 - FEDERAL EMISSION SYSTEM TIER 2
OST - PLANT CODE OSHAWA 2, ONTARIO CANADA QCS - TIRE SPARE
QYZ - TIRES, ALL SEASON BLACKWALL R9N - PROCESSING CODE - SEAT
ROO - TRACKING CODE RSB - WHEELS, 17" FORGED PAINTED ALUMINUM
S1G - WHEEL SPARE SLM - STOCK ORDERS
TB4 - REAR LIFTGATE, MANUAL U2K - XM RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS XM AFTER 3 MOTHS
U80 - COMPASS DISPLAY UE1 - 6 MTHS ONSTAR DIRECTIONS AND CONNECTIONS WITH AUTOMATIC DEPLOYMENT RESPONSE AND TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
UJM - TIRE PRESSURE MONITOR UK3 - STEERING WHEEL CONTROLS
UPF - BLUETOOTH FOR PHONE UW6 - CUSTOM 6 SPEAKER SYSTEM
UYE - AM/FM STEREO, CD PLAYER V8D - VEHICLE STATEMENT US
VQN - NOISE CONTROL ACTIVE INTERIOR VT7 - OWNERS MANUAL, ENGLISH
VZD - MODEL YEAR IDENTIFIER YB6 - AXLE
YD5 - SPRING FRONT BASE EQUIPMENT YD6 - SPRING REAR BASE EQUIPMENT
And this is a component summary:
Vehicle Component
Component Code: 10-ENGINE ASSEMBLY Traceability: 122341038
Source Plant: N-BOC - V6 LANSING, MICHIGAN Part / Number Broadcast:
Date Scanned: 08/24/2012 Time Scanned: 18:28:00 Scan Station:
Component Code: 61-TRANSMISSION Traceability: 2217A0088
Source Plant: K- Part / Number Broadcast:
Date Scanned: 08/24/2012 Time Scanned: 18:29:00 Scan Station:
Component Code: 86-ELECTRONIC CONTROL MODULE (ECM) Traceability: 122235924
Source Plant: C- Part / Number Broadcast: ABMU
Date Scanned: 08/24/2012 Time Scanned: 23:09:00 Scan Station: 03
Component Code: 87-BODY CONTROL MODULE Traceability: Z22210031
Source Plant: 4- Part / Number Broadcast: 4695
Component Code: 92-BRAKE PRESSURE MODULATOR VALVE ASSEMBLY Traceability: 22264537
Source Plant: P- Part / Number Broadcast: 1900
Date Scanned: 08/24/2012 Time Scanned: 18:19:00 Scan Station: 03
Component Code: AB-IR-MODULE ASM-INFLATOR Traceability: R2C2285C1
Source Plant: S-TAKATA Part / Number Broadcast: 0615
Date Scanned: 08/23/2012 Time Scanned: 20:45:00 Scan Station: 03
Component Code: AH-IR-SENSOR ASM-LEFT Traceability: 016B1E75F
Source Plant: E-METHODE ELECTRONICS CARTHAGE IL. Part / Number Broadcast: 2577
Component Code: AJ-IR-SENSOR ASM-RIGHT Traceability: 0169F5092
Component Code: AL-IR-MODULE ASM-I/P Traceability:
Source Plant: - Part / Number Broadcast:
Date Scanned: N/A Time Scanned: N/A Scan Station: 03
Component Code: AS-SENSING DIAGNOSTIC MODULE Traceability: 050131633
Source Plant: E-METHODE ELECTRONICS CARTHAGE IL. Part / Number Broadcast: 7453
Component Code: BL-ELECTRIC POWER STEERING CONTROLLER Traceability: 00937536
Source Plant: L- Part / Number Broadcast: 2233
Component Code: BV-COMMUNICATIONS INTERFACE MODULE Traceability: 122010236
Source Plant: L- Part / Number Broadcast: 0772
Component Code: CA-SEQ NUM (FLEX) BODY ASM Traceability: 0300310
Source Plant: O- Part / Number Broadcast: ZZ
Date Scanned: 08/23/2012 Time Scanned: 07:51:00 Scan Station: 03
Component Code: CB-SEQ NUM (FLEX) BODY ASM Traceability: 0300310
Source Plant: - Part / Number Broadcast: 2ZZ
Date Scanned: 08/21/2012 Time Scanned: 00:18:00 Scan Station:
Component Code: CF-SEQ NUM (FLEX) PAINT PROCESS Traceability: 4143709
Source Plant: - Part / Number Broadcast: 2PP
Date Scanned: 08/23/2012 Time Scanned: 20:19:00 Scan Station:
Component Code: CP-SEQ NUM (FLEX) GEN ASM Traceability: 4155247
Source Plant: - Part / Number Broadcast: 2GA
Date Scanned: 08/24/2012 Time Scanned: 07:05:00 Scan Station:
Component Code: CZ-SEQ NUM (FLEX) GEN ASM Traceability: 029068
Date Scanned: 08/25/2012 Time Scanned: 08:08:00 Scan Station: 03
Component Code: DF---- Traceability: Q22228067
Source Plant: 9- Part / Number Broadcast: 2849
Date Scanned: 08/24/2012 Time Scanned: 15:07:00 Scan Station: 03
Component Code: DG---- Traceability: K32231139
Source Plant: 9- Part / Number Broadcast: 2850
Component Code: DT- Traceability: 23600470
Source Plant: 2- Part / Number Broadcast: 4862
Component Code: DU---- Traceability: A12230C10
Source Plant: D- Part / Number Broadcast: 3483
Component Code: GA---- Traceability:
-Rich-
Old 01-23-2015, 08:03 PM   #66
Salem , Oregon
Images: 18
Hi, I ordered a new hitch shank, but don't have it yet, so not set-up yet. Tonight, I un-hitched the Lincoln from my trailer. I wanted to make sure that my Safari water leaks were gone before disconnecting my Lincoln. Otherwise I would have to tow it back to the shop. Hopefully the next time my trailer moves it will be with the F-150.
2005 Safari 25-B
Old 01-23-2015, 10:07 PM   #67
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I still don't get how your shank drags. I have the Expedition with regular shank and it must be good foot above the pavement. Regardless, I will look forward to a towing comparison report. Moving from a four wheel independent suspension to a solid rear axle, and a more powerful engine.
kscherzi is offline   Reply With Quote
Old 01-23-2015, 10:36 PM   #68
Salem , Oregon
Images: 18
Hope this explains it.
Hi, my shank dragged a few times so I cut it off. The receiver on my F-150 is about four inches higher than the one on my Lincoln, so even if I didn't cut it, it won't work on my F-150. My Navigator has a solid rear axle not full independent suspension.
And the question is: Why did your shank drag while my Expedition [similar vehicle] doesn't? Well my answer is that my Lincoln has rear air suspension and while hitching and unhitching there is a process of opening and closing doors, and putting trans in gear with engine running and waiting for the suspension to pump up. Some times I take off before it is completely pumped up. Therefore it has dragged. Also Lincolns sit lower than Expeditions and two wheel drive models sit lower than four wheel drive models. Mine is two wheel drive.
2005 Safari 25-B
Old 01-24-2015, 04:39 AM   #69
Gainesville , Florida
Always have pulled build sheets on my used purchases. Only way to tell all you need to know. I think it is as important as a car fax report. Jim
Old 01-24-2015, 07:09 AM   #70
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How do you get a build sheet for a used purchase?
Kelvin
2014 Flying Cloud 'Bambi' first report idroba 2005 and newer - Bambi all models 8 07-16-2015 07:20 AM
Ford 2014 Ecoboost 150 with Max tow and HD payload Rollster On The Road... 27 01-20-2015 08:10 AM
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
Applause for Bob Boondocker Boondocking 6 04-10-2006 10:20 AM
Bob Hope... canny_banjo_man Off Topic Forum 10 07-30-2003 01:43 PM
