Old 02-10-2014, 01:31 PM   #15
kellykellyi's Avatar
1952 15' Cruisette
1967 20' Globetrotter
2010 19' International
La CaŮada Flintridge , California
I am looking at the MB ML350 or GL350 to tow the '07 Intl 25FB that I just purchased. Did you do any mods to your GL? How long have you been towing with it? Any years I should avoid if I buy used? I am worried that there is little wiggle room with regard to weight limits with the MB's but can't see myself in Yukon or similar other truck based large SUV. I appreciate any insight you can offer based on your real world experience with the MB.
Thanks!
Kelly
kellykellyi is offline   Reply With Quote
Old 02-11-2014, 06:37 AM   #16
jmcarter's Avatar
2010 28' International
Richmond Hill , Georgia
Thanks!
Kelly
Don't want to hijack the thread...I PM'd you.
jmcarter is offline   Reply With Quote
Old 02-13-2014, 07:04 PM   #17
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
Our 2009 X5 diesel has been a great overall car, and an impressive tow vehicle. We wanted a medium-sized do-it-all SUV, and this is as close as we found to such a thing.
Only scheduled maintenance in 4.5 years, except for one diesel system issue, which was engine control software rather than hardware, and was repaired under warranty. I kept the 255/55-18 factory run-flat tires, and they behave well under towing loads.
I deliberately purchased the X5 with only the basic premium package, and did not choose electronics-heavy options, or air suspension, for the same simplicity and self upgrade paths mentioned in this thread. The dealer installed factory hitch and brake controller have had no issues. As others have noted, the problem areas for BMWs tend to have been in upgraded electronic systems.
We have been towing with it for a year and a half, in all conditions except extremely mountainous terrain. Towing mileage is 15-18 MPG (15.6-13.0 litres/100km), and plenty of satisfaction from 425 lb-ft of torque. The current cost of diesel fuel doesn't make it as a great cost-per mile value as when we bought it, but the non-towing mileage of 24/29 city/highway still beats our old gas V8 SUV by a healthy margin.
I can certainly recommend this choice of tow vehicle.
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 02-17-2014, 01:01 PM   #18
ShinyToo
Ggroth's Avatar
2011 25' FB International
2013 Interstate Coach
Franklin , Wisconsin
Question on X5
Confused about using a BMW X5 as a tow vehicle for a 7400# (GW) 25' Airstream? Towing capacity for an X5 is 6000#. I presently have a 2011 Sequoia, looking at Diesel Cayenne, MB diesel GLASS 350 and Infinity QX 80. Is a BMW X5 Diesel or V8, actually an option to pull (up to) 7400#?
Ggroth is offline   Reply With Quote
Old 02-17-2014, 02:40 PM   #19
withidl's Avatar
2002 31' Classic
Houston , Texas
It's worked for me since June of 2001 (ASCL 31' with GVWR of 8,300#). See my avatar and do a search on "withidl".
withidl is offline   Reply With Quote
Old 02-17-2014, 03:17 PM   #20
jcl
Vancouver , British Columbia
I consider it a reasonable option, with some qualifiers.
1) Consider the strength of the receiver. On the E53 built up to 2006 (withidl has one, I had one) it was very solid. On the E70 (up to 2013) or F15 platform (debuted in 2014) I would look into the receiver attachment and decide if any hitch reinforcement was required.
2) Consider total actual payload as compared to vehicle GVW and curb weight. Pay attention to axle loads and tire load limits.
3) Recall that the X5 has a 7700 lb tow rating in other markets, where the receiver may be different (although it has the same attachment point).
jcl is offline   Reply With Quote
Old 02-26-2014, 10:59 AM   #21
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Of course you can always check out Andy Thomson's posts on here or of course his dealership (Can Am Airstream) website, for info about towing with "alternative" vehicles. Something that he is somewhat of a "master" at setting up those combos. He also regularly writes in "Airstream Life" mag.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-23-2014, 10:21 AM   #22
urban71's Avatar
San Francisco , California
Images: 11
2014 BMW X5 Towing Hitch
Hi all - I am taking delivery of a new X5 and would love some help on the hitch install.
If you did proceed with the 2014 X5, what did you go with for a hitch setup? Looks like the BMW OEM Class III hitch has an integrated ball and not a 2" receiver for a shank and sway control set up.
For many reasons, I'd prefer my current sway control I have now.
Thanks for the insight.
laugh.listen.respond.
urban71 is offline   Reply With Quote
Old 08-23-2014, 01:29 PM   #23
Lexington , Kentucky
Urban71-We are going to Ontario, Canada to get Can-Am RV (Andy Thompson) to install a hitch receiver from scratch. It will be much stronger than the BMW hitch. I would recommend you check into this option.
wlanford is offline   Reply With Quote
Old 08-23-2014, 06:51 PM   #24
urban71's Avatar
Images: 11
BMW X5 Tow Vehicle
Best of luck with the install. We'll be sure to research that.
Old 08-24-2014, 09:40 AM   #25
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
Urban71- there is more to it with the BMW than just installing the hitch- the X5 needs to be reprogrammed to know the hitch has been installed - so when the TV is hooked up to the TT- the X5 with change the shifting patterns, engine cooling, Xdrive dynamics, etc....
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 08-24-2014, 10:35 AM   #26
RacerX's Avatar
1964 22' Safari
Walnut Creek , California
Images: 8
To txdxrider's point, I know on my 2011 X5 35d there is an auxiliary transmission cooler built in by BMW at the factory that can only be activated if the car has been reprogrammed. I went with the factory receiver install and wiring harness for the 7-way connector so I can take advantage of it.
BMW doesn't recommend using sway controls...it's an open debate as to why on various towing forums. I tow with my Reese Dual Cams and haven't experienced any issues.
Mark, Norby, Nicci and (occasionally) Matt
"The reward for work well done is the opportunity to do more." Jonas Salk
RacerX is offline   Reply With Quote
Old 08-24-2014, 11:19 AM   #27
urban71's Avatar
Images: 11
Great input. I'll get with the parts and service guys to make sure we are utilizing all that the x5 has. It's interesting how little they put out there about towing options. Like spelunking for info!
Old 08-24-2014, 07:17 PM   #28
jcl
RacerX, do you have any documentation on that cooler? That is different than my earlier model X5, and I haven't seen that before. The reprogramming on earlier models did not add any code, but simply allowed the vehicle to recognize the existence of the trailer wiring module, which then allowed access to the trailer stability control mode of DSC, turned off the rear PDC, and on some models, changed the rear camera mode. All models of X5 have and use the transmission cooler with or without a trailer AFAIK.
Jeff
Newbie's!! Difference of opinion on our tow vehicle. Travel Bird Tow Vehicles 14 02-14-2012 02:55 PM
Tow Vehicle Mrs. Bale 2008 Safari SE 4 08-23-2011 11:46 AM
Help a girl find a tow vehicle star kitty Tow Vehicles 58 08-14-2011 07:51 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
