Old 11-10-2004, 04:33 AM   #1
Bmw Towing Capacity Please Help
I CURRENTLY OWN A 1992 BMW 316i 102HP
AND I WOULD LIKE TO KNOW THE TOWING CAPACITY OF THIS CARFOR TRAILERS WITH BRAKES AND WITHOUT.
IF ANY OF YOU KNOWS PLEASE HELP
ACHALAT is offline   Reply With Quote
Old 11-10-2004, 05:38 AM   #2
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Hello to Greece!
I only found the data for the new 115Hp 316i on the BMW.com Site. It says there that you can pull a 670 kg unbraked trailer or between 1250 kg on a 12% or 1600kg on a 8% uphill road with brakes.
Maybe it helps, otherwise I would contact a local BMW dealer or submit a question on the BMW site, they should help.
Bye from Germany
Björn
Pschoerrn is offline   Reply With Quote
Old 11-10-2004, 06:38 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Putting into Airstream perspective, you could barely tow a 16' CCD and I am sure that 1250kg does not include passengers, cargo, fuel, etc which would lessing the 1250kg range making the BMW suggested not able to tow even a 16' CCD.
My suggestion would be to get a different tow vehicle if you plan on towing somthing more than a jet ski.
Old 11-28-2004, 06:24 AM   #4
HP9K's Avatar
For what it's worth, I would not tow much of anything with a BMW sedan. Before I got into Airstreams, I had a small Jayco pop-up and a 5-series BMW - the trailer was less than 1000 pounds, well within the tow rating. I got the approved hitch and had it professionally installed, but the problem is that there is no frame to speak of in the rear of the car. It's uni-body construction and the frame rails are relatively thin and made of stamped steel.
Within a few months, the hitch started tearing thru the frame rails and started pulling the bumper off the car. I had plates made and welded to the frame to reinforce the attachment points, but was never comfortable after that and got rid of the car shortly thereafter.
I can't speak about your 3-series, but I would look closely at how your intended hitch would attach.
HP9K is offline   Reply With Quote
Old 02-03-2006, 06:42 AM   #5
Road Ruler's Avatar
Images: 38
ACHALAT.. If you are still interested have a look at what BMW's are towing in Europe.
This WMV shows A BMW convertible towing a TT. Looks good to me. It also shows how their stabilizers (sway controllers) eliminate sway, (Non WD).
http://www.winterhoff.de/Filme/Kabel1_384.wmv
Towing capacity of 345 chopperbob General Motorhome Topics 11 09-06-2017 01:24 PM
Another towing question ipso_facto Our Community 34 08-28-2010 03:47 PM
Towing Capacity of the 360 swebster Airstream Motorhome Forums 37 06-01-2005 03:54 PM
Towing Capacity of 1995 30' Land Yacht Motorhome autoist General Motorhome Topics 4 07-23-2004 12:51 PM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 02:40 PM
