Old 11-17-2015, 02:15 PM   #1
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
Question Big Truck, Little Airstream: Is it a Problem?
If your tow vehicle is well and truly overpowered for what you're towing, can you ignore some of the additional gear recommended for towing?
I've just acquired a 1971 Caravel. 3290 lbs, hitch weight 390 according to the charts. I need a tow vehicle. My puny little 4 cyl pickup won't handle even this much weight, and I'm certainly not going to put it behind the Prius.
I'm planning to move to New Zealand, which makes it advantageous to buy a vehicle that's 20 years old or older -- newer vehicles require conversion to right-hand-drive which costs muchas dinero.
A neighbor is selling a GMC Vandura 2500 with pretty low miles on the speedo. He has used it for towing 27 foot trailer and loads up to 7000 lbs. It sure would be good to buy locally where I could have a trusted mechanic look the thing over. Question is, is overkill going to bite me in places other than at the gas pump?
sandgrubber is offline   Reply With Quote
Old 11-17-2015, 02:17 PM   #2
Gainesville , Florida
No.
Old 11-17-2015, 04:25 PM   #3
mandolindave's Avatar
I have a 2500 Chevy van, with a 3000 lbs trailer
I still need a weight distribution hitch. The hitch doesn't just shift weight back up to the front wheels of the tow vehicle, it also stiffens the " hinge " between the TV and the trailer. The few times that I towed without the weight distribution, the rig " porpoised " if going over any bumps or seams in the road.
A 2500 is not that much of overkill…but you may not want to inflate the tires to max pressure, especially in hot weather.
My tires are rated for 80 psi. The front tires are inflated to 50 psi.( for a better ride ) The rear tires are inflated between 60 to 80 psi, depending on the load I am carrying. While towing, I inflate the rear between 65 and 70 psi, to take some of the stiffness out of the tires so the trailer won't get beat up.
mandolindave is offline   Reply With Quote
Old 11-17-2015, 05:46 PM   #4
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
Thanks for replies. I think I'll move on the 2500 van. Secondary advantage of a full sized van is it'll allow hauling a little more junk! 18' doesn't leave much space for a toolbox, bicycle, solar panel for battery charging, dogfood . . . and on and on.
Old 11-17-2015, 05:56 PM   #5
cameront120's Avatar
1972 25' Tradewind
Why not buy something in New Zealand and save yourself the additional freight costs?
North Vancouver, BC
Old 11-17-2015, 07:14 PM   #6
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Driving that truck in New Zealand will be in interesting experience. Roads are far narrower, gas prices are roughly double. It'll stick out like a sore thumb.
I'd ship the trailer and buy a tow vehicle over there.
andreasduess is offline   Reply With Quote
Old 11-18-2015, 03:29 AM   #7
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
My New Zealand Airstream contact that suggested bringing over an American gas guzzler as well as an Airstream. Seems these sell at much higher prices in NZ than here. He imports both Airstreams and trucks, and says he makes a few grand on each pickup he imports. This mystifies me, given high gas prices and small roads, but following the vehicle ads on trademe.co.nz (sort of Craigslist and eBay combined) bears out what he says.
I won't have a full container, so bringing over a vehicle won't add much to costs, and I won't have to pay import duty, which also helps.
My plan is to sell and use the proceeds to buy a mid-size Toyota pickup or van (NZ gets selected use vehicle imports from Japan at prices below what you'd pay for the equivalent on a US market).
Plus, $2600 for a GMC 2500 van with 91k miles and known history, excellent condition, new tires and battery, etc. isn't half bad. If I decide to sell the thing in the US, I won't lose my shirt. As it stands, I can't tow my TT.
Old 11-19-2015, 09:59 AM   #8
Toronto , Ontario
I've seen a bunch of trucks in NZ, but they tend to be hobby cars, rather than daily drivers.
But yes, if you can make some extra cash, why not indeed.
Where in NZ will you be living? It's a great country.
Old 11-20-2015, 03:47 AM   #9
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
Where in NZ
Like your signature quote, I have no fixed plans. The areas that are looking best to me at this point are Northland (Kiapara) and Cormandel. But there are so many beautiful places. The Airstream project is a way to see a bit more of the place before settling down, and a place to live for some months if I end out buying land rather than a built house.
Big help for a little problem unit13 General Interior Topics 6 07-22-2011 09:03 PM
Condensation problem...big problem MonaxLisa General Repair Forum 16 10-31-2010 10:00 PM
Big Trailer, Little Truck overturfs Tow Vehicles 8 02-19-2009 09:49 PM
Little Adjustment, Big Improvement! thecatsandi Hitches, Couplers & Balls 2 06-08-2006 08:34 AM
