Old 06-09-2008, 03:35 PM   #1
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Question Big SUV Tow Vehicle?
Other than Ford/Mercury and Chevy/GMC what other long wheel base big SUV's are there for towing 31' Airstream. Although the price of gas is going through the roof if you are going to continue to pull the old A/S this may be a good time to trade up in tow vehicles with the rebates and incentives being offered. I want to stay with an SUV rather than a pickup.
You might not be able to get a big SUV before to long.
Don
adonh is offline   Reply With Quote
Old 06-09-2008, 03:41 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There's the Armada, based on the Nissan Titan platform, and Toyota has the Sequoia, based on the Tundra platform. Dodge's SUV offering, the Durango, is based on the Dakota mid-sized truck, so is not a full-size machine.
Old 06-09-2008, 03:41 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
eBay Motors: International Harvester : CXT - 4X4 (item 250254891130 end time Jun-12-08 10:47:02 PDT)
Old 06-09-2008, 03:43 PM   #4
Well Preserved
1993 21' Sovereign
Eric, I think he was asking about SUV's, not pickups, though you could probably carry a pair of Airstreams with that truck.
Old 06-09-2008, 03:46 PM   #5
Aluminut
2004 25' Safari
. , Illinois
Yea, I know, but I just couldn't resist, it's a heck of a truck.
Old 06-09-2008, 03:47 PM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
How 'bout a Sprinter window van. eBay Motors: Dodge : Sprinter (item 150254686395 end time Jun-09-08 20:18:51 PDT)&
A bit smaller than the IH.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-09-2008, 04:07 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Not knowing what the price of SUV's has dropped to, vans are a good alternative. I have a 3/4 ton GMC passenger van that is a remarkable tow vehicle. Not cheap on gas with the 6 liter V8 and the 4.10 axle, but it will pull just about 10,000 lbs.
When I bought mine it was 10 to 15 thousand dollars less than looking at a Suburban.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-09-2008, 05:19 PM   #8
2007 27' Classic FB
Todd , North Carolina
Smile
I tow a 2007 27ft. Classic FB with a 2007 ESV (long) Escalade. Plenty of power, never an issue. I have changed out those super low profile tires with Chevy truck rims and Goodyear Wrangler 275/70R17 tires. The shiny, and costly original tires have been set aside for trade-in time. I also installed the largest BMR transmission oil cooler that could be stuffed in with auxillary fan. Seems to decrease ATF temp by about 15-20 deg F, but I have not driven summer desert hills yet. No problems with radiator, control, etc. I consider myself OK but at the edge of my comfort level for towing. I plan a trip out west in a couple of weeks. That will be the real test. As is, the combination is super comfortable. So far, I love it.
evsjr is offline   Reply With Quote
Old 06-09-2008, 05:55 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Was the BMR cooler a hose type connection or did you simply swap out the OEM cooler. If you simply swapped it out, did it connect directly to the metal factory trans line pipes?
If it was simply a direct connected trans cooler to the factory metal trans lines, can you share what part number you bought?
I've wanted to add a bigger cooler, but most times, I'd have to run rubber lines to the factory metal pipes and I didn't care for that solution.
Old 06-10-2008, 02:42 PM   #10
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
OK, I have stayed away from this till now. You must be talking about SOB tow vehicles. You did say BIG!!!! 2007 C4500 TOPKICK 12,600lbs 4X4
The REAL MACOY!!!!
ID:	62153   Click image for larger version
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
Old 06-10-2008, 03:07 PM   #11
lewster's Avatar
Naples, FL , Hood River, OR
Tom.
Tom,
The Sprinters have a max. tow capacity of 5000lb and 500lb tongue weight for most of the models. The new 3500 dually goes up to 7500/750. It's going to be my next service van/TV combo!
My '04 2500 does very nicely with a full van load and the 19CCD, but the 3500 willl mean more carry capacity AND a bigger 'Stream
Old 06-10-2008, 03:16 PM   #12
Elgin , Texas
Images: 164
The REAL MACOY!!!!
Hmmm... Seems to run counter to your sigline! That's quite a beast!
Incidentally, how do you get the jeep off of the truck? It is a rockcrawler, so I guess you could just run it up there, eh?
bake315 is offline   Reply With Quote
Old 06-10-2008, 03:29 PM   #13
2007 27' Classic FB
B&M cooler for Escalade
I need to correct myself. The ATF cooler that I had installed in my 2007
Escalade was the B&M model 70297. You can Google it and decide if you like
the product. Normally, I will install almost anything myself, but not this
time. I had a professional radiator tech do the installation and I'm glad I
did. Cost of the cooler was $220 and cost of installation was $500. Some
plastic cowling had to be trimmed to make things fit. Rubber tubing was used
in the installation. The fan is supposed to be controlled by a 175 deg
thermostadt. When the weather got hot, I observed that the fan NEVER came
on. I ran a fused toggle switch to manually control the fan. This works fine
as long as I remember to shut the fan off when leaving the vehicle. Looking
at the available real estate forward of the radiator, I believe that this is
the largest ATF cooler that can be reasonably installed in an Escalade. Hope
this is useful. evsjr
Old 06-10-2008, 05:15 PM   #14
adonh's Avatar
1976 31' Sovereign
Interesting, the Toyota Sequoia has a bigger engine 385 HP compared to the Suburban and Expedition at 300 to 320HP for the 2 wheel 1/2 tone models. But the Sequoia wheel base at 122" is 8" shorter than the Suburban and Expedition at 130". Its also about 12' shorter in overall length as well. The towing capacity listed for the Sequoia is 9,500 lbs compared to around 7,500 lbs for the Suburban and Expedition.
It sounds like it has the power to pull a big A/S but I wonder what effect if any the shorter wheel base may have.
Don
Best SUV Tow Vehicle ASchwager Tow Vehicles 76 09-21-2016 07:49 PM
Can a 34' with tow be too big for Nat parks? bronywolfe 1998 Excella 1000 11 04-22-2008 02:34 PM
help for tow vehicle - Chevy frederic.c01 Tow Vehicles 3 10-01-2006 02:05 PM
new tow vehicle whistler On The Road... 10 04-14-2004 07:07 PM
Tow Vehicle hrnicho Tow Vehicles 22 10-23-2002 12:20 PM
