Old 08-06-2008, 04:51 PM   #1
Charlotte , North Carolina
Best tow vehicle?
Hi there! I am looking at a 2005 25' safari with empty weight of 5325 lb. My ford explorer can tow 5600 , so I thought I was set, then after researching the forum, looks like a bad idea if I don't want a white knuckle experience. So, I am considering trading up to something that can handle towing better, and my question is: Any recommendations on a vehicle/truck that can easily handle the towing of the trailer, but somewhat reasonable on gas, as it will also be used as my vehicle for everyday driving. Thanks in advance for your time! I am just starting to research this lifestyle (lots to learn).
Chef Jeff is offline   Reply With Quote
Old 08-06-2008, 05:05 PM   #2
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
depends...
matter of opinion...
the 4FCU has a member that pulls a 25 FB with a Dodge Durango (5900 lbs tow capacity) and he is a bit of a newbie. He has been all over the place and has not mentioned any problem. He is very conservative in his driving practicse. I'm not. Consequently, I'm more comfortable with a TV that has at least 30% more capacity than the trailer i'm pulling.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 08-06-2008, 05:18 PM   #3
Liquid Cooled
RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
Hoo boy, are you in for it now!
Welcome!
I'm finding that I don't know as much as I thought I did.
F'rinstance, I didn't like the way an Expedition pulled a 21' SOB, but saw a Navigator hooked up to a 32' Airstream this last weekend. Much better hitch on the Nav, go figure.
This summer I've seen a 26' Overlander tucked in behind a Chevy Caprice, 23' 1970's models hitched to a Beemer, a Buick Roadmaster, and a 3/4 ton van, and more.
Our 31' has an empty weight just above that 2005 25' model, and the previous owner once towed it with an early 80's Cutlass and a couple of 1/2 ton Suburbans.
So... I'm starting to think that maybe there's more to this than meets the eye... The Touareg guys on their forum seem happy with 7000 lb trailers and since I've never driven a Touareg I can't say whether they're totally nuts or not.
There are two basic schools of thought.
One says that with careful tire & hitch selection, careful driving, and some common sense, a smaller vehicle with a gob of power and an independent rear suspension with short overhangs can work really well. (Touareg, M series Merc, etc).
The other school says you tread dangerously if the gross vehicle weight of the trailer exceeds 75% of the tow vehicle's rated capacity (this quickly adds up to a 3/4 ton truck for any but the lightest applications).
Both schools can provide a lot of examples to back up their claims.
I think the recent Suburban/Tahoe/Expy's ought to be capable of a little over 20mpg hwy, empty. This is comparable or a little better than the Touareg, which will be easier to park and likely more fun to drive.
For that matter, a brief glance at Ford's site shows some versions of the Explorer rated up to 7300 lbs. with an independent rear suspension... interesting. I haven't driven an Explorer since 1994, so I'm not one to ask if this is doable or not. I won't recommend it, but that doesn't mean it can't be done (how's that for weaseling?)
Towing, everybody with a gas engine seems to be getting between 9.5 & 12.5 mpg, with most of the difference coming from the right foot, so that's a wash.
McKesh is a good answer to one of your next dilemmas.
RedSHED is offline   Reply With Quote
Old 08-06-2008, 05:42 PM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
My vote is for a new generation Toyota Tundra (2007-2008) 2wd 5.7litre. Great tow vehicle for the 25' and with reasonable gas mileage towing or not towing.
willyd is offline   Reply With Quote
Old 08-06-2008, 06:37 PM   #5
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
Originally Posted by RedSHED View Post
<snip>Towing, everybody with a gas engine seems to be getting between 9.5 & 12.5 mpg, with most of the difference coming from the right foot, so that's a wash.
The right foot is a BIG part of the equation. If I mind my manners and keep the speed at 55, I get 15mpg or better (best so far has been 16.3 over long distances) with the '99 Burb towing the 72 Argosy 20. If I speed up to 65 or 70, the gas mileage goes right down the crapper - 10 to 12mpg. Push it past 70? Not gonna happen.
I've adopted the "reasonable speed + less braking = better fuel economy" mindset. Everytime you have to apply the brakes, you're converting speed which you paid for with fuel to heat energy that you can't recover. It's just like flying, it's a matter of energy management.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 08-06-2008, 07:32 PM   #6
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I like the F150 it is a bit overkill but it gives you added safety. Not a big fan of toyota and there rusty frame issues. My Breakfast bagle was bigger then the ring gear of most foriegn vehicles rear ends. (disaster) The other thing is a cap or a hard tonuea adds alot of secure storage
mustang is offline   Reply With Quote
Old 08-06-2008, 07:44 PM   #7
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
How about a 69-73 Chrysler Town & County Wagon with a 440 V8
or 69-73 Imperial with the same engine,
or 74-76 Cadillac Fleetwood 472 or 500 V8, 500, that's Big!
74-79 Lincoln Town Car with 460 V8
I have not mentioned a newer car yet,
Those cars are what I remember seeing growing up in the 70's
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 08-06-2008, 08:19 PM   #8
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
Originally Posted by Chef Jeff View Post
Hi there! I am looking at a 2005 25' safari with empty weight of 5325 lb. My ford explorer can tow 5600 , so I thought I was set, then after researching the forum, looks like a bad idea.
Hi Chef,
Welcome to the Forums.
A medium-sized truck-based SUV can be a good tow vehicle, but you have to really examine the weight numbers, and using a good anti-sway hitch system is a must. The difficulty here is you're essentially near capacity before loading anything in the trailer, so you're on the right track in looking for more tow vehicle. We looked at the Dodge Durango as being similar medium size & reasonable towing capability. As others have noted, the Durango is often considered the "little engine that could" when it comes to medium truck towing.
The Explorer has not been small pickup Ranger-based since 2002 - it is now essentially an "F-150 Lite." Is your Explorer a V-6 or V-8? Is the axle's final drive ratio 3.55 or 3.73? These differences bring the Explorer's rated towing capacity up to 7000 lbs, and ours has served us well towing lightweight (3500-4500lb) 22-26 foot trailers. But if yours is a V-6 and with a 25 foot A/S already near 6000 lbs, you'll be happier with more truck.
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 08-06-2008, 08:35 PM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Depending on installed axle (the upgraded the axles across the board on 25' and larger mid 2005 model year) this unit could reach a weight of 7000lbs before fuel, cargo, passengers etc. Regardless, the Explorer is NOT a good choice IMHO to tow a 25 footer....
Old 08-06-2008, 08:46 PM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You will find as many different answers as there are responces.
I personally like the Ford Trucks. Others like GM (they need all the financial help they can get right now) and some Dodge.
There is the 80% rule. your trailer loaded should not exceed 80% of your Tow vehicles RATED capacity. The rated capacities are not necessarly actual. This gives you a margin of safety. If you even have the remotest idea of upgrading your trailer go for the bigger truck or SUV. That way you will not have to support the economy more than is necessary.
Michelle TAC MT-0
Sarah, Snowball
Old 08-06-2008, 08:52 PM   #11
2008 25' Safari SS SE
Longview , Washington
Tow vehicle
I'm in the process of upgrading to a 25SS safari, and I've been towing my 22 foot safari with my 2004 toyota Tundra Double Cab. I have had absolutely no problems with the smaller trailer, and I'll get an idea how it pulls the new trailer on Monday. I'm going to be a little over the 80% when the trailer is loaded up, so we'll see how it goes.
msmst25 is offline   Reply With Quote
Old 08-06-2008, 09:47 PM   #12
1963 24' Tradewind
San Diego , California
Well!I like the Tundra 04 Stepside, However the F150 & F250 work great also, Now the Chevy & GMC well they can tow just about anything. So you see we have many options. Pick one and have a blast!!
Sixty3TW4US is offline   Reply With Quote
Old 08-06-2008, 10:27 PM   #13
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
the chevy will only tow if the hitch doesnt fall off......Did you see that other thread on 2500 hd issues? I couldnt beleve it a v4 hitch on a 3/4 ton truck what where they thinking. I am not a big fan of foriegn vehicles either. I want a big both feet on the ground platform
Old 08-06-2008, 10:41 PM   #14
MrAgent007's Avatar
2006 22' International CCD
Hershey , Pennsylvania
Images: 21
Hello Chef Jeff, I think you should look into purchasing a 2006 AM General Hummer H1 Alpha wagon or open top. There were 500 made during the 2006 model year and I hear there are about 50 new ones still in dealer lots. This was the last year of the H1 and the only year that this vehicle was equipped with the 6.6 turbo diesel Duramax and Allison transmission. This vehicle has an aluminum exterior that is mounted on a rigid steel frame and combined with the referenced drive train, will last well beyond the life of your Airstream. The tow capacity should allow you to pull approximately 9,500 lbs which is plenty for your application. The price for an H1 wagon is $147,000 and I feel is worth every penny. Fuel mileage is approximately 15 to 19 mpg depending on towing or not, highway or city street. Fuel capacity is 52 gallons which for me seems to be plenty. Good luck with your selection.
Alex
MrAgent007 is offline   Reply With Quote
safari
New Tow Vehicle! CaddyGrn Off Topic Forum 13 02-11-2007 11:42 PM
help for tow vehicle - Chevy frederic.c01 Tow Vehicles 3 10-01-2006 02:05 PM
New tow vehicle! Cedars Tow Vehicles 4 12-15-2005 09:14 AM
Tow vehicle help...please pamelake Tow Vehicles 8 11-06-2005 06:59 AM
where to look for tow vehicle remcolent Tow Vehicles 5 07-13-2004 10:39 PM
