Old 01-25-2008, 05:32 PM   #15
SafariSS
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
New Suburbans...
I posted this earlier this week, but unbelievably the new 2500 subs only come with a 3.42 rear end. Not good for towing...get an older one.
SafariSS is offline   Reply With Quote
Old 01-25-2008, 08:03 PM   #16
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
The barn doors (side-hinged) were discontinued after '02.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 01-26-2008, 04:30 AM   #17
ROBERT CROSS
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 31
Exclamation More On Gm Hitch..
Check your GM hitch carefully.
Hitch Failure on 2002 GM 2500 Vehicles
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 01-26-2008, 08:46 AM   #18
2Coaster
Profile:  1973 27' Overlander
PENSACOLA , Florida
Great info. Moosetags, thanks for the offer to come and see. We may do that although i have a trip coming up this week. I am still confused about the best rear end ratio.
2Coaster is offline   Reply With Quote
Old 01-26-2008, 09:18 AM   #19
moosetags
moosetags's Avatar
The 2500 Subs in the the model years you are looking at came with either 3.73 or 4.10 rear end ratios. In effect, the drive shaft turns 3.73 times or 4.10 times to turn the reat axle once. The higher the number the lower the rear end is geared. The lower ratio (higher number) is the better puller, but fuel economy is not quite as good as the higher ratio (lower number) rear end.
In your situation, either ratio will work fine.
Brian
Old 01-26-2008, 04:53 PM   #20
2Coaster
PENSACOLA , Florida
It's under control now. I certainly appreciate all of your outstanding assistance. Time to go car shopping! All the best - Evan
Henschen axle specs Inland RV Center, In Axles 11 01-10-2006 06:47 PM
Specs/Limitations, etc...... Boats13 General Motorhome Topics 28 06-07-2005 06:34 PM
Alignment specs? Mark K Mechanics Corner - Engines, Transmission & More... 2 09-15-2003 02:24 AM
Towing Specs 53flyingcloud Towing, Tow Vehicles & Hitches 0 11-16-2002 05:09 AM
needing some specs Mikie 1969 Overlander 10 08-07-2002 08:54 AM
