The 2500 Subs in the the model years you are looking at came with either 3.73 or 4.10 rear end ratios. In effect, the drive shaft turns 3.73 times or 4.10 times to turn the reat axle once. The higher the number the lower the rear end is geared. The lower ratio (higher number) is the better puller, but fuel economy is not quite as good as the higher ratio (lower number) rear end.
In your situation, either ratio will work fine.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
