Old 02-18-2010, 02:22 PM   #1
can't finish anyth
GolfStream's Avatar
2006 19' International CCD
2010 28' International
Dallas , Texas
Best Replacement Brake Rotor?
My tow vehicle is a 2007 Ford F-150 Lariat and my front rotors are now vibrating at 41,000 miles. So before I sink too much money into the a brake job, I thought I ask here for opinions on brake rotors.
I'm looking at Baer brake rotor & pads and boy are those spendy! I've also come across EBC as well as others.
Does anyone here have a recommendation for brake rotors?
Thanks!
Javier
Javier
Dallas, TX
2010 28' International CCD
(tricked-out techie twinkie)
2007 Ford F-150 SuperCab.
2010 Touareg TDI
GolfStream is offline   Reply With Quote
Old 02-18-2010, 02:53 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I don't do Fords
I am a GM man myself. Perhaps you can get something out of my tale:
Many years ago, my wife's Yukon chewed up a rotor after the wear sensor on some aftermarket front disk brake pads I installed fell asleep at the helm. For good measure, I replaced both front rotors with what the local autoparts chain store was selling.
Within 6,000 miles the steering wheel started vibrating during braking.
The rotors were then replaced with [spendy] Wagner, OEM rotors. And Wagner pads. She never had another problem.
As 87MH would say, "Suck it up, spend the bucks, do it right the first time."
Tom
Old 02-18-2010, 02:59 PM   #3
can't finish anyth
GolfStream's Avatar
Dallas , Texas
Tom!
Thanks so much and I'm with you. Now that I'm out of warranty, I'm the type of guy to upgrade the safety stuff as much as possible.
That's ok... Not everyone can be a Ford Man. =)
Cheers,
Javier
Javier
Dallas, TX
2010 Touareg TDI
Old 02-18-2010, 03:19 PM   #4
TomW's Avatar
1967 26' Overlander
Another Great Mind
Funny - I was pitying you, too!
Tom
Old 02-18-2010, 03:39 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Warped rotors are pretty common on the late model Ford trucks.
Brembos and Wagners seem to be the aftermarket rotors of choice. I went with some generic rotors from NAPA and semi-metalic pads. They're inexpensive and they deliver to the shop. (Discount and, I'm lazy too). 2 years and no problems. The trucks not a daily driver but hasn't developed any hard spots on the rotors from sitting.
FYI if you’re planning on doing the work yourself the rotors are very prone to sticking on the hubs.
If you want your head to spin go over to Ford Truck Enthusiasts. http://www.ford-trucks.com/forums/916610-warped-rotors.html
Good place to find out about all the quirks of your TV.
Good luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Replacement Brake Assembly Jake Brakes & Brake Controllers 15 09-16-2009 09:15 PM
brake replacement parts watt1968 Brakes & Brake Controllers 5 07-03-2008 07:17 AM
Replacement Electric Brake Assemblies Ken10 Brakes & Brake Controllers 3 10-18-2006 07:22 PM
Cracked Front Wheel Rotor LALandyacht Mechanics Corner - Engines, Transmission & More... 2 03-18-2005 05:39 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
