11-08-2014, 08:19 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Best Diesel Truck Forum for Dodge and Ford?
I am contemplating/studying buying a diesel 3/4 ton truck. I am evaluating Dodge and Ford. I'll need to decide if I should go new or used and also Ford or Dodge. I lean toward Ford for body and chassis. I lean to Dodge for the Cummins engine.
So which are the best Discussion Boards/Forums for Ford and Dodge diesel trucks respectively? Obviously I can search the web and come up with at least 20 within seconds but looking for your insights. Thanks
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
11-08-2014, 09:12 AM
2009 30' Classic
Melbourne, FL
, Searsport, ME
I like this one for Ford trucks. It has a large number of members and followers:
www.ford-trucks.com
11-08-2014, 09:24 AM
2007 30' Classic S/O
Somewhere
, South Carolina
http://www.turbodieselregister.com/forum.php?
For Dodge I'm a member at TDR. A bit more conservative than it was years ago, interest is now in making them last and learn them not go fast.
Make your own decision but make it your decision not one forced on you. The Ford 6.7L that my camping buddy has is incredible, until you open the hood. It is a real turn off for me that you have to pull the cab on late model Fords to do any major engine work.
11-08-2014, 03:49 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I use the Ford Powerstroke forum. It isn't just everything, but I like the 6.7 scorpion section.
David
11-08-2014, 07:51 PM
2014 27' Flying Cloud
Wenatchee
Cumminsforum.com (in addition to TDR) for Ram diesels.
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
11-09-2014, 10:37 AM
2017 23' International
Ridgefield
We have a Ram 2500, 2013, which is rated to tow 17K ##!
Open road, not towing= 22mpg
Towing = 14+ mpg ( only 16K on the odometer)
The turning radius is shorter with the Ram than the Ford...we have owned both!
11-09-2014, 04:16 PM
Lower Alabama
, USA
So Zigi - did you use any diesel truck forums to make your decision? If so, which ones?
Alan
Air #64439
11-09-2014, 04:27 PM
1994 30' Excella
alexandria
, Kentucky
I belong to the TDR forum and cummins forum for Dodge trucks. I find the TDR forum has more mature people but there can be good info on both. One of my good friends has a ford and likes the ford truck enthusiast forum.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
11-10-2014, 04:40 AM
belen
, New Mexico
Had a 97 Ford and a 93 cummins. Towed a 79 ambassador with them both. Each pulled like a dream and got about 20mpg. The ford had more bells and whistles and was 4Wd.
I second the turning radius on the FORD as WAY better! The newer ones have more emissions crap to deal with and get worse mileage as a result.
11-10-2014, 04:44 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
The DieselStop is a decent all around forum for diesel trucks.
Aaron
WBCCI #XXXX AIR #2495
11-10-2014, 05:38 AM
Mantua
, Ohio
Your talking about twenty year old vehicles, lots have changed.
11-10-2014, 05:41 AM
2012 30' Flying Cloud
Lake St Louis
, Missouri
X2 for the Dieselstop mentioned by wahoonc.
Barry
WBCCI 11988
11-10-2014, 06:57 AM
Lin
, Ne
So with a new Chev you will get the best of both worlds?
11-10-2014, 08:06 AM
, Kentucky
Ford-Powerstroke.Org, PowerstrokeArmy.com, The Diesel Stop
Larry
Hope to be an Airstream owner Sooner than Later.
Tow Vehicle-2013 F-250 6.7L Powerstroke Turbo Diesel 400HP/800LB-FT TQ
"One Day Closer To My Dream!" :-)
Retired U.S. Navy
11-10-2014, 11:26 AM
Vintage Kin
Fort Worth
TDR and CF.
Contributors (among others)
cerberusiam
ah64
jelag
joe donnelly
bill stockard
steelhead
are all reliable and well-read on the subject of CTD trucks (and usually on both forums. Read their posts if interested in the nuts & bolts of a question on 3rd Gen trucks [2002-2009]. Ask them who they read for 4th Gen)
