Old 07-06-2013, 02:53 PM   #57
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Originally Posted by Luigi123 View Post
Help. Do I need to trade my 2011 F150 6.2 Platinum in on a new F250 diesel to handle a new 2008 30ft Classic Ltd AS. I know the engine strong enough but concerned about the suspension.
Actually, no. Instead, you should sell me the Platinum for $500 and then go buy the diesel.
Old 07-06-2013, 03:30 PM   #58
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Probably not but that diesel sure is nice
urnmor is offline   Reply With Quote
Old 07-06-2013, 05:26 PM   #59
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
No. That truck will do just fine. Note my avatar and signature.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-12-2013, 05:20 PM   #60
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Luigi', have you checked the tow ratings for your suspension? They should be in the owner's manual.
Gene
Gene
Gene is online now   Reply With Quote
Old 01-22-2014, 04:02 PM   #61
2014 22' FB Sport
Atlanta , Georgia
Toyota Tacoma--tows up to what size?
I have a 2008 Toyota Tacoma "access cab," 2wd, 6 cylinder, towing package, towing capacity of 6500 lbs. I thought that my absolute limit was a 23 foot AS, but that to be safe, the 20 footer was the most appropriate bet. But after reading all this, I'm wondering if I was too conservative.
We like to go camping in places like West Virginia, the Appalachians, etc.: small roads, steep grades.
Any advice much appreciated.
(This is only my third post. Is it in the right forum? I'm not sure I understand the structure yet.)
Belbein is offline   Reply With Quote
Old 06-27-2014, 10:59 AM   #62
2015 16' Sport
2015 Interstate Coach
Burnsville , Minnesota
When you're looking for a vehicle to tow your Airstream, you can type the year, make and model of your prospective vehicle into this form at ReeseHitches.com to find out towing information: Trailer Hitches | Reese, Drawtite, Curt and more
nate_053 is offline   Reply With Quote
Old 09-17-2014, 02:51 PM   #63
2015 27' Flying Cloud
Washington , Washington, D.C.
You should check your F150's GVCWR and it's GVWR. You would definitely need to have the "max payload package" which increases your GVWR to 7800 lbs. and your cargo capacity to something like 1800 lbs. The fact that your truck is rated to tow the 10000 lbs. GVWR of the AS is less important than whether you are exceeding your gross vehicle combined weight rating or your truck's overall capacity. That affects truck handling and braking. If you've ever watched the videos of pick ups pulling trailers up and down the I-70 grade to the Eisenhower tunnel in Colorado (shown by The Fast Lane Truck.com) you'll understand that the trailer brakes don't do that much work in stopping or slowing the trailer. (You'll also understand why people tow with diesels. The gas engines spinning at 4-5,000 rpm to develop their power make quite a racket, compared to the diesels spinning at half that speed doing the same job.)
IIRC, when I was researching combinations of AS trailers and tow vehicles, I believe the Classic 30 exceed the gross combined weight rating of any model of the F-150. We bought a new FC 27 and will probably pull it with a new Silverado or Sierra 1500; but the F150 with max payload would work, too. The issue isn't the trailer's 7600 GVWR, it's the 800 lb. tongue weight (empty) plus about 500 lbs. of passengers and dog plus the stuff in the bed, like generators, fuel, tools and so on.
DC Bruce is offline   Reply With Quote
Old 09-21-2014, 10:39 AM   #64
gomotomoto's Avatar
Longport , New Jersey
2003 sequioa with ProPride hitch. Can I tow a 1964 28' airstream? 4300lbs as the trailer sits. Safe or no?
gomotomoto is offline   Reply With Quote
Old 09-28-2014, 09:55 AM   #65
1965 mustang's Avatar
Stoughton , Wisconsin
Yes. I have a 05 tundra ( same truck if you have a 4.7 liter) with pro pride. I tow an 05 safari 25 ab witch is about 6300# . My truck has the tow package with class v hitch. Toyota says 7800# max trailer weight. I use a prodegy brake control. We just put 2300 miles on going around Lake Superior. Great trip and the setup handled beautiful. At the start I wasn't sure that we had a big enough truck, but we didn't have any problems. I really don't see any point in buying anything else, unless I could find something that gets better than 10 mpg towing. For the price of a new truck I can buy a lot of fuel.
1965 mustang is offline   Reply With Quote
Old 10-22-2014, 03:33 PM   #66
2014 19' Flying Cloud
Eugene , Oregon
We tow our 19 Flying Cloud with a Toyota Highlander with the factory towing package. We are amazed at how easily this vehicle handles the task. The gas mileage averages around 16 mpg going over passes, up and down. This model has the 3.5 V6. We did considerable research with Toyota and looked at articles in Trailer Life, as we were skeptical. We originally purchased the Highlander in 2013 to haul our 2,000 lb boat & Trailer. The 19 Bambi weighs in around 4,000. Capacity is listed at 5,000 for the Highlander.
Dave-Nancy is offline   Reply With Quote
Old 05-09-2017, 12:36 PM   #67
Idaho Falls , Alabama
Does anyone have an idea for after market tow mirrors for a 2015 Jeep Grand Cherokee? We have some temp ones but I am tired of not being able to see down myleft side when we have to hop the freeway.
AbbottAir is offline   Reply With Quote
Old 05-11-2017, 05:54 AM   #68
urnmor's Avatar
Berlin , Maryland
I love my f250 diesel for towing especially on hills
Old 05-13-2017, 03:53 PM   #69
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Look on amazon. Seems like they have everything except firearms.
KK4YZ is offline   Reply With Quote
Old 07-08-2017, 05:59 PM   #70
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
Two Wheel Drive, Auto, or Four Wheel Drive
Here's a VERY basic question. My tow vehicle has the option of 2WD, Auto, and 4 WD. What's best for towing a 27' Airstream? Thanks.
Mike G is offline   Reply With Quote
25' Flying Cloud FB Twins Al - K4GLU Off Topic Forum 7 02-11-2011 12:36 PM
