Old 09-28-2015, 04:03 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Barely got 110,000 miles out of these brake pads after towing with my half to...
Name:	ImageUploadedByAirstream Forums1443477806.508717.jpg
ID:	249235Click image for larger version
Name:	ImageUploadedByAirstream Forums1443477825.919327.jpg
I barely got 110,000 miles out of these brake pads after towing with my 1/2 ton, why do these wear so quickly?
Brevi tempore!
Old 09-28-2015, 04:23 PM   #2
1981 31' Excella II
New Market , Alabama
They don't even look worn out.
Perry
Old 09-28-2015, 04:38 PM   #3
1994 30' Excella
Mississauga , Ontario
sounds like you have a heavy foot on the brake! Ha Ha.
Al and Jean
TAC ON-3
Old 09-28-2015, 06:48 PM   #4
1979 23' Safari
Wayland , New York
110k on brake pads sounds pretty good.
Old 09-28-2015, 06:52 PM   #5
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
that is unheard of.. 100 k on brake pads pulling a trailer.. either you see stop lights for miles ahead and let off the gas or your trailer brakes are wearing out after 10K miles..
It hard to do that on a car much less a truck. good one.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-28-2015, 06:56 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I had a 1990 Ford Ranger that I put 120k on without ever changing the pads. Only thing I ever replaced was the muffler on that truck. Sends most folks' BS meter into the red zone when I tell them that story. All truth.
www.nesa.org
Air No. 6427
Old 09-28-2015, 08:08 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I pulled my trailer with a 97 Ford 150 a couple of times. I had to change the front rotors after each time. Do you live in flat land?
Old 09-28-2015, 08:37 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Lots of miles between AR, NM, and AZ.
The biggest grade I have navigated (several times now) is a fairly long 8%er south of Globe AZ on hwy 77.
I do like to feel my trailer brakes at every stop. Those brakes came on the truck, I took them off today with 118,000 miles, I think I might have been able to squeeze another 20,000 out of them.
The trick is, in my opinion of course, to avoid hard stops and to go down a hill at a speed that only requires intermittent, fairly light, and brief brake applications. It is all about pace and anticipating what is coming next.
Brevi tempore!
Old 09-28-2015, 09:26 PM   #9
Wolf Alaska's Avatar
Madison , Alabama
I replaced the brake pads on my Excursion @ 125,000 but it was preventative maintenance. Big Ford trucks have good brakes, but I don't use them much. Sadly, I had to replace the front calipers at 132,000 miles in Pensacola this winter, as the front was pulling when I applied the brakes. New pads were still good, so they are now in the new calipers.
Let's Roll !
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 09-28-2015, 10:43 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yeah, I use normal deceleration and engine braking a lot.
Also, proper "break in" of the new brakes are KEY to longevity!!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 03:44 AM   #11
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'm due for brakes on my car. What is proper break in?
I'd love them to last longer than they do.
Dingo Girl is offline   Reply With Quote
Old 09-29-2015, 03:57 AM   #12
r carl's Avatar
Lin , Ne
5 moderate to aggressive stops from 40 mph down to 10 mph in rapid succession without letting the brakes cool and do not come to a complete stop. If you're forced to stop, either shift into neutral or give room in front so you can allow the vehicle to roll slightly while waiting for the light. The rotors will be very hot and holding down the brake pedal will allow the pad to create an imprint on the rotor. This is where the judder can originate from.Then do 5 mod­erate stops from 35 mph to 5 mph in rapid succession without letting the brakes cool. You should expect to smell some resin as the brakes get hot.After this is complete, drive around for as long as possible without excessively heating the brakes and without coming to a complete stop (Try for about 5 minutes at moderate speed). This is the cooling stage. It allows the heated resin in the brake pads to cool and cure.After the brakes have cooled to standard operating temperature, you may use the brakes normally.
Old 09-29-2015, 06:34 AM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Many years ago my Uncle Billy told me the way he would break stuff in.....
Upon starting break in, drive it just like you are going to drive it, proceed with this procedure for the life of the vehicle.
This has been working for me for about 35 years now.
If a person goes through a lot of brake pads;
A. The car is driven hard with lots of hard braking.
B. The pads used are not very good.
C. The car is driven hard with lots of hard braking.
If a person often sees lots of black dust on their front wheels see A and C above.
Brevi tempore!
Old 09-29-2015, 10:16 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yup... see above!
http://www.ehow.com/how_7518438_brea...rake-pads.html
and as mentioned above:
http://www.powerstop.com/brake-pad-break-in-procedure/
Now, I do this all 'in the country'... I once lived in the country but the 'city' has 'improved' around me... so, it takes a little drive to get there...
I 'brake' using downshifting... coasting to stops (really upsets the Hybrid drivers behind me)...
I use the 'brakes' mildly then NEVer hold the car with them until break in complete. I use the clutch/ shift in/out of gear..
Once in the country, I proceed as above.. then drive at a moderate speed to cool the brakes.. then repeat the process...
The whole process is to 'transfer' brake pad material to the disc, then allow heating/cooling of the parts.... then cycle it at least 3 times... heat, cool.. repeat.
The brakes will work their best from now on...
NOTE.. when/if you have a 'hard/panic' stop, try to heat then cool the brakes again so that you 'balance' the brake material across the disc.
Channing
WBCCI# 30676
Refueling: GASOLINE TANK- Half EMPTY or Half FULL? Ray Eklund On The Road... 33 06-12-2015 06:54 AM
Half polished. Half arsed.... gomotomoto Our Community 9 11-22-2014 04:41 AM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
28,000 or 128,000 miles? jimelmoreiii Mechanics Corner - Engines, Transmission & More... 8 01-11-2004 07:16 AM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
