Old 07-30-2010, 09:50 PM   #1
1990 34' Limited
Duluth , Minnesota
Bad Gas mileage on my dodge diesel
I am a brand new airstream owner (today!!!), and have only owned my 2004 Dodge Ram Quad Cab with the 5.9 cummings diesel (81000 miles) for about a week.
Picked up my 1990 34ft Limited today in Madison, WI and pulled it home to Duluth, MN. I have been getting 18-19mpg with my truck on highway (68-75mph) without the AS. I was only getting 9 miles per gallon on the way home today pulling my 34 footer at 68-72 miles per hour in over-drive. Not much wind.
Had all 6 wheels pulled off the AS, bearings assessed and greased prior to leaving Madison.
THE QUESTION: What kind of mileage do you get with your TV? I was expecting 12-15 miles per gallon? Any thoughts?
Sorry if there is alot of info on this already--couldn't find anything when I searched.
triple axel is offline   Reply With Quote
Old 07-30-2010, 10:01 PM   #2
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
If you are watching the overhead mpg readout it is not accurate. The only way to know fuel mileage is to hand calculate.
It is very possible to only get 9 mpg pulling at that speed with a stock truck. Adding a downloader or power box will up that figure some.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 07-30-2010, 10:13 PM   #3
1990 34' Limited
Duluth , Minnesota
And those figures are based on the overhead readout.
Just to add... it is a 2500 3/4 ton.
Old 07-30-2010, 10:18 PM   #4
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
So 9-11 that is the deal.
NashBuff is offline   Reply With Quote
Old 07-30-2010, 10:22 PM   #5
_
hi axel
welcome
this question and issue has been addressed often.
of course EACH tow vehicle may be different.
IF you wanna know what the mopar/cummins guys get specifically...
check out one of their enthusiast forums for a LOT of mpg reports.
lots here too...
http://www.airforums.com/forums/f238...age-21229.html
http://www.airforums.com/forums/f463...s-18186-2.html
http://www.airforums.com/forums/f463...mpg-65624.html
http://www.airforums.com/forums/f463...eage-9778.html
http://www.airforums.com/forums/f463...age-13435.html
http://www.airforums.com/forums/f463...cle-46812.html
http://www.airforums.com/forums/f463...icle-9919.html
http://www.airforums.com/forums/f42/...cks-40195.html
wanna a easy reliable BOOST in mpg...
http://www.airforums.com/forums/f463...ree-41047.html
http://www.airforums.com/forums/f161...uel-42561.html
or how bout some gimmicks and snake oils?
http://www.airforums.com/forums/f463...5-a-62852.html
http://www.airforums.com/forums/f438...uel-27885.html
http://www.airforums.com/forums/f238...ves-59278.html
cheers
2air'
Old 07-31-2010, 06:30 AM   #6
1990 34' Limited
Duluth , Minnesota
Thanks for all the links 2air. I need to practice with my search techniques on this forum. Still getting used to it.
And I should slow down a little bit as well!
Old 07-31-2010, 06:40 AM   #7
Baltimore , Maryland
I just bought a 2003 3500 long bed 4 door and got the same results as you. I stopped turning the over drive off while towing and my milage went up dramatically. I know it is recommended to tow without overdrive, but I see zero change in shifting on big hills and the added milage makes a big difference.
Old 07-31-2010, 06:54 AM   #8
1966 20' Globetrotter
1993 34' Limited
Hugo , Minnesota
We're pulling a 1993 34 Classic Ltd. w/ a 1998 Dodge Cummins 32V. w/105,000. Get 14-15 mpg in OD almost all the time on flat ground (like out the the Black Hills, etc.) Regular as clockwork; almost always 14.something. However, I usually get 19-22 without the trailer. Yours sounds a little low for a Dodge Cummins engine. I don't use OD on hills w/cruise control though. I have a really heavy sprung 2500 2WD, seems highway geared to me. Just for ref for ya.
fstuneck is offline   Reply With Quote
Old 07-31-2010, 06:59 AM   #9
2007 31' Classic
holland , Pennsylvania
it depends what rear is in the truck.it sounds like you may have a 410 rear which equates to this kind of mileage.my stock 2005 excursion diesel gets between 11.5-13.0 towing depending on speed.my truck has a 373 rear gears.i tow with tow,haul mode which has overdrive.gcwr with truck and trailer is approx 18000lbs.
xonvldz is offline   Reply With Quote
Old 07-31-2010, 07:01 AM   #10
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
Overdrive
I've been towing in the Ozarks this summer -- very steep, short grades. In the "tow mode," my transmission temp stays in the normal range, 180 to 200 degrees. I lost a transmission in the same Ozark hills in a Ford Expedition pulling a 4,000 lb boat with the overdrive on. So I keep the overdrive off, accept the lower MPG, and save the transmission. Best wishes, John
JBinKC is offline   Reply With Quote
Old 07-31-2010, 08:03 AM   #11
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Tripple
IF ya wanna get fuel mileage ya gotta get your toes off the fan. Slow that thing down to 60 to 65 mph . Easy away from dem traffic lites and STOP signs. I think you are trying get that Cummins to perform like a gas job and its tellin ya it aint a gonna do it. IT shows it in the fuel mileage.
Keep the RPM's down to 16 to 18 hundred and see the difference. I have driven diesel engines for almost 50 yrs , I do believe I can see the signs. As you can see by the profile we have an F350/7.3 liter Harvester Diesel and it gets 14 around town and 20 highway NOT TOWING. The average towing is 15 to 17MPG depending on conditions.
SLOW DOWN ENJOY THE RIDE and save some money on fuel while you are doing it. Start a little earlier then ya dont have to hurry so fast.
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-31-2010, 08:20 AM   #12
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
triple axel, is your truck a stick or auto? What rear end ratio? I can help you get better mpg's if you want.
Godspeed,
Trent
Old 07-31-2010, 09:11 AM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
60 mph is The Brick Wall where aerodynamic resistance is the single worst factor.
You'll want to know which engine: mine is a 2004.0 with the 305/555 ISB. Yours "may" be the 325HP motor (which adds an extra injection event and features internal changes as well). The 5.9 Cummins "peaks" for fuel economy on the third generation trucks (HPCR: High Pressure Common Rail) in the 2003-2004.0 period. The 2004.5 begins a slight downward trend as emission controls take force (the 5.9's are better than the 6.7's in re mpg).
The trick to a diesel is to give it what it wants (not what the driver wants) and use as little fuel as possible to get to the correct gear. I keep mine between 1700-1900 rpm for all driving (manual trans) and see high mpg while solo.
I also change air/fuel/oil filters at 6k/6mos during an oil change. Or, if all highway miles I change the fuel filter at 6-7k. Change it often is the point, as the engine is sensitive to either air or fuel filters being dirty. I can do it in about 5-minutes, so I recommend getting the tools/fittings to keep in a dedicated toolbox onboard, as well as 1-2 spare fuel filters (BALDWIN FP7977 ONLY!). Your truck "may" have been converted to an intank fuel pump, so check for this as it tends to be more reliable than the engine mount pump.
Go thru alignment, brake drag, correct WDH rigging, etc. Fuel economy means chasing down all the possible mechanical details. A nose-high truck will do poorly, for example.
Good luck.
I believe this is the best place to start:
http://www.airforums.com/forums/f238...-in-17984.html
Old 07-31-2010, 09:40 AM   #14
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
triple axel,
Welcome to Airforums.
If you would provide the details of your truck, trans, axle ratio etc that will help narrow this a bit.
My .02$.
The overhead figures should not be used for discussion, use consistant fillup techniques and actual hand calculated MPG numbers.
Any comparison to a different make, or even a different engine series 5.9L 12V, vs. 24V vs. HPCR will only add confusion to this. The Q. is, is your truck getting mileage that similar Dodge Cummins trucks get?
Also details about any mods to your truck or tires all become interesting things to know.
I'm not reporting any mileage on my rig because I have not driven it enough fully loaded to offer any figures. I do get 19 easily on my empty daily commuting. 93,000 miles on my '05.
I'm sure that getting a loaded weight or your rig will be of interest.
There are several dedicated Dodge Diesel forums.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
2008 Dodge Hemi 4x4 Pick up 1970 Safari gas mileage drm101 Tow Vehicles 3 08-12-2009 06:11 AM
Eco-Responsibility: Veggie Diesel? Better gas mileage TV? jolttx Tow Vehicles 10 03-16-2009 01:10 PM
Need Dodge diesel info. Davis Tow Vehicles 11 12-17-2007 06:23 PM
Dodge Ram 2500 Diesel Foiled Again Tow Vehicles 23 10-18-2007 09:01 AM
What's your Gas (or Diesel) Mileage? 85MH325 Tow Vehicles 29 04-04-2004 06:40 AM
