Old 12-12-2016, 10:45 AM   #1
Ron and Lilla McClendon
2013 27' FB International
Watkinsville , Georgia
Backing a trailer down a curving driveway
We are Newbies as of this summer and have a 2013 27' FB International Serenity and 2016 F-150 Ecoboost 4X4. We would like to keep the trailer at our home but it currently is in the driveway partially blocking our garage. We have a driveway down to our shop garage which turns as shown in the attached photo. I need to know if we are making a big mistake in moving the trailer down this driveway. I plan to have two spotters making sure no part of the trailer hits bottom and go very slowly. I have removed the weight distribution hitch and will put on a standard ball mount with 2 5/16" ball to increase clearance under the tongue.
Will this put a strain on the trailer frame or structure or cause other problems I haven't anticipated?
Thank you for your responses and for all the extremely valuable information we have gained from the Forums.
Ron
RonMcMusic is offline   Reply With Quote
Old 12-12-2016, 10:49 AM   #2
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Don't think your picture made it, but those two spotters will help any situation. Keep in mind that more hitch clearance = less "back of trailer" clearance. They'll be traveling over the same ground, but the 150 probably squats a good bit before the WD hitch. Sounds like you'll be leveling things out for the maneuver.
DaveMc is offline   Reply With Quote
Old 12-12-2016, 11:03 AM   #3
Second attempt at including photo.
Old 12-12-2016, 11:22 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Not using the WD hitch is not an issue.
I am including a link to the best trailer backing video of all time. Make sure you have your written backing instructions to refer to while you are backing. The video also demonstrates the Murphy's Law collorary if two spotters are better than one, then more is better than two.
https://youtu.be/U6CbffjZ6fI
Old 12-12-2016, 11:23 AM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Some people put a hitch receiver on the front of their TV to make this type of manoeuvre easier.
Ray B.
Adventure.AS is online now   Reply With Quote
Old 12-12-2016, 11:35 AM   #6
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Ron-
Even with our limited view, that looks do-able. I might get hollered at here, but I'd also not connect the trailer umbilical to the truck. Sometimes low speed, twisting, turning backups get more complicated when the truck controller keeps putting on the trailer brakes for you. Try it both ways, but you might like it with truck brakes only.
I agree with the ball mount only idea, and you'll have to really watch when the coach is in a twist and your truck breaks over the crest of that hill. Oh, and work out your hand signals first, tell your spotters if they can't see you in the mirrors you can't see them, and taka you time.........
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 12-12-2016, 11:36 AM   #7
Sphere Guy's Avatar
Livingston , Texas
Should be doable. Practice, practice, practice.
It looks like that you will have a hitch clearance once the TV gets down on the hill.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 12-12-2016, 12:05 PM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Looks doable.
Hug the inside curve with the trailer tires as the front of the truck may go off the concrete.
As suggested above review hand signals with your spotters. One good spotter should be adequate.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 12-12-2016, 12:05 PM   #9
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
It's a piece of cake...... go for it!
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 12-12-2016, 12:12 PM   #10
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I have a slightly similar backing challenge. You'll mostly loose sight on the drivers side as you go down and turn.
Use your pass side mirror adjustment to keep it in sight.
Slow and easy.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 12-12-2016, 12:13 PM   #11
Kingston , Georgia
One suggestion that could help. You need to focus on only one part of the AS, in this case the wheels on the inside of the curve, the passenger side. These tires should always be close to the edge of the pavement while far enough away to miss your house. That will give you more room to maneuver the truck. So, you're number 1 spotter will be on the passenger side and you are talking to him. The number 2 spotter is more for making sure everything is okay on the off-side.
randyc is offline   Reply With Quote
Old 12-12-2016, 12:14 PM   #12
palm beach gardens , Florida
that is a great video!!
m rafferty is offline   Reply With Quote
Old 12-12-2016, 12:17 PM   #13
HeavyMetal's Avatar
2008 23' Safari SE
White Rock , British Columbia
Cell phones as walkie talkies
A trick we also use - is to have the spotter phone your cell phone in your vehicle (driver is hands free or speaker on) to give verbal directions for those moments when they are hidden behind the trailer or trees etc. Your could conference-in both your spotters so everyone can hear?
HeavyMetal is offline   Reply With Quote
Old 12-12-2016, 12:18 PM   #14
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
x2 what randyc said. I was in the process of adding a comment that said the same thing.
Just go slow and use your spotters.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-12-2016, 12:45 PM   #15
2014 25' Flying Cloud
Temple , Texas
the hardest part is backing down slope and keeping your TV on the concrete. Slow and easy pull forward a little then back up some more. Watch your choice of words. I have a long (180 Feet)narrow drive way but no curve like that to negotiate but I still have to pull up a couple of times to keep it on track.
2014 Flying Cloud 25FB
2018 Ram 2500; Diesel
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 12-12-2016, 12:45 PM   #16
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
For ~$150 you can fit a front receiver on your TV ... money well spent!
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 12-12-2016, 01:00 PM   #17
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
Looks doable like the others have said. Go slow. I had to put a wood ramp on mine to get up on to my driveway. It is heavy duty, but also very heavy, but needed so my "trailer butt" clears it.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 12-12-2016, 01:09 PM   #18
2010 25' FB Flying Cloud
Tulsa , Oklahoma
Ok, I'll add one more piece of advice.....
Remember that if you get in a bind, you can always unhitch and re-position the tow vehicle at a straighter angle and then re-hitch and continue on.
rlhendren is offline   Reply With Quote
Old 12-12-2016, 01:09 PM   #19
1989 25' Excella
Albemarle , North Carolina
backing down a curved driveway with airstream
I would hire a mobile home delivery firm to put that camper where you want. They have low and high hitch levels which can do the job. If they are nearby cost should not be a problem. 21 ft 69-26 Ft 76argosy 25 ft excella.
eldin is offline   Reply With Quote
Old 12-12-2016, 01:12 PM   #20
albuquerque , New Mexico
RIGHT TURN, Clyde !!!
splintair is offline   Reply With Quote
Goin' down, down, down... Aironius Axles 12 08-23-2014 09:09 AM
Awnings: are they really up/down/up/down ... Belbein On The Road... 6 06-08-2014 02:55 PM
Backing into my driveway--A hearty thank you! Belbein On The Road... 7 05-30-2014 02:21 PM
Backing-into-the-driveway strategy Belbein On The Road... 40 03-29-2014 11:31 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 09:15 AM
