Old 02-02-2006, 10:19 AM   #1
ifly4cal's Avatar
1975 31' Sovereign
1973 Argosy 26
hewitt , New Jersey
Avalanche 1500
Hello Everyone,
I am looking for a new tow vehicle. Interested in Chevy Avalanche 1500 1/2 ton 5.3L. I have a 1975 Sovereign, my dry wt 4970 and hitch wt 690. Do you think this truck will do the job for me?
Opinions?
Tim
Ifly4cal@enter.net
ifly4cal is offline   Reply With Quote
Old 02-02-2006, 10:32 AM   #2
JimGolden's Avatar
1977 31' Excella 500
Probably OK
Hi there,
I tried to copy paste a chart off Chevy's website for you but it didn't look right.
They say a 1500 2WD with 3.42 axle can pull 7300lbs max, and 8200lbs with a 4.10 axle.
A 1500 4WD with 3.42 can tow 7100lbs and 7900lbs with 4.10
A 2400 4WD with 3.73 can pull 10,200lbs and 12,000lbs with 4.10.
Take care,
- Jim
JimGolden is offline   Reply With Quote
Old 02-02-2006, 10:39 AM   #3
basecamp's Avatar
1996 30' Excella
Bowmanville , Ontario
Order it with the 4.10 axle, you will be surprized how well it will tow. I had a 2003 with a 4.10 pulling a 96 30' classic. You will loose a tiny bit on gas mileage however I think the 4.10 is a better ratio for an already heavy truck. Go to the avalanche forum, it is a great truck. Wish you could get a 3/4 ton with a Duramax(GM doesn't make it), that would be my ideal truck.
Hensley Hitch, Jordan controller
basecamp is offline   Reply With Quote
Old 02-02-2006, 12:05 PM   #4
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
I would not recommend the 5.3l with the 3.73 rear end based on my experience with a 2001 Yukon( similar set up) My 21ft. Sovereign weighs about 5000lbs fully loaded. Flat geography no problem, but mountains and hilly terrane are another story! The truck needs to work way to hard, which in turn makes the journey less than fun. A 4.10 rear end would help a lot, but that combo is not that easy to find. I ended up moving up to a truck with a 6 liter engine and a 4.10 differential. Big difference!! You will not regret having more power!
Juergen
jhart657 is offline   Reply With Quote
Old 02-02-2006, 01:27 PM   #5
Images: 59
I heard today that GM will be introducing hybrid SUV's (Tahoe, etc) next year. The pitch says they will be up-rated for higher towing capacity. Time will tell.
Old 02-02-2006, 01:48 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
You'd prob be ok with that setup. As has been pointed out though in the hills or mountains, you may find you're a bit short on what you need when the trailer is loaded and you have gear and passengers in the truck.
I think if you did do it, 4.10s would be your best shot, but I still think that 4.10s and a 6.0L in a 3/4 ton will serve you better in the long run. Why? Well for starters the 6.0L has more meat, second, the 3/4 ton has upgraded trans and rear end, and brakes (from what I understand). I am not sure the cost difference ($4500 new) is great between the two (1500 and 2500), yet ask those who came from 1/2 ton to 3/4 and most will tell you it's a night and day difference.
As I said before, you'd might be just fine, but for $4k new, I'd go 2500 6.0L w/4.10s. I'd expect pre-owned to have a similar cost difference between the two.
Old 02-02-2006, 04:51 PM   #7
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
I guess I go by the old adage, "You can't have too much truck."
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup,
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-03-2006, 09:07 AM   #8
ifly4cal's Avatar
1975 31' Sovereign
1973 Argosy 26
hewitt , New Jersey
Avalanche 1500
Thanks everyone for your input. I really appreciate all the comments and the pros and con. You all were a really big help!
Tim
Ifly4cal
Old 02-03-2006, 08:20 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If you like the Avalanche, you will definately be more pleased with the 2500 Avalanche, 6 litre engine and the 4.10 rear end. It seems that particular engine likes to rev and performs so much better with the 4.10 than the 3.73 rear end. You won't have to worry about hills compared with the 5.3 engine and the 3.73 or 4.10 rear end.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-03-2006, 09:47 PM   #10
basecamp's Avatar
1996 30' Excella
The 2500 Avalanche only comes with a 8.1 litre gas engine. glug glug, I wouldn't want to feed it...
Old 02-04-2006, 12:00 AM   #11
Aluminut
2004 25' Safari
. , Illinois
I didn't know that....great info.
Old 02-04-2006, 12:54 AM   #12
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
Basecamp,
Well.....you're right.... it does burn more gas......but after 30 some years of driving 4 & 6 cyclinder engines, I figure I deserve the extra power and comfort ........and......I can't think of a better use for it (pulling my AS)!
Lastly......I can afford it !
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 02-04-2006, 01:32 AM   #13
1992 34' Limited
Falls Church , Virginia
!!!!!!!! 8L vs. 6L !!!!!!!
Bing! The fight is immediately called a DRAW to get the ref out of spitting gange. Crowd decends into a melee that the 'crips' and 'bloods' got beaten out of - they are all hospitallized in several Downtown traumacenters in seperate single rooms. Crips on 8, bloods on 9 - if you wanted to visit. Hours are 9 - 6 M-S, Sun 1-5.
On....to the news of the day.
I bought my'01 2500HD 'Burb on the same day as a friend bought his '01 2500HD. Same assembly shift even! He has the 8.1 / 4.10 and all else is essentially the same. I have the 6L/ 3.73 and all else is essentially the same.
We bought have about 55K on the clocks. He tows a very light trailer about 8 times a month for a day. I pull a 14'er dual axle enclosed Utility trailer about once a month.
He gets 7 3/4 MPG driving around like a Type A - to/from work, business meetings, etc. When he is relaxing and taking it easy he gets 9.9 MPG (NOT 10, which is pissing him off no end). The trailer is negligible when he hauls it.
When I drive around town and all the other 'too numerous to mention' things in my life I get 13.8 MPG. I have gotten 14.9MPG in a tank of gas that consisted of a lot of flat territory and nearly NO mountains driving. And I do live in Mountains with elevations that cover 2ooo feet in one mile and 12% grades are the norm to get to our houses.
When the Airstream gets on the tail of "Kelly" for a romp out into nature. I experience about 11.2 MPG - I averaged that out over a 2 week trip to the Black Hills coming from Iowa and heading thru Denver and over Raton pass to get to Albuquerque.
Now conserning the 4.10 vs 3.73 gears debate. The mileage does suffer when you are hauling, and even when you are NOT hauling. That is not to say that a lower gear can't be a huge help. So can the 4.10.
I have been VERY happy with the 6L and 3.73 choice (Ha!!! They had it on the lot!) and it has serviced us will without so much as even a hichup. Love that truck!!!!
Go out and buy the truck you always wanted!!!!!!!!! Just be sure it can pull your rig! or else that was just a fantasy that is going to cost you dearly at trade-in time. Had a friend that got stunk to the tune of 10K on a trade/ and buy deal. Yikes......
Don't know that I moved any process forward, but hey, I wasn't really trying either.
Ciao
Axel
facor8man@yahoo.com
SilverToy is offline   Reply With Quote
Old 02-04-2006, 05:48 AM   #14
CanoeStream's Avatar
St. Cloud , Minnesota
Need more data...
Good morning Tim -- and welcome to the Forums!
Oh Mama, tell your children .... not to do what I have done .... (where are the musical smilies?)
Your numbers are right off Airstream's empty weights as found at their FAQ page. I would recommend starting at that site and reading further about tongue weight and weight rating.
JimGolden gets better data out of the Chev website than I can. There is a severe obstacle to information if an everyday person can't find vehicle capacities! You should be looking for the Avalanche's "load capacity" (difference between empty curb weight and the GVWR). Jim, can you find that? Then read this post on how to apply that to the real world!
I often see questions about going as high as a 28-footer with a 1/2-ton truck. A 31-footer shouldn't make it any easier. I had a 5.4L Nissan Titan (a 1/2-ton truck, no more, no less - pay no attention to the "advertised" 9000# tow capacity). I swallowed hard, took the hit, and sold it this week. Loading my 24' Argosy and determining the tongue weight took me to the upper end of the Titan's load capacity. The drive train was wonderfully powerful (with the equivalent of a 4.10 rear end) although I did manage to peg the tranny temp gauge in 30-degree weather once in switchbacks on US-50 in NE West Virginia.
Your trailer doesn't have the weight penalty newer trailers have -- my 25' Safari weighs 1000# over what the Argosy did. The new Safari empty puts the Titan just over max TV load capacity. But heck, the older Sovereign weighs about the same as my Safari. Property, insurability* and safety of your dear passengers could suffer severely if the TV load capacity numbers don't add up. My road lifestyle will include bringing the bikes and maybe my 42# canoe. I am going to be much happier .... (going looking at 3/4-ton GMC pickups today )
*after the details of any overload accident get on a person's record.
5 meter Langford Nahanni
Old 02-04-2006, 06:25 AM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am going to "weigh" in here (pun intended) I have a 75 Sovereign rear bath. My real world weight with full LP tanks minimal "stuff" inside is just a shade under 6000# my measured hitch weight is 685#. FWIW the unit GVW is 7200# I strongly suspect that the weights listed on the Airstream site are basic weights and don't include any options, Intenational Package, Vistaviews, etc. I am a Ford man so I am not up to speed on the Chevy availablity. However I slept at a....oops, our company owns several 2500HD 6.0L with the 4.10's. They are a pulling truck. I have towed my Sovereign with a F150 4.6L 3.73. It did just fine, on flat ground. There is NO WAY I would attempt to do this on a full time basis. I believe that Airstreams are one of the best handling trailers on the road and you can get away some things towing them you can't with an SOB, not that you should or that I reccomend it.
Aaron
WBCCI #XXXX AIR #2495
Old 02-04-2006, 06:42 AM   #16
davidz71's Avatar
1986 25' Sovereign
Ciao
Axel
facor8man@yahoo.com
Axel,
I have a '01 2500 4X4 extended cab with 8.1/Allison combo and 3.73 rear end. I get 14.6-14.9 mpg on the highway at 70 like clockwork. I got 10-12 towing a '77 31' Excella before I sold the trailer. The only time I get below 10 mpg is when I run AC and am hitting continuous hilly or mountainous terrain.
Craig
AIR #0078
3.73 rear end
Old 02-05-2006, 09:42 AM   #17
JimGolden's Avatar
Chevy's website is "fun" to try and find some specs. Here's the link to the chart I tried to copy/paste and had to do by hand. Maybe you can find what you need using this as a launching point.
http://www.chevrolet.com/avalanche/specifications/
There are tabs on this page where you can get the engine specs, trailering specs, about all of it. Took me a while to get to here though. The 8.1 does have it all over the 6.0 in torque. 447 ft-lbs to 330. Day to day mileage would surely take a big hit though.
The guys I know with the 6.0 in their pickups say it's a great motor, but they average about 12mpg all the time.
I average about 15-16 with my Cummins in mixed driving; get 21 on the highway. I've only towed the Airstream about 30 miles with it so far, but that was in hilly WV and I still got nearly 16. Was only averaging about 50mph though
- Jim
Old 02-05-2006, 11:26 AM   #18
davidz71's Avatar
1986 25' Sovereign
If that is the case, Chevy has their head up their butt again. The Avalanche 2500 would be a great vehicle with the 6.0 in it and even better with the Duramax with Allison but we know that is not happening at the moment.
Craig
AIR #0078
3.73 rear end
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
Suburban 1500 FiveGreers Tow Vehicles 20 01-23-2006 12:01 AM
2002 Dodge 1500 QuadCab Melvin P. Thorpe Tow Vehicles 15 03-14-2003 01:34 PM
GMC 1500 Z-71 what mods for towing ? Rod Pease Tow Vehicles 5 01-07-2003 01:32 PM
