Old 11-09-2004, 07:55 PM   #29
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john
you call them ferrets, i call them weasels.
Old 11-10-2004, 11:34 AM   #30
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
One last shot
This is the Caterpillar filter that is installed after the switchover valve and is in line with both tanks. There is a thick steel plate in front of the filter to protect it from road debris. This filter is a lot finer than the GM filter in the engine compartment. Hopefully it will pay off in injector life.
It took a while to get all the air out even though I filled the new filter with diesel before installing it. The air was probably in the long lines getting up to the filter.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 11-10-2004, 04:16 PM   #31
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
john
two suggestions.
a mud flap to protect the filter from debris flung from the rear tire, stones flying off the tire could get it.
a bleeder in the line after the filter, you can open it and turn the key on allowing the lift pump in the tank to purge it without starting the truck. i have one of these from the factory on my '97 turbo 6.5. it also doubles as the water drain. makes filter changes easy.
john
Old 11-10-2004, 04:25 PM   #32
Pahaska's Avatar
Hays County , Texas
But ...
Originally Posted by john hd
john
john
There are no lift pumps in the tanks on the current diesels. There is a single pump at the engine and that's it. So the bleeder at the filter (I was aware of it) is useless. In fact, I had opened the bleeder to drain the lines when I temporarily removed the filter to put in the transfer valve.
The only way to purge air is a hand pump on the filter in the engine compartment. There is a bleeder screw there and you push the pump until solid diesel comes out.
John W. Irwin
WBCCI #9632
Old 11-10-2004, 04:28 PM   #33
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
so much for that idea!
how 'bout the mud flap?
john
Old 11-10-2004, 04:36 PM   #34
Pahaska's Avatar
Hays County , Texas
Better idea
john
The filter you see is new. The previous Cat filter was on there for almost a year, almost since the truck was new. I decided that since I had to replumb it, it was a good time to change it. The kit manufacturer recommended a new filter once a year. The old filter can was pretty dirty, but had no noticeable dents or marks from stones.
I had been thinking of wrapping foam around it, though, for some protection.
John W. Irwin
WBCCI #9632
Diesel Mtrhm Data 1995 - 2003 phred Airstream Motorhome Forums 5 08-17-2011 02:12 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
bigger black tank? Stormy Weather 1970-79 Tradewind 8 10-20-2004 08:16 AM
Tank Replacement Lookinghard Waste Systems, Tanks & Totes 3 09-16-2004 11:18 PM
Aux. Diesel Fuel Tank RivetED Tow Vehicles 1 01-22-2004 03:49 PM
