Old 01-22-2004, 03:18 PM   #1
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
Aux. Diesel Fuel Tank
I have an '03 F-250/7.3l diesel crew-cab/short-bed. The facty. tank is only 28 gal, rated. When towing that's about 350 mi./tank. I'd like to have an additional 45 gals. min. What kind of solutions have others found?
RivetED is offline   Reply With Quote
Old 01-22-2004, 03:49 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I know there are bed mounted tanks available. We have a couple of unit members that have them. The exit form the bed mounted tank goes into the OEM tank. You fill the bed mounted one only. I have a Friend in Ocala that only buys fuel in GA. He can get there, get back, run around here and get back before he uses it all.
The biggest drawback on the newer trucks is the computers cannot deal with the tank being full for hundreds of miles, so you would have a cut off valve between the two. Fill them both, close the valve, run for a while then open the valve to refill the OEM tank.
One other option is to replace the OEM tank with a bigger one if possible.
Check out these guys.
http://www.transferflow.com/html/wedge_tanks_0.html
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
