Old 08-08-2011, 01:13 PM   #1
Longmont , Colorado
Audi Q5 3.2 TV
I am a complete newbie. I have an Audi Q5 with a rated towing capacity of 4400lbs and tongue weight of 440lbs. Considering Bambi 16'. All advice welcome.
mikemet is offline   Reply With Quote
Old 08-08-2011, 02:21 PM   #2
Road Ruler's Avatar
Images: 38
Generally speaking, more or less.... the Q5 is a performance SUV that would fall in a similar class as the VW T-reg, Mercedes ML, BMW X3/X5, etc. These are top rated tow vehicles for towing Airstreams.
There are many factors you need to take into consideration to determine your vehicles true capabilities.
Old 08-08-2011, 03:15 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As to the Audi Q5 as a tow vehicle for a 16' Airstream, it should work just fine. You need to get your Audi properly outfitted to tow a heavy trailer. You should start researching weight distribution/sway control hitch systems and trailer brake controllers.
Brian
SuEllyn & Brian McCabe
Old 08-08-2011, 03:25 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Welcome aboard.
In Colorado I would seriously consider a transmission cooler as you will be running an unlocked convertor a lot of the time pulling hills and the trans temp will be effected.
Less serious I would consider an engine oil cooler.
2004 Excursion 4x4
Old 08-08-2011, 03:54 PM   #5
1986 32' Excella
vledder , drenthe
Images: 8
I see a lot of questions about towing a airstream with a european car.
The weight of the airstream may not be the problem.
BUT european cars are NOT build for the tongque weight of a US trailor.
It os mostly 75 kg and 150 kg max.
Also the frame of a european car is NOT build for a WD hitch system.
Remco
remcolent is offline   Reply With Quote
Home Sweet Abby Top On The Road... 61 08-23-2011 09:13 PM
