Old 12-22-2007, 09:49 PM   #1
driverjohnlh's Avatar
1976 Argosy 26
Lynchburg , Tennessee
Astro/safari??
We are between vans right now. We had a raised roof G20 conversion van with 230k miles. We are considering an Astro or Safari. Although I don't have actual numbers, the weight/hosepower ratio seems to be similar during test drives. We would use it more for a daily driver than a tow vehicle so the increased gas milage would be nice. I do have an old pick up that's set up pretty good and use it to tow locally. We don't go very far, usually less than 30 miles with the trailer. I do want the option of going cross country with the van as I love AZ and haven't been out that way in a while. We would not do that trip in summer months though. I know it would need the proper WDH, brake box and fluid coolers. Thanks for all the knowledge and opinions.
driverjohnlh is offline   Reply With Quote
Old 12-23-2007, 02:31 AM   #2
acgypsy's Avatar
Western , Washington
i have an astro which i tow a 20 foot minuet with. it--97 with 193000 miles gets 12 to 15 miles towing. i tow in third gear with 3.73 ratio. trailer weight 2450 dry. loaded its about 3100#. you need to go to Welcome to www.ASTROSAFARI.com and research their towing section. my awd astro weights 2750# front 2360# rear, the tounge weight is about 600# with trailer. good luck, out.........
acgypsy is offline   Reply With Quote
Old 12-24-2007, 09:40 PM   #3
1976 Argosy 26
I'm new here. After starting a new thread, I discovered the other pages of threads. I found at least 3 other threads on this exact subject. I've figured out this combo is borderline. More importantly, my wife decided she wasn't a real fan of their appearance. Thanks for the info.
Old 12-25-2007, 06:13 AM   #4
Well Preserved
overlander63's Avatar
Colfax , North Carolina
You are welcome. You will find lots of opinions about tow vehicles, weight distributing hitches, and axles here.
IF you can talk the wife into it, the Astro-Fari has a tow rating of around 5,000 pounds, depending on how they are equipped.
Intelligence is learning from your mistakes. Wisdom is learning from others' mistakes.
1967 Caravel--Astro jsulli45 Tow Vehicles 12 04-13-2006 07:03 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
Astro & Safari aviontt Tow Vehicles 21 07-03-2004 01:33 PM
Chevy Astro/GMC Safari as tow vehicle generalsparky Tow Vehicles 19 03-05-2003 09:15 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
