Old 09-30-2010, 03:23 PM   #15
_
hi carl
welcome to the forums
and good4u trying to sort ALL of these issues, PRIOR to buying.
i see your questions (in these 2 threads) lumped into 3 general categories...
1. trailer specs, build issues, structural differences and so on...
2. w/d in regard to hitches, calculating vs measuring tongue weight and how that all relates to tv selection.
3. tv ratings, matching tv to trailer and meaningful modifications to the tv that may enhance real world towing.
the tangential issue related to #1 is "what size/floorplan stream do i need"
the tangential issues related to #2 are many and will eventually involve SELECTION of a hitch apparatus.
the tangential issues related to #3 are also many but for now focus on axles, springs and supporting payload.
is that a reasonable summary?
_________
for now this post focuses on #1 with a tiny bit on #2.
#3 and most of #2 will go into your OTHER thread.
http://www.airforums.com/forums/f463...gle-69998.html
_________
u have correctly concluded that the floor plan graphics are improperly scaled.
the LISTED lengths are correct the 27 is longer than the 28.
a/s is well know for doing this, for example classic 30s and 31s are exactly the same length.
they differ by floor plan and the 31/30 tag was a simple way to make that distinction.
the actual FRAMES on 27s and 28s are different.
the 27 as a rear door model has different outriggers and structure around the steps/door.
the 28s as a front door model has specific outriggers and support around the door/step location.
they MAY be other differences, like # of cross braces, outriggers and placement of the axle cut outs.
a/s doesn't make the frames, leland does,
and since heavy things are in different locations it is not UNreasonable to assume frames differ.
the gvwr are diffent, so u might also ask IF the axle ratings are different for the 27 vs 28.
i had a similar set of questions back in 05 when sorting out an order,
http://www.airforums.com/forums/f296...-up-15259.html
http://www.airforums.com/forums/f296...sic-15300.html
http://www.airforums.com/forums/f296...res-27055.html
and only cleared things up, after a few email exchanges with a/s tech/customer support.
the dealer also hounded them about these questions, since i was unwilling to BUY without the details.
LUCKILY 4 me, no one responding here (trying to help) suggested a DIFFERENT SIZED UNIT.
knowing exactly what size/floor plan i wanted was a done deal, so suggesting smaller would not have been helpful.
the printed materials, the website and the actual SPECS for any given unit or year (especially new) don't always MATCH UP.
often the factory web site differs from the dealer pamphlets.
1. contact tech support with your questions about frame/tongue issues, they will tell u the differences between a 28 and 27.
_________
ok now a few notes on #2 above, the w/d issue.
a/s has 4 a long time UNDER estimated tongue weight, leaving out spare tires, lpgas and options.
recently they've started including spare tires and appear to be TRYING to improve published estimates.
still the only real way to know is weighing the tongue, loaded, gased, watered and so on...
steverino' report doesn't mention IF w/d was engaged, and is indirectly estimating tongue weight (that's not a bad thing)
i understand U are interpolating that data to arrive at a higher real tongue weight.
that's fine except the notion of 1/3-1/3-1/3 or 2/3-1/3 is NOT based in reality.
it may have been at one time (i doubt it) when single axle, short trailers and long sloppy sedans were the norm...
the goal of w/d is to RESTORE steering axle loads NOT distribute the tongue equally over all axles.
we can dig further into this later but for now, don't assume a 27-28 has a 12-1300 lb tongue.
cheers
2air'
Old 09-30-2010, 04:00 PM   #16
carl28's Avatar
Colorado Springs , Colorado
2air
thanks for you methodical post. I will absorb this for awhile and perhaps call AS and see what they can say. My guess is the 28 is just a different animal altogether, frame too. But since I wont really know till I get on the scales and on the road for awhile what it means, I will simply go after the floorplan I want - with some wiggle-room-likely-to-be-required in the loaded weights I experience
carl28 is offline   Reply With Quote
Old 09-30-2010, 04:33 PM   #17
_
Originally Posted by carl28 View Post
... My guess is the 28 is just a different animal altogether, frame too...
we agree on this.
cheers
2air'
Old 01-04-2011, 10:50 PM   #18
JFScheck's Avatar
Rockville , Maryland
Images: 33
Scales be our best friend....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Length and weight information StevenG Our Community 9 11-20-2008 10:42 AM
Electrical mysteries mrauch Electrical - Systems, Generators, Batteries & Solar 2 08-06-2008 06:37 PM
Trailer weight Vs length DasAir Towing, Tow Vehicles & Hitches 28 04-08-2008 05:55 AM
GVWR Mysteries ljmiii Axles 7 05-21-2007 03:28 PM
