Old 12-16-2016, 05:18 PM   #1
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Anyone Use Their Engine Block Heater?
Well its going to get down to 6F on Sunday morning. I've got a 2015 Ram 2500 Cummins. Should I plug in my engine block heater on Saturday before the temperatures plummet? I don't plan to drive the truck until Tuesday when the temperatures have come back up to the 40s but lows in the 20s.
Would the engine block heater being connected invite animals to seek shelter?
Kelvin
Old 12-16-2016, 05:26 PM   #2
2012 19' International
Southeastern MI , Michigan
Kelvin
Plug it in about 4 hours before you need to drive it. Any more just runs up your electric bill.
2018 International Serenity 27' FB
Michelin 16 tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Countryboy59 is offline   Reply With Quote
Old 12-16-2016, 05:31 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
What Countryboy59 said. I'll plug mine in even when it is only in the low 40s to minimize stress on the battery and starter. The heaters run for 15 seconds or so and even then it cranks longer and slower when cold.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-16-2016, 05:51 PM   #4
rastapoodle's Avatar
2004 31' Classic
Middle River , Maryland
The cold will not hurt the engine. You are leaving after temperature warms up. The engine heater just heats up the coolant. You can always plug it in before you leave.
rastapoodle is offline   Reply With Quote
Old 12-16-2016, 05:55 PM   #5
2016 30' Classic
We use ours when up in Breckenridge in the winter. It routinely gets to 0, and often lower than that. Last year it was -16 over Christmas. Simple answer is that I use the block heater if it gets below 5 or so. It certainly helps at warmer temps, but I don't ever plug it in if in the 20's. Our old diesel MH wanted to be plugged in at anything in the 30's. it just made starting so much easier. The GMC HD really has no problem. The one thing I'd add is that we use an additive when up in the mountains to prevent diesel fuel gelling. We've had great success with Stanadyne products. I'd never heard about gelling until talking to friends up there. Sounded nasty, so we make sure we transition early to winter blends + extra additive.
caseywsj is offline   Reply With Quote
Old 12-16-2016, 06:07 PM   #6
1973 31' Sovereign
Minneapolis , Minnesota
I use mine over night when it gets cold. I'm in Minnesota for reference for what cold means.
fairtheewell is offline   Reply With Quote
Old 12-16-2016, 07:03 PM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My new ram has straight 2 fuel ,parked in the shop at about 50 degrees and going to be --22 tonight, taking the wife to work early in the morning, now have 17" snow with some drifts on our county road..
Old 12-16-2016, 07:34 PM   #8
Trnpk Crsr's Avatar
Baltimore , Maryland
You can always put a timer on the heater, so that it comes on just a few hours before you need to use the truck.
Trnpk Crsr is offline   Reply With Quote
Old 12-17-2016, 06:08 AM   #9
Anything you can do to ease the workload of that heavy duty starter will pay off in the long run. Nothing sucks more than changing a diesel starter on a zero degree day. I even use the block heater on my gas truck.
Michelin 16 tires
Hensley Arrow hitch
Old 12-17-2016, 07:09 AM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I use mine!
I have a v10 gas engine which will start under any cold condition on its own... I just like the cabin heater working immediately.
like mentioned above a timer will get the effect you need in a couple hours without rinning up a big electric bill. I think my factory is 2500 watts! Thats a lot of electrical use! Make sure any extension cord is up to the task!
AtomicNo13 is online now   Reply With Quote
Old 12-17-2016, 07:31 AM   #11
paiceman's Avatar
Upper St Clair, PA , PA-Summer/FL-Winter
I run my engine heater all the time in the winter when at home. The electric draw is minimal at best.
Bud
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 12-17-2016, 08:10 AM   #12
2014 25' Flying Cloud
New Ashford , Massachusetts
Run it all the time below 32. I also have battery heaters, anything to lower the stress on cold days.
Mine and the trucks stress
Dexterpix is offline   Reply With Quote
Old 12-17-2016, 12:15 PM   #13
belen , New Mexico
I used to go out when I got up and plugged mine in and in about 3 to 4 hours the intake heater would not even come on.
alantbird is offline   Reply With Quote
Old 12-17-2016, 12:45 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The new oils are a big help, including the sy ethics...
Old 12-17-2016, 12:51 PM   #15
SMLJeep's Avatar
2017 27' Flying Cloud
Moneta , Virginia
Kevin,
I have the same truck as you and I never plug it in unless it is going to stay below 20 degrees all day and I need to use the truck. The glow plug will heat the engine with no issues at temps above 20 degrees.
SMLJeep is offline   Reply With Quote
Old 12-17-2016, 01:06 PM   #16
Edmonton , Alberta
Here In western Canada, there are times when plugging in the truck/car is a must however a couple of hours before it is needed is just fine most of the time, a timer is good if you know when you are leaving every day but if like me, I never know when I'm going to be needed, (hot shot delivery) I user a smart phone and remote control plug in. 20 minutes is usually enough most days
just google, : Orvibo Wi-Fi Smart Socket Outlet US Plug
Ronwp is offline   Reply With Quote
Old 12-17-2016, 01:31 PM   #17
pappy19's Avatar
Garden Valley , Idaho
On any diesel engine when the temp gets below freezing, it doesn't hurt a thing to plug in the block heater. Having it plugged in does a number of good things. Warm engine starts easy and is easier on battery and parts. Warm engine gives you heater and defrost immediately.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 12-17-2016, 03:20 PM   #18
1995 34' Limited
Sarasota , Florida
Wouldn't hurt if you did, might if you don't
GatorDave is offline   Reply With Quote
Old 12-17-2016, 04:20 PM   #19
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
My F-150 had a black heater, doesn't do much.
It STILL takes about 5 km. To warm up enough to clear the windshield. That's why I put a frost shield over the window at night.
FORD (AND TOYOTA) REALLY NEED TO DO SOME WINTER RESEARCH ON WARMING UP A COLD ENGINE.
THEY NEED to talk to VOLVO!
(I have told them, but it"s talking to a wall; meaning there is truth in the saying: "You can always tell an Engineer, but you can't tell him anything!".😬
Trailer Trash. ........"
MelGoddard is offline   Reply With Quote
Old 12-17-2016, 04:31 PM   #20
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
My owner's manual gave a recommendation of when to use the block heater. You might check yours.
StreamDog is offline   Reply With Quote
Does anyone use their bumper storage for anything except hoses? WILDRTEXAS Bumpers & Bumper Storage 46 03-26-2015 02:56 AM
Cracked engine block in fairly new truck bluvalley Towing, Tow Vehicles & Hitches 22 02-02-2014 03:07 PM
Older 3/4 ton suburbans - engine history diesel/big block Jammer Tow Vehicles 10 02-25-2010 08:10 PM
Who's done their Airstream with their custom style interior? ANY PICS LAWFISH Upholstery, Blinds, Walls & Interior Finishes 1 02-08-2009 06:36 PM
Has anyone ever removed their air conditioning from engine compartment Mr. D Mechanics Corner - Engines, Transmission & More... 19 06-07-2007 08:11 PM
