Old 10-30-2007, 06:51 PM   #29
_
wow...
i agree completely!
sell the excursion AND the tires.
they are both way too dangerous.
but so is that tire rep.
cheers
2air'
Old 10-30-2007, 06:53 PM   #30
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Originally Posted by HowieE
Had a very lengthily conversation with a Michelin Company truck tire rep today. After reviewing my axle weights and other factors he came to the same conclusion I had as far as tire pressure, 50 front and 55 rear. He did say that under no circumstances should I go out to 75 psi as that would reduce the road contact surface to a dangerous state.
Don't know what to tell you, Howie. I guess I'd ask the guy why they give inflation tables for axle/tire weights up to 80 psi at max load if you can only inflate their tires to 55 psi, and why would anyone buy their tires for a truck if they can only carry 70% of the weight of a comparable Bridgestone or Goodyear.
The replacement Firestones I had on the Ex were E rated with a max psi at 80.
As I said, I have the LTX M/S Michelins on my moho, and they have an 80 psi max rating on the sidewall.
Good luck with your decision.
Roger
Old 10-30-2007, 07:20 PM   #31
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
FWIW - I have load range E BFG's on the 1 ton van - their max psi for max carrying capacity is at 70 psi.... stamped on the sidewall of the tire. I run 65 psi with excellent results.
All this Excursion talks is making me reconsider an Ex (I had been looking for a diesel one). My 1 ton Dodge van, all 13 yrs old of it, sounds like it's doing better... course, my trailer is a BIT lighter! : > Only about 5000 pounds....
Marc
New (to me) '05 Excursion TV panabax Tow Vehicles 2 05-27-2007 12:47 PM
Mirrors for Excursion? Tom Randall Tow Vehicles 10 01-13-2007 02:11 PM
Excursion advice nilesrob Tow Vehicles 9 01-09-2007 09:23 PM
Diesel Excursion Owners! Bambi_Bandit Tow Vehicles 19 05-23-2006 02:50 PM
First Major Excursion Jabba Our Community 3 07-29-2003 04:14 PM
