Old 05-31-2006, 06:29 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Anyone tow with toyota tundras ?
I have a 31 foot airstream and was wondering if anyone towtrailer that size with one
I own 2000 tundra sr5 extra cab and I think it can tow 7100 lbs with its engine .
Mrcrowley is offline   Reply With Quote
Old 05-31-2006, 06:37 AM   #2
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Hi MrCrowley....I have a 04 Tundra D-Cab V8 pulling a 21'. Pulls like a dream on the highway but going up hills on the back roads works a little. I think the dry weight on my AS is about 3800lbs... There is another person in here pulling a bigger unit such as yours with a Tundra under the name BOBTHOMPSON I believe...if you have any ??? you could prob try to contact him. There are also some good threads about Tundras on here...do a search and you'll find plenty of reading material. Good luck!
enduroryda is offline   Reply With Quote
Old 05-31-2006, 06:46 AM   #3
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Tundra
I have a 65 GT and towed with a 2000 Tundra. I like the truck and it fits perfectly with the GT, but I'm not sure I would tow anything bigger. My impression of towing a 31 ft rig is that it would be slightly under powered and the weight of the trailer would be pushing my comfort zone.
The other issue I could see is suspension. You will need to beef up the rear springs and use a wd hitch. Without the WD hitch the tundra sags a great deal. Another forum member, towed a late 70s 24 ft rig and his rear end sagged a great deal (Tundra that is).
Sad to say this since I'm not a big fan of domestic brand trucks (oh here come the bombs my way), but for a 31 ft rig I would be looking at a Silverado or F250. IMHO.
Muddy
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 05-31-2006, 07:01 AM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I have an '02 Tundra Access Cab V6 that I pull my fiberglass RV trailer (a 17' Bigfoot) at 3500 lbs with. The V8 would have more power, but I don't think I'd want to tow anything much larger with my Tundra. I tow my 34' Airstream with a V10 Excursion.
Roger
Old 05-31-2006, 07:07 AM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree fully with whats been said. I would search for a different tow vehicle if you plan to tow a 31' RV.
Old 05-31-2006, 07:25 AM   #6
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
You would be a lot more comfortable pulling your 31 footer with a 3/4 ton truck. The diesel seems to be the popular choice of power plants on this forum. You'll have difficulty pulling any grades without a substantial TV say nothing about cooling the tranny etc. Good luck with your decision. Happy Trails
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 05-31-2006, 10:26 AM   #7
Frank S
peoria , Illinois
Hi Mrcrowley--What you need to satisfactorily tow a 31' A/S is a 3/4 ton truck with at least a 130" wheel base, 6.0 ltr V8 with a 4:10 rear minimum, or a big block V8 or diesel with a 3.73 rear (Chevy talk, or similar Ford or Dodge). You won't be satisfied with anything less.--Frank S
Frank S is offline   Reply With Quote
Old 05-31-2006, 06:55 PM   #8
Van
1977 23' Safari
Hillsboro , Oregon
IMO, a 31' trailer is far too much for a truck of that class to safely handle. You would be better served by a F-250 ford, 2500 chev, or 2500 dodge. I know i wouldnt be comfortable towing something that big with my F150
Van
2009 F-350 FX4 Crewcab 4x4 6.4l
former '78 Argosy 20' Minuet owner
former '77 23' Safari owner
former 25' Fun Finder X-250BHS SOB owner
current 26' Komfort Trailblazer 262BSLE SOB owner
Van is offline   Reply With Quote
Old 05-31-2006, 07:11 PM   #9
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Hi, I'm the Bob Thompson mentioned above and I pull a '97 Excella 25 with my Tundra. I've towed it near 35,000 miles in the past couple years, and as long as your travel conservatively, it is very much up to the task. I have had no towing related issues with the truck, although I did have to replace a rear axle seal and front brake rotors and pads. The rotors/pads are a common problem on pre-2003 Tundra's as is the axle seal problem. Otherwise, the truck has performed beautifully. On last September's 6,000 plus mile trek, we averaged over 13.5 mpg for the trip. We traveled a lot in mountainous areas from Santa Fe to Reno to Sonoma to Sequoia NP, then to Albuquerque. As for pulling something longer, I wouldn't. The brakes, suspension, power, etc. are just about maxed out for long distance traveling pulling a 25. The 25 is about as large as I would try to pull with a Tundra if you travel extensively.
So Long!
Bob Thompson is offline   Reply With Quote
Old 05-31-2006, 07:33 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I agree with Bob. I tow my 1975 25' tradewind with my 2003 Tundra and would not want to go much larger. It handles great and lots of power. I was in the mountains of Arizona (8000 ft +) this weekend and only on the steepest hills did I really slow down (50MPH).
Bob - You are getting better gas mileage then me! My 25' is lighter then yours, what's the deal? I keep my speed between 60 and 65, I tow with OD off and I have the 4x4 Tundra. Maybe it's the 3 dogs in the back seat...
Richard
Old 05-31-2006, 07:58 PM   #11
Images: 67
I would say the better gas mileage is a result of several things. I use Michelin LTX M/S tires which have a lower rolling resistance than say the very good Yokohama Geolanders. I run the Tundra tires at the highest pressure shown on the tire. Most times I tow with OD on especially if I'm rolling along on smooth easy conditions! The September trip, was just after Katrina and gas prices were thru the roof, so speed was mostly between 55 and 60 mph. Probably, most important, I plan my towing day carefully. Having sailed and windsurfed for years, I'm really tuned into wind patterns. If I am expecting head winds, I try to get out and get going early before the winds build up. Usually, winds are lighter in morning and build until mid-afternoon and drop off at dusk. If I am expecting tailwinds I put departure off a couple hours so I get the benefit of the wind. Charts like this really help in the planning: http://nwwind.net/
So Long!
Old 05-31-2006, 08:07 PM   #12
2002 25' Safari
Dewey , Arizona
Images: 62
Thanks for the reply. I have the same tires on my Tundra and I really like them. I never tought about the wind factor, but it always seems to be against me. I would bet the OD is a giant factor in the numbers. This last trip we left the house at midnight and got to the lake at 5am. No trafic and no wind. My numbers were around 11 MPG. That includes many ups and downs and 10 miles of dirt road. Started at 1200 ft and ended at 8200 ft. Thanks again...
Richard
Old 05-31-2006, 08:51 PM   #13
1977 31' Sovereign
Images: 33
Thanks for responce ..
Well the towing capacity of this model tundra is 7100 lbs but the weight of the trailer alone is 7100 lbs . BUT I have a chevy silverado k3500 dually that will tow it it is just cant have family with me three to four seater have five two need seat belts at least. ? can anyone ride in the trailer as it is being towed my gues is no becasue if they move around in trailer it would make it sway...
Old 05-31-2006, 09:10 PM   #14
SnorkyII's Avatar
2004 25' Safari
Escondido , California
I tow a 2004 25 Foot Safari with an 03 Tundra V8. We have towed the trailer over 6000 miles in the last two years. It's a little slow going up the grades, is otherwise OK. We live north of San Diego, and have grades in any direction except up the coast. I tow with the overdrive off.
SnorkyII is offline   Reply With Quote
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
tow vehicles paul k Tow Vehicles 96 01-19-2003 09:59 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
Tow questions ALANSD Airstream Motorhome Forums 3 05-28-2002 09:51 AM
