Old 04-29-2012, 02:12 PM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Anyone GMT900+Hensley+10000GVWR?
Specifically: 2007-Present Suburban 2500, Hensley Arrow, and a 30í (or more) Classic
Iím considering trading in my 2005 Suburban 2500/8.1L for a 2013 6.0L, and thereís a few issues Iíve occasionally seen mentioned:
1. The new integrated receiver is inadequate for 1200/12000 towing (and not replaceable)
2. The new integrated receiver is too high for any of the Hensley stingers, making your trailer Ďnose highí
3. The 6.0L is inadequate.. even with the 6 speed trans
Unfortunately, the 'burb is my only option- since I must have 4WD and Quigley isn't taking any orders on the E350.
Any hands-on experience/insight would be greatly appreciated.
TIA!
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-30-2012, 04:52 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Joe,
I don't recall what the integrated hitch is rated for but I do know it is much better than the hitches' it replaced.
Here is a photo I took when they first started using them. You cant see it very well but it's bolted directly to the frame extensions on both sides, has a very large boxed crossmember that the hitch box is welded to both inside and outside. Pretty substantial improvement.
Have you researched an aftermarket hitch or checked any Burb forums?
There were a lot of questions at the Chevy Store,(retired now), about this problem when the integrated receiver first came out in 07.
It may work but what I see as a problem is the difficulty of doing a good maintenance inspection, plus the 24" stinger height.
Just for S&G's what's your 30 weigh?
Name:	2007 SUB #3.jpg
ID:	157199   Click image for larger version
Name:	2007 SUB 1.jpg
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 04-30-2012, 05:06 PM   #3
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
There is a sticker on mine that lists the max tongue weight at 1000 with W/D and max trailer weight at 10,000. It is exactly the same sticker that was on my 2010 1500.
But don't fret because I'm pretty sure that both of those numbers are wrong. Why? Because I read the manual that came with the vehicle.
Also, when I made the measurements for hitch height seen on another thread around here I did it on a 1500 series (before I decided to get the 2500). The inside of the top of the hitch receiver on my 2500 is a little over 25"
As for towing? Well this thing has plenty of power and the 6 speed has enough gears to be really flexible.
ID:	157201   Click image for larger version
Name:	Max Tongue.jpg
phbarnhart is offline   Reply With Quote
Old 04-30-2012, 05:41 PM   #4
Dearborn , Michigan
Images: 21
Bob,
It's usually around 1,300#, although I've measured it as high as 1,500#
With a 25" receiver, I'd need a 10" drop stinger, right?
Thanks for the pix
PH'
Exactly what I was looking for.
Thanks!
Old 04-30-2012, 07:54 PM   #5
richinny's Avatar
2011 34' Classic
i'd give andy at CAN-AM a call.
Ricky
Old 04-30-2012, 08:12 PM   #6
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Originally Posted by finalcutjoe
Bob,
Thanks for the pix
PH'
Thanks!
No problem, let me know if you need anymore info!
I know I'm towing less weight, but I'm finding that I've got more than enough power!
Old 05-01-2012, 06:29 AM   #7
Originally Posted by finalcutjoe View Post
Bob,
Thanks for the pix
Joe,
I believe your 30 has the same level ball height as our Classic, 18 3/4", a 10" drop would be doable. But as with most things Airstream I would level your rig and measure to be sure. I had to go from a 4" drop to 6 to get the 06 Burb level.
Our tongue weight,(1200lbs), is 330lbs over listed numbers, so going by the spec sheet is a bit problematic.
I wouldn't stress too much over an inch or so difference as wd adjustment can easily compensate with no adverse effect on handling. Just my experience.
Your rationalization for replacing the 8.1 is? Just wonder'n, our's has been bulletproof.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 05-01-2012, 09:18 AM   #8
Vintage Kin
Fort Worth , Texas
Ask Sean. He may be at Pro-Pride, but he's also an H/A whiz. Might be time for a custom stinger anyhow (we need another of your great threads, f-c-joe).
Old 05-01-2012, 03:19 PM   #9
Dearborn , Michigan
Images: 21
Originally Posted by ROBERT CROSS View Post
Joe,
No issues.. it's about time for a new family truckster, and I figured I might as well get something I can tow with.
Old 05-10-2012, 10:20 PM   #10
Vintage Kin
Fort Worth , Texas
I've now come across two guys in the oilfield who've been towing "big" 5'ers with their [old] 6L Chubbies. In each instance the pickups are above 200k on the original engine. These are guys who understand motors . . and who can also afford to trade for what they want. That they don't says quite a bit.
As to hotroddin' a motor for towing: the only benefit is in reduced restriction at air inlet and air outlet. And I'll bet it's quite hard (nowadays) to actually beat what the factory has as stock. The only benefit in the old days to dual exhaust and dual inlet air cleaners wasn't the 15-25 HP they added, but the ability to allow the engine to hang on longer before the upshift so that the motor would "come back in" at a higher rpm. And it took some careful re-tuning of carb, trans shift points and fuel delivery to actually see the benefit of those changes.
A 6-speed auto ought to be just fine for a guy like you (knows how to use things).
Old 05-10-2012, 11:47 PM   #11
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Why, I don't know but we have the 2012 Tahoe with the high receiver and we are able to use the 6" drop stinger with no problems. The Hensley is new so maybe they changed the design to accomadate the higher receivers in all of the new Chevys and Fords.
Dan
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 05-11-2012, 06:53 AM   #12
Dan,
I believe the Tahoe hitch height is 2-3" lower than the Burb or P/U's.
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 05-11-2012, 06:59 AM   #13
dznf0g's Avatar
Oswego , Illinois
Hmmm, With my 30'er, I use an 8" drop with the Subs, Yukon XLs, and Escalades. 3/4 ton trucks (GM), I use a 6" drop.
I thought Tahoe was the same as a Sub, but I wouldn't hook a Tahoe to my 30'er.
-Rich-
hensley, suburban, towing, trailer, motor scooter
