Old 06-14-2004, 12:57 PM   #1
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Another tow question
I'm trying to weigh pros/cons between a GM tow vehicle with 6.0 liter and the 4.10 ratio vs the 8.1 liter and 3.7 ratio. I'd think the 6.0 liter would get better mileage and the 4.10 gives me close to the same towing capacity as the larger engine. Sort of a Ginger vs Mary Ann I guess, but I'd appreciate the groups wisdom.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 06-14-2004, 01:26 PM   #2
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
8100 vortec=danger
Hut,
Chevorlet considers 1 quart of oil for every 100 gals of fuel normal. I have a friend that has a 2500 Suburban that would be happy to talk to you. Just pm me and I will give you his number.
As far as the 4.10 gears the weight of your trailer will be your guide.
From the Chevy trailer data:
2wd 6000 vortec 3.73 #7900 8100 10,500
2wd 4.10 #9900 8100 12,000
4wd 6000 3.73 #7600 8100 10,200
4.10 #9600 8100 12,000
(with quadrasteer -300#)
For my 27' Overlander the 4.10 rear is over kill and I will work to change my gears back to 3.73.
Hope this helps!
Abe
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 06-14-2004, 03:06 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
As a kid, I was partial to Ginger, but now would think she'd be "high maintenance", so I'd opt for Mary Ann
Dennis
cosmotini is offline   Reply With Quote
Old 06-14-2004, 03:51 PM   #4
Tin Hut's Avatar
which
I've always stuck with Mary Ann.
Old 06-14-2004, 06:04 PM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
At the risk of being a bit off color:
Ginger is the one you want to date and get lucky with. Mary Ann is the one you want to marry.
I try to think long term
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-14-2004, 06:07 PM   #6
summerkid's Avatar
1956 16' Bubble
Rose Lodge , Oregon
The two concepts are mutually exclusive? Ick.
summerkid is offline   Reply With Quote
Old 06-14-2004, 06:23 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my thinking exactly brett!
john
you call them ferrets, i call them weasels.
Old 06-14-2004, 06:30 PM   #8
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Brett... I'm appalled! That would be appalled with a Capital "A", two "p"s, and two "l"s.
Roger
Old 06-14-2004, 08:08 PM   #9
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
so who would you pick roger?
john
Old 06-15-2004, 09:48 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
tin hut,
I considered the 6.0 with 4.10 vs. the 8.1 with either the 3.73 or 4.10 rear end. I can tell you that the 6.0 really likes the 4.10 since it likes to rev. I chose the 8.1 over the 6.0 in the 2001 model because of more than numerous complaints about noise (CSK) from the 6.0. I have been extremely pleased with my 8.1/Allison auto transmission combination and now have 33,100 miles on it with no problems. They seem to have taken care of the short piston noise problems they were having with the 6.0.
Comparing comments made from forum members and those from the www.pickuptrucks.com forum, the 6.0 gets 2-3 mpg more on the highway solo (18 mpg) than the 8.1 (14.5-15 mpg) but towing seems to be a dead heat (10-12 mpg). I'd rather have the extra power/performance of the 8.1, reliability of the Allison (the manual is good also) over the 4 speed auto of the 6.0, and the fact that the rear end is a heavier duty unit with the 8.1/Allison combination. Matter of fact, it has the same transmission/rear end that the 3500 dually has. You can't ask for a better combination out of a 2500hd than that other than the increased mpg of the diesel.
Towing capacity of the 6.0 with 4.10 in the 2500hd ext. cab short bed 2X4 is 1,400 lbs. less than the 8.1 with 3.73 in the same configuration. The 4x4 with 6.0 has 1,900 lbs. less than the 8.1. I think you get the picture. There is no substitute for cubic inches.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-15-2004, 09:55 PM   #11
Tin Hut's Avatar
Thanks Craig for the advice. That's the way I'm leaning. Sounds like most of the issues with piston slap has diminished in the last year or so and I like the reserve power the 8.1 has over the 6L
Old 06-19-2004, 12:53 PM   #12
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
6000 vortec vs 8100 vortec
FWI
the 6000 vortec has 325 hp and 365# of torque
the 8100 vortec has 320 hp and 440# of torque and is a $950 option.
the extra 75# of torque cost $12.66 per pound is pretty steep in my book.
abe
Hensley Hitch
Old 06-19-2004, 04:20 PM   #13
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by vajeep
FWI
abe
The following was downloaded from the Chevy Vortec Engine site:
First, the specs on the 6.0 liter engine:
Horsepower:
325 @ 5000 rpm
GMC Sierra Denali
320 @ 5000 rpm
GMC Yukon Denali/Yukon XL/XL Denali & Suburban
315 @ 5000 rpm
H2 (prelim)
300 @ 4400 rpm
Chevy Express, GMC Savana, 3500 series, 2500 HD & 3500 GMC Sierra and Chevy Silverado pickup and crewcab
Torque:
370 @ 4000 rpm
GMC Sierra Denali
365 @ 4000 rpm
GMC Yukon Denali/Yukon XL Denali
360 @ 4000 rpm
GMC Yukon XL/Suburban, Chevy Express & GMC Savana 3500 series
H2 Prelim
2500 HD & 3500 GMC Sierra & Chevy Silverado pickup and crewcab
And for the 8.1 liter:
Horsepower:
340 @ 4200 rpm L18
325 @ 4000 rpm MD L18 w/LRW power option
295 @ 3600 rpm MD L18 w/LRZ power option
225 @ 3600 rpm MD L18 w/LQR power option
Torque
455 @ 3200 rpm L18
450 @ 2800 rpm MD L18 w/LRW power option
440@ 3200 rpm MD L18 w/LRZ power option
350 @ 1200 rpm MD L18 w/LQR power option
The 325/365 are at 5000 and 4000 rpm.
The 320/440 rating is about 4000 and 3200 rpm.
In my opinion, the 8.1 liter engine is the clear winner. The 6.0 liter would be turning it's heart out at a continuous 4000 to 5000 rpm.
Granted, I would not turn the 8.1 liter at 4000 rpm continuously either, but my 454 engine runs all day long in the 345 at 3000 rpm.
And gets up to 3600rpm in second for as long as it takes to pull a hard hill.
All depends on what you really need - my vote would be for the 8.1 liter for consistant heavy duty work.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-19-2004, 05:52 PM   #14
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
thanks for the information
The numbers I posted were from the Chevrolet.com build it site. The numbers were from the options area for motor choices.
I am all about knowing more about the motor that is in my Suburban.
I am rated for 9300# total trailer wt. Our 27' Overlander is rated at 4500 empty. I long ago realized the Ford/Chevy Gas/Diesel Ginger/Mary-Anne
etc.. Was all about what the driver wanted to be driving. I love this forum because I always get honest answers.
Abe
Hensley Hitch
Argosy 24 MH Tow Capacity Question outbound Argosy Motorhomes 3 03-14-2004 11:35 AM
Tow Vehicle Question SCBrat Tow Vehicles 3 09-25-2003 08:43 AM
Tow Vehicle Question gorlesky On The Road... 2 08-31-2003 05:28 PM
Suburban tow package wiring question uwe On The Road... 9 08-29-2003 02:08 PM
Another Tow Vehicle Question jalewis Tow Vehicles 8 07-28-2003 12:51 AM
