Old 01-28-2014, 06:53 PM   #169
Marine city , Michigan
Originally Posted by Caryl View Post
Greetings all. I may be joining you as a Touareg owner. We are looking at a new 2014 TDI with the factory hitch and 7 pin connector. The technician at the dealer says that it is plug and play indicating that it would control the brakes. This seems weird and wrong to me. I assume that I will need a brake controller. What am I missing here??? Or what are they missing here?
Caryl
Plug and play means you buy a brake controller and plug it in. Controllers are often available with plugs that fit specific vehicles's recepticles under the dash.
Denny Wolfe
www.wanderingourway.wordpress.com
Mcdenny is offline   Reply With Quote
Old 01-28-2014, 07:05 PM   #170
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Caryl
They sure make it hard to find that kind of info on their website!
If there's a factory hitch and 7 pin connector and it's sold as a tow package, I'd assume it's got an integrated brake controller. Obviously double check that, but it doesn't make sense otherwise - unless - the wiring harness is included for you to select the controller of your choice and install it to the pre-wired harness.
VW's mobile website leaves something to be desired.
But 7000+ lbs of towing capability would cover my 27FB Flying Cloud with plenty of headroom!
Good luck!
Old 01-28-2014, 07:08 PM   #171
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
...7 pin connector. The technician at the dealer says that it is plug and play indicating that it would control the brakes.
I suspect he was comparing the 7 pin to a 4 pin, which only controls running lights, brake lights, left and right turn signals. The 7 pin adds trailer brakes, alternator charge, and ground. You'll still need a brake controller.
Steve
TinLoaf is offline   Reply With Quote
Old 01-28-2014, 07:20 PM   #172
2012 25' FB International
Evanston , Illinois
Ah, Mr. Tinloaf and SteveSueMac, you make sense. And thanks, Denny for the reassurance. The VW tech said he would do the research and get back to us. He clearly had not dealt with this question before. If he does the research, I will post here.
Caryl
Caryl
Caryl is offline   Reply With Quote
Old 01-28-2014, 10:05 PM   #173
JFScheck's Avatar
Rockville , Maryland
Images: 33
The Touareg does not control the brakes ala integrated brake controller and a 27FB is too much for a Touareg. Read the posts on this thread and then come back if you have any questions left to ask...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-29-2014, 09:21 AM   #174
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
And another dealer tech who is uneducated. Yes, you need a brake controller. The Touareg does not come with one, only the wiring harness to connect one. It is located near the steering column wrapped in gray foam. Go to: Club Touareg - Volkswagen Touareg Owners Community and search for "brake contoller".
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 01-30-2014, 05:07 PM   #175
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
Just purchased a 2012 Touareg TDi. Believe I'll be shopping for a brake controller in the weeks to come. With a dry weight of 4855 / 515 hitch weight, we'll probably only use the VW for local jaunts with known routes. Long trips will bring a Dodge 1500 truck rental.
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Erik Olson is offline   Reply With Quote
Old 01-30-2014, 05:14 PM   #176
JFScheck's Avatar
Images: 33
I have written instructions on how to hook up both the Prodigy P2 on a 2005 - 2007 Cayenne/Touareg and 2009-2013 Cayenne Touareg with Prodigy P3.
Check this site as I posted both sets of instructions online, the latter model Cayenne\Touareg requires a relay for proper install.
**I Love U.S.A.**
Old 01-31-2014, 07:00 AM   #177
Evanston , Illinois
John,
I have your instructions and a new controller and will be off to the dealer today. We have spoken to the dealer a couple of times about this and we seem to be on the same page. I think it was a communication issue.
Thanks again. Caryl
Old 01-31-2014, 07:33 AM   #178
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
John, do you have a link to that instruction sheet you drew up? Also, our Ambassador has been towed with what must be the original distribution hitch (stirrup and saddle style, chain tensioned). In light of the fact that VWs official policy on weight distribution being bad, do I simply go direct to the receiver with a variable height ball hitch? I don't want to break the Touareg or cause some highway catastrophe.
Erik Olson
Old 01-31-2014, 07:36 AM   #179
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
You are well within the capacity for towing your AS with a Touareg. Your Touareg has better brakes, better handling, and more torque for towing than a Dodge 1500. However, a pickup truck does have more room for stuff on long trips.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-31-2014, 07:47 AM   #180
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Mojo,
Thanks! As a legacy Land Rover and Dodge Ram owner, I'm a fan of the old-school boxed frames. This uni-body thing is new to me and I don't want to tweak the new ride. I feel confident in the Touareg and I'm sure I'll gain more as I start towing the Ambassador. We never travel with the white tank loaded - I'll just have to get in the habit of buying the beverages once we've set camp instead of towing all the booze up the mountain.
Erik Olson
Old 01-31-2014, 06:39 PM   #181
JFScheck's Avatar
Images: 33
Here is the link --> http://www.airforums.com/forums/f463...els-61931.html <-- minus the pictures as I deleted them off of my web site, will look to see if I have them still if you need them...
**I Love U.S.A.**
Old 02-01-2014, 10:52 AM   #182
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Thanks again!
Erik Olson
New VW Touareg initial impressions..... Silvertwinkie Tow Vehicles 126 04-10-2014 11:09 PM
My new tow vehicle juel Tow Vehicles 50 02-22-2006 06:26 PM
First road trip with Touareg and CCD... Xray Our Community 35 09-15-2004 01:06 PM
VW Touareg as tow vehicle davidp Tow Vehicles 13 08-27-2004 12:33 PM
new volkwagon AS commercial Stefrobrts Our Community 55 08-09-2003 12:47 PM
