Old 06-30-2006, 08:32 AM   #1
1965 26' Overlander
1990 34' Excella
1975 20' Argosy 20
Upper Black Eddy , PA
An 87 Wagoneer for a 65 Overlander????
Thinking about purchasing an 87 Wagoneer with a 360 V8 for towing my 65 26 foot Overlander, with a dry weight of about 4230 lbs. and wet weight around 5500 lbs. It has a Class 3 hitch.
Can't seem to find out what the gear ratio is on this vehicle--it's not in the owner's manual and doesn't seem to be labeled anywhere on the vehicle. How can I find this out? I called a dealer and they weren't very helpful. Also, is a Class 3 hitch appropriate for this type of load?
I'm supposed to meet with the seller this afternoon--so, any info would be really helpful!
Kathy
kdenault is offline   Reply With Quote
Old 06-30-2006, 11:51 AM   #2
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Try IFSJA
Kathy,
Not sure on 87. Try the International Full Size Jeep Assoc. www.ifsja.org web site and ask them.. someone will know.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-30-2006, 11:46 PM   #3
1960 24' Tradewind
santa barbara , California
Hello kdenault,
Look for a small metal tag attached to the rear differential cover ,it will be small about 1 1/4 long or less ,if it is there it will show ,3:73 or ? which is the ratio ,also there may be a small tag saying limited slip possibly.The axles are
DANA corp. units .The wagoneer is plenty tough to pull that airstream .The
mileage isn't great but so what its the heavy duty vehical you need .Expect
about 10 mpg .
scott
scottanlily is offline   Reply With Quote
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Thinking of Buying '72 Overlander Joe C 1972 Overlander 16 07-20-2005 06:01 AM
receptacle replacement 1960 overlander rod Electrical - Systems, Generators, Batteries & Solar 3 10-31-2002 07:19 AM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
Looking at a '64 Overlander N80 1960 - 1964 Overlander 1 06-02-2002 08:25 PM
