Old 11-24-2007, 04:04 AM   #29
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hello Wingfooted
We have at least 200 customers that with F150's & Expeditions many are towing 30-34' Airstreams some much harder to tow conventional trailers. Several are on their second or third and see no reason to change to a 3/4 ton.
Your brakes are just as effective as a 3/4 and you have good engine braking going down hills, far more than a deisel without an exhaust brake, if you find you have to use the brakes to keep your speed down going down a hill then you are in the wrong gear or not at a high enough RPM. To climb you will need to use second gear on hills occaisonally so you will be climbing at 50 MPH instead of 65. The F150 has more power than any tow vehicle you could by 12 years ago and people still traveled back then.
If you need 4x4 where you are the F150 has independent front suspension the F250 does not. Pushed to the limits the F150 will outhandle the F250 hands down.
The key to driving in hills both going up and going down is to select a gear that keeps the engine in its powerband which is 3500-4000 RPM with the 5.4. It runs those RPM's very easily and will climb easily if it is kept in it's powerband. The 5.4 receives the same transmission as the V10 or the earlier deisels so it is a pretty bullet proof drive train. It likes fuel but you will never drive enough in your circumstance to pay for the deisel with fuel savings.
The passenger car tires that some of these trucks come with are not good and changing the tires can improve handling a great deal. There are several tire size options on this truck if you let me know what size is on it I can recomend a good replacement.
The hitch receiver is not too bad, we always strengthen them but it is better than a lot of the hitches out there much improved over the older F150 hitches.
A Hensley hitch is a great idea for either the F150 or an F250.
Andrew T is offline   Reply With Quote
Old 11-24-2007, 04:22 AM   #30
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I must mention that Wingfooted is still listed at one post so unless he is just lurking and not responding he hasn't been back to read all of this great information and we have all been talking to ourselves for 3 pages of posts.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-25-2007, 08:57 PM   #31
holland , Michigan
andy i have the 18 inch tires. what would you say is a better tire for this 08 model?
safari 28 is offline   Reply With Quote
Old 11-26-2007, 04:08 AM   #32
wingfooted's Avatar
2005 30' Classic
Nyssa , Oregon
thanks for all the comments
Very good comments and opinions from the board on this topic.
Conclusions
1. Yes it is possible to tow a 30' classic with the new model Ford F 150 but it wont be as much fun as having a bigger TV. Particularly on gradients.
2. Safety issues are involved - buy a good weight distribution and anti sway hitch.
3. As I wont be driving the Ford F 150 off the lot until February, I will wait until then and see what my brokerage account looks like. A decision on the bigger Ford F 250 can be defered until then.
Thanks again
wingfooted is offline   Reply With Quote
Old 12-14-2007, 07:01 AM   #33
papademojo's Avatar
1991 34' Limited
1968 22' Safari
Clarksville , Indiana
Talking F150 with 34' Limited 60th anniversry
Just purchased 34' Limited W/Hensley. I drive an '05 King ranch 4x4, 5.4L with 18" wheels and I must say that it pulled the TT like the 22' that I will be posting for sell. I had no problems towing it 540 miles from KC,Mo. to Lou.,Ky. So if you have A F150 and want to pull a 30-34' go for it. Make sure you have a Hensley and a good controller. BTW my controller is a prodigy and worked flawlessly with the Three axel TT.
papademojo is offline   Reply With Quote
Old 12-14-2007, 08:40 AM   #34
dmreilly10000's Avatar
1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
Talking
Nope, nope, nope, you need at a minum one of these:
Just joking, of course.
Name:	Ford F-650.JPG
ID:	50834   Click image for larger version
Name:	airstream truckbambi.jpg
dmreilly10000 is offline   Reply With Quote
Old 12-14-2007, 10:35 AM   #35
tpi
Trabuco Canyon , California
Andrew T The key to driving in hills both going up and going down is to select a gear that keeps the engine in its powerband which is 3500-4000 RPM with the 5.4. It runs those RPM's very easily and will climb easily if it is kept in it's powerband.
This is good advice which shouldn't be lost in the shuffle. Don't be afraid of revs on this engine. It also keeps the transmission cooler.
If you go w/ 250 get the v10 or diesel.
tpi is offline   Reply With Quote
Old 12-14-2007, 11:50 AM   #36
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
F150vs mini...found it this morning. Has nothig to do with towing, of course, but I still found it to be interesting.
bridger.us » Archive » Crash Testing: MINI Cooper vs Ford F150
Uwe
www.area63productions.com
Old 08-08-2010, 10:12 PM   #37
can't finish anyth
GolfStream's Avatar
2006 19' International CCD
2010 28' International
Dallas , Texas
Thanks to everyone on this thread. After reading this, especially Andrew T's post, I will be keeping my '07 F-150 Lariat well after my payments are completed. :-) But, then again, I have the tow package including the tranny cooler, 3.93 rear gear, and beefed-up rear suspension.
We completed our first trip with the 28 CCD to Santa Fe in May and I was a bit concerned about keeping the 5.4L in the 4,000 RPM range on inclines and declines. Good to know that i was doing the right thing.
Yesterday, I test drove the 2011 F-250 with the new diesel and while it is a very nice truck, the thing is a gangly beast and I'd hate to have to park that thing in a grocery store lot, much less in a parking garage.
Javier
Dallas, TX
2010 28' International CCD
(tricked-out techie twinkie)
2007 Ford F-150 SuperCab.
2010 Touareg TDI
GolfStream is offline   Reply With Quote
Old 08-09-2010, 03:20 AM   #38
wingfooted's Avatar
2005 30' Classic
Nyssa , Oregon
Follow up
As followup, although I still have the F-150 5.4L I never have actually towed the Airstream off the farm grounds. In fact I never even bothered to license it. The Airstream goes from the machine shed to the parking space and back to the machine shed with a side trip now and then to discretely dump the black tank in the back 40 acres.
Recently purchased a 2000 F-350 7.3 powerstroke with 6 speed manual --- that will be my primary tow vehicle. Actually I bought the diesel for other reasons rather than towing.
If I had to do it all over again, I should of just bought a superduty diesel to begin with.
Old 03-11-2011, 07:48 PM   #39
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
f-150 ad
watching 'flying wild: alaska' on discovery. just saw an ad for 2011 f-150 towing what looked like a 27 foot classic. is that really enough truck for that rig?
Morrison's Airstream Page
munimula is offline   Reply With Quote
Old 03-11-2011, 08:16 PM   #40
Ottawa , ON
Read this thread from the beginning and tell us what you think.
Old 03-11-2011, 08:33 PM   #41
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Originally Posted by Inland RV Center, In View Post
Your 150 is fine.
Contrary to the opinion of all to many owners, you should always tow with the water tank "full.".........Traveling with full water, adds enjoyment to Airstreaming, and peace of mind too.
Interesting concept, until you pull a few hills and your trans blows, like mine (on my 5.4L expedition) did.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
The F150 as a TV; one guys perspective Boondocker Tow Vehicles 26 02-25-2008 09:57 PM
Towing questions: 1967 Safari with 1994 Ford F150 Billm67 Tow Vehicles 9 06-05-2006 11:01 AM
F150 or F250 Gas J Goertzen Tow Vehicles 28 05-15-2006 06:18 PM
2000 F150 -- Enough truck? Kinder Tow Vehicles 6 01-20-2006 03:55 PM
f150 w/ a 4.6 vi 60traveler Tow Vehicles 7 08-11-2003 02:45 PM
