Old 03-07-2012, 12:05 PM   #29
phbarnhart's Avatar
2012 25' FB Eddie Bauer
Eugene , Oregon
Images: 14
@Bob: I'm pretty sure that it is a locking rear diff (automatically) and yes, its a 4wd.
@Herrick: Yes, the Eddie Bauer has 16" wheels so it's a little taller than normal but that actually works pretty well with where the hitch receiver is on the Suburban. Once I fill the fresh tank it's (by the specs, mind you) around 6000lbs. Then we add clothes, food, the small generator (if going boon docking), and a few toys for the kids. I don't know the weight of all of the dishes and the like, but I was pretty careful about picking out light items. I would be pretty surprised if we end up over 6500lbs but I'm planning on finding out soon.
phbarnhart is offline   Reply With Quote
Old 03-07-2012, 12:18 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
G80 is the option code for the locker.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-07-2012, 12:37 PM   #31
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Excellent, thanks Bob.
Old 03-07-2012, 12:45 PM   #32
phbarnhart's Avatar
Eugene , Oregon
Images: 14
Update: Apparently the 3.08 rear-end is in an 8.5" housing and the 3.42 gears will not fit in that. GM doesn't sell a complete 3.42 housing (just the individual parts) but they do sell the 3.73 housing complete. So the guy has some of his contacts at the wrecking yards looking around for a complete 3.42 set-up.
Old 03-07-2012, 01:59 PM   #33
IMHO.... if your serious about changing, go for the 3.73, you would be hard pressed to notice the difference going to the 3.42. And remember the front differential needs the up-grade too.
PFC
"Tahawus"
RLC
John Prine
Old 03-07-2012, 02:05 PM   #34
Wise Elder
Jammer's Avatar
2010 30' Classic
I have the 3.73 rear in my pickup and the 4.10 rear in my 'burb. They have the same transmission but the 'burb has a bigger engine.
The only difference is that the 3.73 leads to more hunting between 3rd and 4th on hills with the trailer (I have the 4 speed transmission, not the newer six speed). I don't notice a difference in noise level or fuel economy.
Things may be a little different with the 6 speed transmission, but in general, if you're doing a significant amount of towing, you'll want a lower (numerically higher) ratio rear. 3.73 would be fine if that's what's available, I would think, 4.10 probably ok too, 4.31 might be too much of a good thing but maybe not.
Old 03-07-2012, 03:42 PM   #35
phbarnhart's Avatar
Eugene , Oregon
Images: 14
My understanding is that the 6-speed has made some of the traditional wisdom about which rear-end ratio to go with a little less applicable because the availability of more gears means that you're more likely to have the right one available.
That said, I may very well end up with the 3.73, especially if the mechanic can't find a suitable set of 3.42s!
Old 03-07-2012, 03:53 PM   #36
dznf0g's Avatar
Oswego , Illinois
Well, IMO, it made the issue of 3.73 vs. 3.42 less of an issue in your weight class.
-Rich-
Old 03-07-2012, 04:06 PM   #37
....a suitable set of 3.42s!
One more time....two suitable set's.
IMHO..a lot to spend for .34 of one revolution.
Any math geeks out there?
PFC
"Tahawus"
RLC
John Prine
Old 03-07-2012, 04:24 PM   #38
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Think of it as 9% more torque in every gear. But yeah, with the 6 speed, it means that on any given hill, you may be in 4th instead of 3rd at the same speed & RPM...
I'm with the not sure you have a problem and this isn't a minor expense group.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 03-07-2012, 04:35 PM   #39
phbarnhart's Avatar
Eugene , Oregon
Images: 14
@ Bob: Yeah, I know I need to change the front and back, I thought that my use of "set" followed by a plural "3.42s" showed that. I guess that since each end actually needs a set of gears it wasn't clear. Anywho, I'm hoping that they can find a front/back gearing set from a single vehicle.
@ newroswell: I noticed on my trip to Montana and back last fall that I didn't quite have enough power to cruise on the freeway in 5th but that 4th was more than was necessary. I'm thinking that 9% would be just about right. What I do know is that I had to drop to 2nd on a few of the mountain passes because 3rd was, again, just by a little bit, unable keep up momentum.
My real concern was about the durability of the 3.08 gears/housing as compared to the 3.42 or 3.73. It seems that the housing is smaller on the 3.08 but I don't know if that matters all that much. Anyway, I'm exploring my options right now.
Old 03-07-2012, 04:45 PM   #40
dznf0g's Avatar
Oswego , Illinois
I still say try it the way it is and see if it is comfortable for YOU, performance wise. There's plenty of time later to swap out gears (yes, 2 sets!)
If you were trying to pull a 30'er or a 34'er, I'd be much more concerned about durability, etc. Not so much with a 25'er.
-Rich-
Old 03-07-2012, 04:53 PM   #41
X2
PFC
"Tahawus"
RLC
John Prine
Old 03-07-2012, 04:53 PM   #42
phbarnhart's Avatar
Eugene , Oregon
Images: 14
@ dznf0g and Bob: That's kind of why I'm doing this now. I did a 2000 mile trip from Eugene, OR to Helena, MT (plus a some around Montana) trip in October before I put her to bed for the winter. What I learned from the trip is that there's a very good reason that the tow package comes with the 3.42 gearing; it's only a little bit lower, but a little bit seems like all that would be needed to keep the transmission from shifting all the time, even while cruising.
I do appreciate the advice though, basically, if I may paraphrase, you're saying that I'm not really hurting anything by towing with the 3.08 but I may be more comfortable with the 3.42 or 3.73 so it's basically a judgement call about the cost v. my personal towing comfort.
My next project is a basket case... InsideOut Vintage Kin 142 10-19-2013 09:18 PM
Doing full monte on my '58 Traveler Chlyman 1958 Traveler 77 06-13-2013 07:36 PM
5 year search, we got it! Sodbust 1972 Overlander 23 03-24-2012 08:34 PM
Towing Garyj Tow Vehicles 6 03-08-2012 04:53 AM
