Old 02-15-2010, 11:56 AM   #1
till's Avatar
Lisle , Illinois
Images: 108
Alternator
The alternator is going out on my new TV 1994 C2500 Suburban.
I have a decision to make, to I go with a stock 105 amp unit or upgrade to the 140 amp alternator? With two batteries on the truck and than adding a third while towing, do I need the extra 35 amps?????
Thanks in advance.....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 02-15-2010, 12:21 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The performance on the overwound units isn't that great.
You might, on the other hand, consider a CS-144 upgrade. It's a larger frame alternator that produces more output, especially at idle. You might need a different belt and there is a wiring adapter you use because the connector is a little different.
GM CS-144 High Amp Alternators, Nations Power Engineering
Old 02-15-2010, 12:34 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
No.
Unless you are doing a lot of stop and start, less than 30 miles per start, you do not have enough load to warrant the large alternator.
2004 Excursion 4x4
Alternator help tebone Mechanics Corner - Engines, Transmission & More... 0 12-04-2008 07:05 PM
HELP with alternator dorothywhitt Mechanics Corner - Engines, Transmission & More... 1 07-11-2006 12:44 PM
Failed alternator? Robfike Mechanics Corner - Engines, Transmission & More... 13 07-06-2006 08:10 PM
Alternator issue guy99 Mechanics Corner - Engines, Transmission & More... 12 08-24-2005 03:10 PM
345 alternator pbnjsellers Mechanics Corner - Engines, Transmission & More... 6 08-07-2005 08:45 AM
