Old 08-07-2014, 04:33 PM   #1
interstateflyer's Avatar
2017 25' International
Los Osos , California
AirBags or Stiffer Shocks on 2013 Dodge RAM 1500?
I noticed that when I switched from a 2013 International 19 to a 2014 International 23D and added a bed cap that the rear of the 2013 RAM 1500 Crew Cab 2x4 rides a little lower.
The tongue weight of the 23D is 200 pounds more than the 19. The weight distribution system looks perfect with chains hanging straight down and the bars perfectly level.
However the ride is harsher and there is a little bounce on undulating roads.
I looked at the AirLift 1000 air bag system for coil springs. Our local installer recommends a heavier duty adjustable shock instead.
Based on your experiences which would you go with?
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-07-2014, 04:52 PM   #2
1981 31' Excella II
New Market , Alabama
What size bars are you using? It maybe that they are not stiff enough. A little bounce is better than not enough. Measuring the actual tongue weight might be a first step.
Perry
Old 08-07-2014, 05:04 PM   #3
1200 pound bars for the 23D. The tongue weight is close to 720. The bars are for 800 to 1200 pounds. The A/S dealer felt that we were close enough to 800 to warrant the 1200 bars.
Old 08-07-2014, 05:07 PM   #4
I just got a call from another person at the same shop (he also got my message of inquiry) who favored the AirLift 1000 coil air bag system over new adjustable shocks. He feels that Dodge put heavy shocks on our model and that at 15K miles they should be far from worn.
Old 08-07-2014, 05:16 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Be a good time to do a weighing or a careful measuring of fender heights. You need to find out how much weight you are transferring back to the front axle to judge if you are getting enough weight transfer. Level bars does not mean much. I pull a 25' with 800lb bars. My 25 puts 800 lbs weight on the truck. I switched to the 800 lb from 1000 lb bars. I can not answer your original question since I have never owned either. I would be inclined to go with the airbags because I have friends who have had the leaky shocks. My guess is that you are going to need to add some more weight transfer to get the front end to the proper load.
Old 08-07-2014, 08:11 PM   #6
1981 31' Excella II
Tighten the bars till the truck is level.
Perry
Old 08-07-2014, 09:48 PM   #7
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You need more weight transfer to the front. Don't know what brand hitch you have, but tilt the hitch head down towards the back (add more washers) so you can lift the rear of the truck higher.
Doug and Cheryl
Old 08-08-2014, 10:29 AM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
The Airlifts are ok. Tuftrucks makes a progressive rate shock, a 25% stiffer of stock and a 50% stiffer over stock. Some of the guys on the Ramforum.com who haul campshells who are NOT OVERWEIGHT switch to the shocks over the Airbags.
Look, rather than argue with the know it alls on this site. Our Dodge Ram's feature a linear spring that compresses under load. That's what it's designed to do. They sag. Period. Some of the other shocks are progressive.
Linear spring will compress 2 inches for 200lbs, 3 inches for 300lbs. A progressive spring will compress 1.5 inches for 200lbs and 2 inches for 300lbs, etc. (example weights)
So if you want after you try adjustments and check weights, springs paired with better shocks are a better option over bags IMO. However the truck will ride a little harder than it does stock.
Bags are better if you don't tow a lot. Good luck.
And watch out for the payload police.
Yours Truly
- Someone that actually owns a Ram.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-08-2014, 02:17 PM   #9
Our 2013 RAM 1500 Crew Cab 2x4 has coil springs. I am looking at simple Airlift 1000 airbags that fit inside the coils and have a Schrader valve above the bumper.
The measurements from top of wheel wells is dead even when towing the 23D with water tank at 1/2 and truck fuel tank full....with typical cargo in the trailer and a rather light load in the camper shell covered bed.
What I noticed when moving up from a 2013 International 19 to the 2013 International 23D was a harsher ride and some bounce.
The fender well measurements when towing both trailers was almost exactly the same...even. The rear fender well height is 2 inches heigher when not towing.
I'm not trying to increase load capacity.....I'd just like a better riding rear end.
Old 08-08-2014, 04:28 PM   #10
dkottum's Avatar
We have a Ram 1500 with rear coil springs as well, tow a 25rb. Our ride was improved when we put a hitch with 1400# bars so we have excellent weight distribution. You probably have too much weight on the back of the truck and not enough on the front, a combination that can cause excessive bounce and harsh ride. Keep working with your w.d. hitch, add washers to tilt the head back and get more lift. With good weight distribution the full coil spring ram is a nice riding truck for towing.
Doug and Cheryl
Old 08-08-2014, 08:21 PM   #11
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
It should be smooth as silk (if you aren't on the bump stops)
I also have a RAM 1500 with rear coil springs. Mine is a 4X4. I recently towed with it for the first time. It was a beautiful, smooth ride while towing our 1972 Ambassador. It weighs 6,500lbs with a 950lb tongue weight.
I would say that you must not be getting enough weight transfer to the front axle as dkottum points out. The only way to know is to take your loaded for camping rig to the scales and find out how your hitch is working (or not). It is the only way to know for sure.
Lance
Top is offline   Reply With Quote
Old 08-09-2014, 08:38 AM   #12
Nomadic , USA
All Ram 1500's 09 and up have coil springs . When I said shock earlier, I meant spring. This is also why they ride and handle better than Ford, GM and Toyota.
This fact is lost on the Ford & GM owners who have leaf springs and terrible rides. But leaf springs don't sag as much under weight.
This is a fact. This is why the new 2013 and up offer the Air ride that adjust automatically when you hitch up. Just hope it doesn't fail. Because a lot of folks are having their Air rides fail in the first year of ownership. Luckily their is a warranty.
Old 08-09-2014, 09:25 AM   #13
dkottum's Avatar
BoldAdventure, just curious. The truck in your Avatar appears different than the truck in post 8 above, not sure which one you have. Also, did you buy an Airstream yet?
Doug and Cheryl
Old 08-09-2014, 09:40 AM   #14
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I use Airlifts with my F250 and have for about 7 years. I have a shackle system and the bags mount over the shackles. I find them really useful for fine tuning the ride, especially when carrying a lot of camping gear in the truck bed.
720 lbs tongue weight seems a lot for that trailer. Is that the spec rated at GVWR or was it weighed?
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Towing with a 1999 Dodge Ram 1500 crew cab with 8ft. box with 5.9L engine Paul and Sue Tow Vehicles 11 07-27-2009 08:44 PM
Dodge Ram 1500 Tow Vehicle UK-Airstream On The Road... 6 06-07-2008 12:54 PM
Dodge Ram 1500 Tow rating HELP!!! cobra93 Tow Vehicles 11 02-05-2008 07:20 PM
Dodge RAM 1500 SLT 5.9 liter tow vehicle abridges01 Tow Vehicles 10 08-17-2006 08:25 AM
