Old 10-25-2009, 03:32 PM   #1
Concord , California
Aftermarket cooler ok???
I just found a 5.4 1500 chevy 2006 but with NO towing package I was told pickups of that size engine ALREADY have a larger radiator and tranny cooler. I only need to professionally have a prodigy, and sway braces installed with new hitch. Is that true? Would that be as good as factory??Thank You Dave Gale
dansdad is offline   Reply With Quote
Old 10-25-2009, 03:48 PM   #2
Adding a transmission oil cooler, will pay many dividends.
But, don't install the cooler in front of the radiator, or AC heat exchanger.
To remove the heat from the radiator, is great, but you don't want to turn around and put it right back into the radiator.
Install the tranny cooler, below the radiator, behind the bumper, so that it can get plenty of "ram" air when moving.
That installation does 3 things.
1. It removes heat from the radiator.
2. It helps controlling the tranny oil temperature.
3. It helps lowering the engine temperature.
Installing a tranny cooler in front of the radiator, helps with # 2 only.
Old 10-25-2009, 03:52 PM   #3
Then what you are saying Andy is that 5.4 engines dont just come with proper tranny coolers and larger radiators? Stick with factory only?
Old 10-25-2009, 03:56 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
With out the tow package does the truck have a 7 pin trailer connector or a tow/haul switch?
Richard
Old 10-25-2009, 03:57 PM   #5
Adding a tranny cooler, is a plus.
Not having one, over and above what might be original equipment, will cause the tranny oil to reach temperatures that will cause harm.
Old 10-25-2009, 03:57 PM   #6
No it does not. There is nothing there
Old 10-26-2009, 10:20 AM   #7
What I meant Richard... is that no wiring harness is present. I really want to know if 1/2 trucks come from the factory with a large tranny cooler. If not II will get one. Dave
Old 10-26-2009, 10:30 AM   #8
Dave.
A good tranny cooler will be about 8 x 12 inches and about 1 1/2 to 2 inches thick.
Anything less than that is not adequate for towing a large Airstream.
Hayden makes the best tranny coolers.
Old 10-26-2009, 10:37 AM   #9
Kevin245's Avatar
Don't know about other brands, but my Ford did not come with an external transmission cooler. It had one for the power steering pump only.
My only gripe about most of the aftermarket coolers is the cheesy plastic ties manufacturers provide to mount the cooler. We ended up fabricating an aluminum frame to mount ours in.
We had trouble flaring the trans line steel tubing. I ordered some steel compression fittings that did the trick.
It was a six pack project.
Regards,
Kevin
Eleanor Roosevelt
Old 10-26-2009, 01:23 PM   #10
SteveH's Avatar
Common Sense , Texas
"Normally" there is more to a factory towing package than the tranmission cooler. I'm not up to speed on what Ford installs, but the GM trucks with the towing package come with a transmission cooler, factory trailer wiring harness, a heavy duty radiator, a heavy duty alternator, receiver hitch, and a lower rear end gear ratio...usually a 3.73:1, although the Chevrolet 1/2 tons use a 3.42:1 when I was last looking at the specs.
Aftermarket Breakaway Switch uniquemicro Brakes & Brake Controllers 2 09-19-2009 07:20 PM
Aftermarket solar flmgrip Generators & Solar Power 1 08-09-2009 06:23 PM
Lets see your aftermarket wheels???? LAWFISH Wheels, Hubs & Bearings 4 04-20-2009 05:55 PM
Aftermarket Miles Per Gallon Gauge herrgirdner Off Topic Forum 11 05-22-2008 08:32 PM
Dealer/Aftermarket Hitch Equipment Toasty's Dad Hitches, Couplers & Balls 12 12-02-2005 12:18 PM
