Old 06-01-2016, 08:58 AM   #1
2000 25' Safari
Denver , North Carolina
Advice and suggestions on which AS to pursuit
Hi, Looking for an AS and have been stalking the forums. It seems I almost put the cart before the horse. Now that I've calmed down what I need is some advice or opinions on what I can really tow. GM ( GMC 2007 Sierra with tow package) says with the engine size and the 3.42 axle ratio, I have a maximum towing capacity of 6,600 lbs. I've been looking at a 1990 and 85 Excella. They might be too close to capacity. Any comments or suggestions? Should I downsize in length?
mbubbaca is offline   Reply With Quote
Old 06-01-2016, 09:50 AM   #2
2012 25' FB Flying Cloud
Parker , Colorado
Rule of thumb is to have 2,000 lbs towing capacity over your GVW. That would put you at 4600 pounds LOADED for your trailer. But I live in Colorado and routinely tow over 11,000 ft passes. I would stick with this anyway, gives you better acceleration and control. And nothing can ruin a vacation quicker that feeling uncomfortable towing.
You have a good axle ratio, and getting the proper hitch setup makes a huge difference. I'm no expert, but sticking to this has worked well for me. Good luck in your search.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 06-01-2016, 10:59 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Not much into rules of thumb here but I do like to consider the overall towing combination, truck, hitch and setup, and trailer.
Airstreams have low frontal and side wind resistance, as well as full independent suspension and low center of gravity for stability. As good as it gets. Weight ratings don't consider these advantages over most trailers, they make an easier, more efficient and safer trailer to tow.
A high quality weight distribution hitch with separate or integrated sway control can equalize the hitch load on the truck's axles as desired and transfer some to the trailer's axles. Set up properly it can help stabilize the truck in turns, and ensures better braking. An Eaze-Lift w.d. hitch and two separate sway control bars are inexpensive and will do a good job. If towing cross-country regularly a ProPride/Hensley style hitch will make your towing life much more pleasant, if not your pocketbook.
The truck has ratings for load and towing, they are good starting points. You can improve it with good trailer and hitch selection as mentioned. The axle ratio can improve the power to the drive wheels, and you can improve the ration uses lower gears, changing axles, or a little smaller diameter tire if t has enough load capacity for you. On a truck a few years old you can improve handling, stability and ride by putting on new, high quality shocks such as Bilstein. Pay attention to axle and tire ratings, and use a truck scale to verify your loaded truck and trailer, and weight distribution hitch setup are ready to travel.
The easiest, surest and least expensive way to add safety margin is to reduce towing speed, less chance of trailer sway, loss of control in an emergency maneuver, safer braking on hill descents, better driver reaction time, and less stress on drivetrain components. Not to mention improved fuel efficiency and less tire wear.
Your truck is most probably very good when properly set up towing these Airstreams. Similar trucks have routinely towed similar Airstreams all over North America safely, and continue to do so.
Doug and Cheryl
Advice and installation suggestions for Perko switch M and M Batteries, Univolts, Converters & Inverters 0 11-11-2015 07:19 PM
Heating and Air Cond. - Which wires are which? trekerboy Electrical - Systems, Generators, Batteries & Solar 12 08-09-2015 08:37 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
not really in news - pursuit show dufferin Airstream "In the News" 0 10-08-2007 09:43 PM
