07-10-2018, 02:23 AM
Dalton
, Ohio
Acura MDX towing
07-10-2018, 04:09 AM
2018 28' International
Fayetteville
, Georgia
Not wanting to rain on your parade, but the tow rating of an MDX is 5000 lbs, with or without the hitch enhancements, and a 25 footer will weigh well north of that. Your bigger issue may be payload. Check your door sticker for the actual payload for your MDX, but likely 1300 to 1400 lbs. Tongue weight is included in payload.
Not saying you can't do it, but you will be maxed out for a cross-country trip.
brick
2018 International Serenity
Cute wife...
07-10-2018, 04:32 AM
Trailer Sold, Waving
2019 26' Flying Cloud
Stettler
, Alberta
http://m.acura.com/pdf/owners/2016/M...MDX_Towing.pdf
https://www.airstream.com/wp-content...542d07b489.pdf
Hitch Weight 720 lbs
Gross Weight 7300 lbs
Dry Weight 5210 lbs
Cargo Weight 2090 lbs
Just looking at the numbers, I would not tow this rig with your Can-Am reinforced Acura. Certainly cannot carry any food, water or clothing. I presume you obtained insurance, so someone is ready to underwrite it. But not me. Best of luck.
For your approximate $13K trade-in value, it might be worth your while to look at suitable pickup trucks with adequate tow ratings.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
07-10-2018, 05:14 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Too scary for me. What are you engine and transmission temps looking like.
“I” feel that you are forcing that little car to do something it was not made to do.
Legally if you have an accident someone is going to send you to the cleaners.
Towing outside the manufacturer spec is a risk that “I” am not willing to take.
Good Luck, and safe travels.
07-10-2018, 05:33 AM
2011 Interstate Coach
Evansville
, Indiana
I'm an Airstream Interstate owner so I know little about towing but know quite a bit about Acura MDXs (own an '06 and '15). Their transmissions (specifically the torque converters) are notoriously prone to failure. Both of mine have the "judder" condition around 45mph. Towing a heavy trailer up and down mountains would not be something I would consider, knowing the "delicate" nature of these trannies. I would take the previous poster's advice and look into finding a tow vehicle that is up to the task.
07-10-2018, 06:09 AM
Fayetteville
, Georgia
. I would take the previous poster's advice and look into finding a tow vehicle that is up to the task.[/QUOTE]
I took this advice, and am glad I did. I had a 2016 Expedition Ecoboost with a 9200 lb tow rating, but only 1319 lbs payload. It had plenty of power to tow my new 6200lb (dry) 961 lb tongue weight Serenity 28, but still felt overwhelmed from a suspension standpoint.
So I traded for a 2018 F250 Diesel. The difference in towing is night and day (duh...) Makes towing so easy, I have to remind myself there is a shiny silver thing behind me. I would find it hard to go back to a lesser capable tow vehicle.
Towing across country is a big trip. Long miles, mountains and summer heat will take a toll on your MDX. Reconsider your options.
brick
07-10-2018, 06:35 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Originally Posted by brick1
Not wanting to rain on your parade, but the tow rating of an MDX is 5000 lbs, with or without the hitch enhancements ...
I disagree. The hitch receiver upgrade makes a substantive improvement to your towing capacity. The towing capacity is not based on the overall suitability of the vehicle but only the receiver capacity.
The towing rating is based on the strength of the receiver in North America. IIRC a minimum of 10% of the trailer weight is the recommendation for the tongue weight. If the vehicle manufacturer engineers and manufacturers a low quality, stamped metal receiver that can only handle 500 lbs then it logically follows that the towing capacity would be 5,000 lbs.
However, if you increase the strength of the receiver to a Class IV (which is capable of handling a WD hitch with 1,000 tongue weight) then, if you stay with the 10% tongue weight rule of thumb, your trailer weight could be up to 10,000 lbs and it could be towed safely (i.e. avoiding sway at up to 65 mph), if loaded correctly.
Ray B.
07-10-2018, 07:11 AM
Fayetteville
, Georgia
By that logic, if I put a really big 2.5 inch receiver hitch like the one on my new F250, the MDX can tow 15,500 lbs...
Vehicle tow ratings are based on many factors, and the hitch is only one of them. Engine, transmission, suspension, brakes, unibody construction and many other factors contribute to the rating. I tend to trust the engineers who designed the vehicle to understand it’s limits.
07-10-2018, 08:01 AM
Niagara-on-the-Lake
, ON Canada
...I tend to trust the engineers who designed the vehicle to understand it’s limits.
It isn't the engineers who specify the hitch it is the marketing department. Why, they say, put an expensive hitch receiver capable of WD on a vehicle that most people won't use for towing.
Ray B.
07-10-2018, 08:09 AM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
Not an Acura MDX but set up by Can Am. Currently with 500,000 k and 300,000 k towing a 25 Safari and then a 30 International. Sent out to pasture as a daily driver. It will be coming for a visit next week. Your Acura should do just fine.
07-10-2018, 08:14 AM
Fayetteville
, Georgia
I suspect that vehicle manufacturers match the hitch rating to the overall vehicle capacity. It makes no sense to put a heavy, high capacity hitch on a vehicle not capable of utilizing it. It might also encourage someone to assume a vehicle with a 10,000 hitch can safely tow 10,000 lbs, despite the vehicle’s 5000 tow rating...
brick
Cute wife...
07-10-2018, 08:27 AM
2015 27' Flying Cloud
Newberg
, Oregon
Well, free advice is always worth the price. :-/
If you do decide to keep your currant rig, I would be interested to hear how it does towing up and down the Rockys in Summer, or if you are getting shoved around by the wind wall from big rigs passing you on the freeways.
07-10-2018, 08:32 AM
2016 26' Flying Cloud
Southlake
You are trying to defy the laws of physics. There is no way I would drive that setup across the Rockies, or anywhere else for that matter. I drive conservatively and in 2 years I have had 2 situations where I was cut off by another vehicle on the Interstate. Both times, I had to swerve aggressively and if I had been towing with anything else I would be a statistic.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
07-10-2018, 09:36 AM
Vancouver
, British Columbia
Agreed. Lots of posters saying it can’t be done, while others are just out doing it.
The MDX is built on the same platform as the Pilot and the Odyssey. Isn’t there an Odyssey documented on here that was pulling a 34 tri axle for extended time and distance?
Take it easy on the hills out west, manage the payload, and the OP can tow just fine.
07-10-2018, 10:50 AM
2016 27' International
Sherwood Park
, Alberta
I would get to a scale ASAP and weigh your rig, paying particular attention to the rear axle of your MDX with the trailer hooked and loaded up like it would be for travel. Once you have that number, look at the door sticker for the max rear axle weight rating. If you are under that, I would be very surprised. Next, check the sidewall of your rear tires for their weight rating to make sure you are not exceeding their rating. These 2 things are not capability to tow issues, they are serious safety issues, neither of which has anything to do with whether your hitch can take it.
The next thing to check is the vehicles tow rating. This is only partially based on the OEM hitch. The others are engine and transmission strength and their cooling capacity when under the stresses of towing and the vehicles braking capability. At best, your MDX is rated to tow 5000#. This is if you have the extra cooling, 3500# otherwise.
Please let me know what mountain roads you plan on travelling so I can stay clear. I would not want to be in front of you near the bottom of a 7 degree grade, 5 mile hill with a few twisties for good measure as you go thundered past with smoke billowing from your MDX brakes.
I am a big MDX fan, but other than hooking up the utility trailer to haul a load of whatever to the local recycle, I would not hook up anything that weighed enough to require a WD hitch.
07-10-2018, 11:26 AM
Fayetteville
, Georgia
Not saying it cannot be done. Saying it may not be the smartest decision for the OP or the Acura...
07-10-2018, 01:41 PM
Mountain View
Here we go again...
Always nice to see a SUV towing a larger trailer. I do not know Acura. I can only tell you that X5 tows 33 ft long trailer like on rails. This is SOB. Airsteam will always tow better than SOB. I towed it through Rockies, Sierras a number of times.
I would not worry too much about payload. Just check the axle and tire weight ratings.
07-10-2018, 02:13 PM
Sherwood Park
, Alberta
Originally Posted by bono
Here we go again...
An MDX ain't no BMW X5. I tow a 27 FB with a Cayenne, but that doesn't mean that an MDX can. Comparing apples to oranges will not help the OP. And to tell the OP not to worry too much about payload is just wrong. Payload specs are there for a reason, to keep everyone safe.
07-10-2018, 02:39 PM
Mountain View
You have your opinion, I have mine. Being 100-200 lbs over payload should not result in catastrophe. IMO there are more important specs to worry about.
Any I did not tell OP that he can tow this trailer with Acura or that Acura is similar to X5. What may help OP is to be aware that SUV can tow larger trailers, despite 90% comments in similar (US) forums.
07-10-2018, 03:29 PM
Fayetteville
, Georgia
Airstreams have been towed with bicycles. Doesn’t mean it is smart...
brick
Cute wife...
