Old 07-18-2009, 05:36 PM   #1
2004 25' Safari
San Francisco , California
a.moore
Hello: I just purchased a 2004 25 Airstream (SS). I have read that the new Ford 150s (2009) have a towing capacity of 11,300 pounds, but I'm not sure about other features such as the brakes, transmission, etc. Also I was told you don't need sway bars on these new 150's.
I am partial to Ford 150's. Would the 2009 F 150 (5.4 liter engine) V8 be appropriate for this trailer, and is it true that sway bars are not necessary on this model?
a.moore is offline   Reply With Quote
Old 07-18-2009, 05:52 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
YEP, that would work, Just make sure you get the 3.73 rear end.
Now as far as sway control goes they are suppose to have it built in, and I remember seeing a video on it.
Personally, it looks like a fancy anti slip deal. I would still put a real anti sway bar on it. They aren't that expensive and they really work well....
Just make sure you get the right tow package they make a lot of different ones... and you want the double cab with the 145 in wheel base not the short 126 in one..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-18-2009, 05:57 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Even if it doesn't sway, you still need weight distribution and a WD hitch will provide sway control as well as weight distribution.
Gene
Old 07-18-2009, 06:14 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Agree.... a quality WD hitch with sway control, properly set-up, is an important part of towing, not an option, a necessity.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
