Old 07-29-2009, 08:25 PM   #15
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Isn't there a drive shaft from the case to the front differential that can be removed?
It would be cheap and easy as long as there isn't a slip joint into the transfer case. And cheap and easy is a rare combo these days!
Action
Old 08-20-2009, 12:12 AM   #16
1975 31' Excella 500
Orcutt , California
Hi, I also have a 99 4X4 Suburban, only a 1/2 ton which I'm looking to replace with something more suited to towing our 31ft Excella.
Anyway a little over a year ago I got a service 4WD system light and unfortunately decided to shift out of 2 wheel high to 4 wheel high and then to 4 wheel low where I got stuck. I did some research online and read that the push button 4 WD system was known to have a poorly soldered switch. I removed the switch and re-soldered the connections on the back of the switch. The light went out and I've been able to shift into and out of 4WD for the last year without any problems.
Might be worth a try, good luck
CGStitt is offline   Reply With Quote
Need technical info for ordering electric brake components turfclubroad 1980 Caravelle 5 07-06-2009 09:30 PM
Shark-bite Pex components. boatdoc Fresh Water Systems 19 11-05-2008 07:00 AM
Steering components shocker bkahler Mechanics Corner - Engines, Transmission & More... 2 06-14-2007 04:54 AM
Parts source for 345 rear suspension components? Honkity Hank Classic Motorhomes 3 07-17-2006 12:56 PM
