Old 01-20-2012, 08:18 AM   #15
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
You guys are on target about the importance of changing your brake fluid (I would say every 2 years). I think the term for brake fluid is hygroscopic, which means it absorbs water (another reason not to use that OLD bottle of brake fluid in your garage when servicing your brakes.
So you get the double wammy, corrosion from the inside (easily counteracted by proper maintenance) or from the outside (more subject to quality of materials and environment in which the vehicle is operated).
I'll add to Bob's list of brake bleeders by including the one by Motive products too.. The one thing to bear in mind is that if you do it yourself, and want to do it right, read up on how to cycle the ABS while you are bleeding so that gets a full fresh dose of fluid. Dealers would use their TECH 2 scanner to handle that.
Dennie
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 01-20-2012, 05:57 PM   #16
r carl's Avatar
Lin , Ne
I just bled the brakes in my 2500HD yesterday. I just cracked a bleeder and let graviity do it thing. When you notice the new fluid shut the bleeder and move to the next wheel. You must monitor the master cylinder fluid level, do not let it get too low!
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
Corrosion Kirbys Ribs, Skins & Rivets 4 01-19-2011 06:39 PM
